R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters |
11-09-2014, 06:05 AM | #1 (permalink) |
Where to find small/micro compound (servo) gears by tooth count and mod
Update.! Still no luck. the gear I need is 24/12tooth. Both gears are the same module 0.1-0.25. Hole for shaft is 1.0mm. I only have a plastic micrometer, that came in a generic set so I don't trust my measurements enough to say for sure
on the mod. or I could get a cad drawing of it. Even with specs the only option I could find was custom manufacturing. I do not need 500 of them ten maybe . I have some generic micro servo's (14g) actually. they are metal gear with a very small plastic gear between motor and gearset. Funny thing is there is room and attachment points on both sides of the pinion and gearset to allow for dual plastic gears to be used I actually moved the shaft and gear on one servo to the other side as the botom hole on the original side was wollowed out of round causing poor gear mesh. I would like to run dual gears on all 3 of the servos. gearsets aren't available and Ihave no intentions on buying 2 servos for each one each time the plastic gears go (which I hope will be never w/ dual gears and sacraficial arms in place) I haven't counted the teeth yet but I would guess (based on mcpx gears being mod .3) it is a basic servo type gear w/ a larger flat gear on top and a smaller thicker gear on bottom. shaft is prob 1.5mm x 6mm long gear is 3or4mm thick total. Ireally son't know w/o measuring ok so google was my best friend here. searched for: mod 0.2 compound gear and found several resources some reasonable some outrageous. Once I complete an order I will report back. In the meantime if anyone knows of a trusted resource for this please let me know.
MSRX CX450 Black Angel Stretch DFC -HW 50v3, Hyperion 2221-6 3dx450b3 Scale Huey Rescue, TGY Sk3 3600kv, Yep 45a, Robird, CX rigid 3 blade head Protos Carbon Stretch, MSH Scorpion, YGE, Ikon Last edited by deebee; 11-16-2014 at 02:15 PM.. Reason: No Luck Yet |
