Old 12-04-2012, 10:57 AM   #41 (permalink)
my 800-40 arrives tomorrow... not stoked after reading this :o
honey bee king II
andersn is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 11:42 AM   #42 (permalink)
Originally Posted by smsodhi View Post
Thanks guys.
I forgot to mention, I checked inside the can on its arrival and the magnets were perfectly spaced. They moved whlie the motor was in operation and put it off balance.
Not good, as you say for a premium brand charging premium prices. It would be impossible to know if this would happen unless in flight or bench testing!!
I suppose, lucky me, it didn't happen in flight.
As Ralph said numerous times 14 poles tend to come loose, i have one in banshee and 850 arrives in a day or two, gonna pour some loctite over it and hope for the best. Seems k got it wrong this time, been quite a couple qc issues on these motor, so wtf did i buy them
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 01:06 PM   #43 (permalink)
Thanks guys.
Now that doesn't inspire any confidence. I mentioned in your other thread that I got a stock Pyro 800-40 for my XXtreme so short of physically trying to move the magnets, HTF will we know that the magnets won't play musical chairs while in operation???
Again, Kontronik isn't inspiring confidence here. The standard warranty will be limited to replacing the motor only.
PS> HTF: H(ow)TF instead of W(hat)TF. I'd usually write LOL here, but I S(ure)TF don't have a reason to laugh right now.
ElectricSheep is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 03:27 PM   #44 (permalink)
Thanks for making me laugh
Seriously you won't know you have a problem untill you run the motor. Run it on the bench and do some auto bailouts and see if it dislodges the magnets. The motor was also only at 48 degC when it happened. Yes I actually measured it.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 09:28 PM   #45 (permalink)
I don't get it.
Do they not do extensive testing before bringing things on the market.
When one charges a premium price peoples expectations of quality control exponentially goes up.
wow that some shift on the magnets.
Perhaps some kinda bracing on the magnets may help.
not sure if that possible ....
I think the initial start-up of any motor tends to put a lot load till it gets its momentum on the rotors and gear train.
My Brand new pyro 800, I went to fly it today and it would not spool up. I got a 8 blink error with the helijive v11 in the field.
Came home, same thing on the bench. It would start, then a grinding noise, and then it would spool up.
I changed the helijive to a V12 one I had in the draw. Started to work. Then after some testing, getting logs with the JLOG big vibration and I stopped. Had a look inside and well the pic speaks for its self.
I cant believe my luck. You know I had that issue with the 700 and now this!!
I will contact K and no doubt send it back!!
I assume the first helijive must have picked something up and stopped me from flying. The second helijive, well, lucky I did not have that one in the heli!!
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 08:21 AM   #46 (permalink)
Well spacer rings double as braces but o' l Eddy and his ever prsent current apparently becomes a problem , well tbh i dont mind having Eddy for supper if it keeps my motor intact, chk the hobbyking helidrive
Old 12-05-2012, 04:51 PM   #47 (permalink)
So make a spacer out of plastic (POM should be strong enough and sufficiently heat resistant) or some other insulator. Then Eddy can go away
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 07:01 PM   #48 (permalink)
If I'm not mistaken isn't the newer Pyro 600 14 pole ?
Not heard or read any magnet shifting regarding these particular motors.
Could this be just a case of poor quality of bonding or more the fact 800 motor are much
larger in size hence magnifying the inherit problems of 14P that Ralph had pointed out ?
why not just machine in slots on bell can itself both on the bottom and top.
all scorpion motor bells have these nice slot milled on the bottom of the bell where each magnets sits.
In this case it seems just gluing the magnets on the bell is not enough.
I understand its extra work but when charging a premium dollars I'd expect the extra mile.
yup seen and looked at HK heliDrive. Interest still tempted to try one.
Old 12-05-2012, 08:01 PM   #49 (permalink)
Hey helifx,
EDDY CURRENT!!!!!!!
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 09:55 PM   #50 (permalink)
even having slots on the bottom of the bell can ?
I thought it was just the top area or stator.
Perhaps alternative bonding method could be used.
ah I'll stick with 10P motors
Originally Posted by ZuvieleTeile View Post
Hey helifx,
EDDY CURRENT!!!!!!!
Old 12-06-2012, 06:44 AM   #51 (permalink)
Some Pyro 700's also had issues with loose magnets, no reason really to not buy one.
This is the first mention on the internet regarding magnets on the P8xx as far as I know, people put negative experiences online very fast...
When all is good you hear nothing.
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 09:50 AM   #52 (permalink)
Yeah well Dekker not the first i read about http://www.rc-heli.de/board/showthread.php?t=211293, and you can bet it wont be the last, if it comes loose it means they use the wrong glue so chances are many will come loose, or you think perhaps they forgot to glue also the chaffed wiring etc, i bought 2 already but at least i can fix mine i think qc is lousy for an upmarket motor and if we dont voice our opinion k will do nothing about it!. I already tgrew some loctite on my mags and placed it in drill so centrifugal force dan hopefulle force some 648 into the empty spaces. Hope it lasts
Old 12-06-2012, 10:06 AM   #53 (permalink)
Hey helifx,
EDDY CURRENT!!!!!!!
Kontronik used 14 poles in many motors before, the problem here is magnified because of first the strength of the magnets then the larger bell flexes more under various loads so dislodging the mags, a very strong flexible glue should be the best solution.
Old 12-06-2012, 11:07 AM   #54 (permalink)
Well this is actually hilarious, while waiting for my loctite to dry had a quick look at the wiring, guess what!, seriously they have lost it, BIG TIME! Lucky doesnt matter in my case but man they gotta do something quick or sell motors with rewinding kit for backup. For the record i didnt come close to this motor with any tools, the way it came out of bell.
Old 12-06-2012, 11:17 AM   #55 (permalink)
I agree, at least for us it would be better if we could get kits.
Old 12-06-2012, 12:21 PM   #56 (permalink)
Remember, not all of us are your level, could you enlighten whats wrong in pic? the marks on stator?
honey bee king II
Old 12-06-2012, 12:36 PM   #57 (permalink)
Their winding machine had a mishap on the wires: they are damaged.
Old 12-06-2012, 01:07 PM   #58 (permalink)
where the yellow "lumps"? seems to be? I thought it was just glue, but its stripped insulation?
honey bee king II
Old 12-06-2012, 01:16 PM   #59 (permalink)
Yes it's stripped. K does not use glue.
Bert
Old 12-06-2012, 02:10 PM   #60 (permalink)
I would seriously check out every pyro 800 or 850 for this problem, i have from a reliable source that its much, much more common than we think, since i'm running stock 800 in banshee guess i' ll have to pull that motor and do a check i' m sure k did the 1000 volt test so just some hi temp epoxy on it will do the trick, if like me not worthwhile to send back as reliable shipping is 100 usd. Its a real pity a motor with so much potential, dunno how a respectable company like them can get it so wrong. What bothers me more is the mags they should talk to eflite as to what glue they use, softening in oven makes it harder every time it cools down so after 4 oven sessions on wire out comes the mini gasflame, rewinders nightmare but it does the job for sure
