Old 01-01-2011, 09:54 AM   #1 (permalink)
Default mini-protos head speed ?
Mini-protos 16t pinion , stock motor (2580kv) / YGE 60A esc ! how much head speed at 100% throttle ? anyone help ? thank's
1972neo is offline        Reply With Quote Quick reply to this message
Old 01-01-2011, 05:32 PM   #2 (permalink)
probably around 3200 to 3400 depending on what packs your use
JASON671 is offline        Reply With Quote Quick reply to this message
Old 01-02-2011, 12:19 AM   #3 (permalink)
If I remember well I have around 2800 at 70%.
Francesco
ziper_it is offline        Reply With Quote Quick reply to this message
Old 01-02-2011, 06:32 PM   #4 (permalink)
At 90% I am getting 3190 with everything stock. I am going to change to the 15 tooth pinion and see what I get
jdanks is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 12:41 PM   #5 (permalink)
I've heard 3500 is the max recommended rpm. I wonder what points are stressed more once above 3500. Grips? Belt? Tail? I wonder because I've tried my 450 pro at 4k rpm and it's is a friggen blast. It wouldn't be a daily flyer, but good for a sunday afternoon rip.
Stuff
Rob Cherry is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 07:49 PM   #6 (permalink)
Default hi
im assuming that max head speed is because of the plastic main grips,, i hope he gets the metal ones out soon. i m planning on building this ship for higher head speeds... does anyone know what the projected headspeed is with the 17t and 18t ?
audio131 is offline        Reply With Quote Quick reply to this message
Old 01-04-2011, 08:49 AM   #7 (permalink)
Holy moly man.... fly it with the 16T first and see if you need any more headspeed. I can't imagine needing more than what it'll do with the 16T!
Don't count on MSH releasing metal blade grips, they never did for the big Protos. There's nothing wrong with the plastic...
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 01-04-2011, 11:24 AM   #8 (permalink)
Default hi
i plan on running it with the 16 t first. and yea. i got the metal grips for the 500 from infinity hobby when the came out with them. dont trust plastic grips. never have and never will
Old 01-04-2011, 12:15 PM   #9 (permalink)
It all depends on the plastic. Align? Totally agree. MSH, Mikado, Miniature Aicraft? Plastic is fine.
Chris Boultinghouse
Old 01-04-2011, 12:30 PM   #10 (permalink)
+1
Msh plastic is reliable, no worries at all.
4cyclic is offline        Reply With Quote Quick reply to this message
Old 01-06-2011, 01:59 AM   #11 (permalink)
So far and only my opinion this little guy flies best around 3100 max, for best park it control and so fourth it seems to be the best balance rpm. For small tight stuff the higher HS makes judgement more difficult and takes away from the collective control and input precision.
Old 01-06-2011, 07:25 AM   #12 (permalink)
Interesting, I'll have to tach mine. I'm running 85% flat throttle on gov mode with stock pinion.
Old 01-06-2011, 08:54 AM   #13 (permalink)
Based on my tests yesterday, 85% on the stock setup is likely around 3500 rpm. Of course, it may vary depending on your radio but here's what I got at zero pitch using an optical tach pointed at the rotor:
65% = 2600
75% = 3050
85% = 3500
That was with a Turnigy 30c 2200 fresh off the charger.
Chris Boultinghouse
Old 01-06-2011, 06:13 PM   #14 (permalink)
Default hi
i just got my kit yesterday.. those plastic grips are beefy.
Old 01-06-2011, 06:56 PM   #15 (permalink)
65% = 2600
75% = 3050
85% = 3500
3500 @ 85%, hope it's less while flying.
Old 01-06-2011, 07:38 PM   #16 (permalink)
Yes. Yes they are.
I doubt I'll use that mode very often, if ever! I'm more of a low headspeed smooth aerobatics kind of guy.
Chris Boultinghouse
Old 01-12-2011, 09:14 AM   #17 (permalink)
Ya, agreed MSH plastics are good..After hundreds of flight only broke my blade grip today for the big brother because ESC cut out and drop. broke at the links side n strip the DS510 gears. First time ESC cut though.
I love the landing gear still my first set though I bought spare.
The plastics tail blade is also doing wonders stopping though so soft no CF needed.
I won't upgrade or change anything to metal. Plain Stock flies so well. Save my $ for the batteries give me more fly time or $ for good blades.
The only upgrade I thought of is the Scorpion 880kv to replace the stock MSH.
Just sharing..:-)
James Marcus is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 07:16 PM   #18 (permalink)
tached min last evening at 85% and gov on 10CHG produces 3200 hs with WR helitach.
Feels right at that rpm. Most 450pros were running 3400ish.
Old 06-06-2011, 01:26 AM   #19 (permalink)
Smile
Hi All,
If I use the HKii 2221-10 3000Kv, Is 15T ok at 80%?
Old 06-06-2011, 05:26 PM   #20 (permalink)
3900RPM for 200 flights
only thing i had to changed after 200 flight were the tail rotor grip bearings.
invertsick is offline        Reply With Quote Quick reply to this message
