Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Like Tree3Likes
Old 02-10-2013, 09:31 PM   #21 (permalink)
I was able to go through the full airframe and tail today and check all of the screws and reloctited all of the screws that are load bearing. I got the complete airframe together and read for electronics. I got the heli used so i wanted to go through everything and make sure it meets my expectations. I still have to go through the head and of course buy and install all of my electronics. I pulled the trigger on the HC3SX today so it will definitely be going in the Diabolo. Still have to figure out the rest, but i have a pretty good idea of what I'm getting.
Protos Max 700 Vbar, Synergy E7se Vbar, Rush 750 Vbar, Gaui X5 Vbar, Gaui X4II Vbar, Protos 500 Vbar, Compass Warp 360 Vbar, Gaui X3 Robird
Controlled by: Jeti DS-16
Clay333 is offline        Reply With Quote Quick reply to this message
Old 02-10-2013, 10:26 PM   #22 (permalink)
Clay,
You will be glad you got the HC!!!
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 02-10-2013, 11:22 PM   #23 (permalink)
Originally Posted by jcflyer View Post
Clay,
+1
NickBee is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 10:30 AM   #24 (permalink)
Got the "business end" wired. I'm done crimping on this project now!
Old 02-11-2013, 10:34 AM   #25 (permalink)
What's up they were sold out of the big ESC? JK. Your wiring is quite impressive and meticulous.
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 06:14 PM   #26 (permalink)
Discovered that my tail control loss incident was not my dodgey wiring, but a faulty brain, goes mental when touched
Put on a new brain and problem fixed.
Hopefully this weekend I will get some consistent packs thru the diabolo...
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 09:01 PM   #27 (permalink)
I got one word for you.... HC3SX. Or is that 5 words?
Old 02-12-2013, 09:25 PM   #28 (permalink)
Should be here tomoz, lol.
I'm going to trial it on a mini protos first tho.
Old 02-12-2013, 10:22 PM   #29 (permalink)
Sweet. I use one in my stretched P500. Works great.
Old 02-13-2013, 09:40 AM   #30 (permalink)
If your HC3SX behaves weird or if your heli drifts first thing to do is lighten up those cables. So many rigid cables with wrapping and heat shrink at the end plus everything zip tied together over a FBL unit which is a one piece box with the sensors inside is a no no, it induces a lot of vibration. You might be fine, but have this in mind if anything arises.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 09:56 AM   #31 (permalink)
I thought of this. There is some wiggle in the harness but the braiding does stiffen things up a bit. I have seen similar setups where the last half inch before the connector is left uncovered. Might be a good compromise of protection with some bare wire to soak up vibes. I might go back and do this...
Old 02-13-2013, 02:02 PM   #32 (permalink)
Don't sweat about it, on electrics it is not so critical, specially if you are using a hard foam or a thin 3M tape. Another symptom could be less than perfect stops on cyclic, some bouncing there. Again, less probable with hard tape. As long as the FBL doesn't get blurred by vibes and makes the heli commit suicide, which is unlikely coming from cables and more likely from unbalanced or bent tail or main rotor, you should be fine.
Marcos
Old 02-13-2013, 08:32 PM   #33 (permalink)
If you look at the pic's from my build you can see how I did my wires, I had read about this a while back.
Logo 500SE
Old 02-14-2013, 02:19 AM   #34 (permalink)
Default What did you do with your diabolo today?
Did a test hover after replacing the brain to make sure it's good for this weekend.
Went well, little bit surprised with battery consumption, 12S 5000mah, 5min hovering with a couple pitch pumps and piro's, landed with 64% left!
I could do a 10min hover, and this was with 1800 on the head, could easily go down to 1400 and get a lot more again!
Old 02-14-2013, 09:14 AM   #35 (permalink)
Yup, I think that is where I saw it done. I picked up some 3:1 heat-shrink yesterday at a local electronics store. So I'll be able to cut back the braiding and re-heat-shrink without removing the connector. I'm thinking about 1/2" of exposed wire before the connector. We'll see once I get around to it.
Old 02-14-2013, 04:50 PM   #36 (permalink)
Default Re: What did you do with your diabolo today?
Maidened mine today. Wow, what a sweet bird. Flew it and my TDR for several of break-in and tuning flights. So far to date the Diabolo fits me the best yet. Can't wait to get back to the field.
Jake
jakeg1999 is offline        Reply With Quote Quick reply to this message
Old 02-14-2013, 04:58 PM   #37 (permalink)
My flight times started around 5:30 but are creeping more towards 4:30 now that im getting comfortable with it 2050 rpm, radix 710, no hovering
Sent from tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 02-14-2013, 05:05 PM   #38 (permalink)
What tail pulley are you using?
Old 02-14-2013, 05:49 PM   #39 (permalink)
The regular one, not the red. Rail 106's
Sent from tapatalk
Old 02-15-2013, 07:34 AM   #40 (permalink)
Sent from tapatalk
Me too. Now 4:15 at 1700 rpm
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
