Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
11-19-2013, 04:11 AM | #21 (permalink) |
Mine will be looking exactly the same as what Grant has above...In which heli I will reveal later, BUT if my kosmik smokes up in my new Heli, I'm probably going to make a lot of noise. I will be running a buffer pack for saftey purposes as well as the fuse holder and fan.
William Blake Team Kontronik TDR1, Banshee 850 # 22 Diabolo 700 |
11-19-2013, 07:40 AM | #22 (permalink) |
I would recommend (how thefrog has it) using linus's fuse holder for added mechanical support of the fuse.
Richard Zappe Team Kontronik USA PeakAircraft |
11-19-2013, 10:06 AM | #23 (permalink) | |
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
11-19-2013, 10:20 AM | #24 (permalink) | |
Looking forward to hear your comments.
11-19-2013, 10:28 AM | #25 (permalink) |
if there truly was a flaw in the design itself then they would all fail. now maybe part tolerance on the component level allows for a design to become a flaw in very rare cases but all of this is being investigated. The problem so far is that Kontronik has yet to be able to reproduce any of these failures under extensive testing.
11-19-2013, 10:43 AM | #26 (permalink) |
Richard,
Its human to make mistakes, i just hope that when the "flaw" becomes known that kontronik will share and fix at no cost! The service I have received since joining the K family has been fantastic. Im just nervous to put it in my "new" heli and become part of the senses. I got the buffer pack, the fuse holder and will be using the fuse so i really have brought all of the precautions, i just hope it enough
11-19-2013, 11:04 AM | #27 (permalink) |
Can you please elaborate on the "flaw" you are talking about with the Kosmik design? Are you talking about the screws holding the mounting tabs becoming loose and causing a short? I have been advocating for the longest time that people stripe across all screws on their helicopter with fingernail polish so they can visibly see if a screw has vibrated it's way loose. The same should be done on the top of the Kosmik to make it easy to visibly check if the screws holding the mounting tabs and the screws holding the case together have vibrated their way loose.
Avant RC Scorpion Power Systems ThunderPower RC Kontronik Drives |
11-19-2013, 11:23 AM | #28 (permalink) |
Im not a electrical engineer but what i can comment on is that the guy who let me know I actually trust as he is one very clever guy! Hope fully he will be able to comment on this or get in direct contact with you. We all love K and thats why we pay what we pay so im not trying to bad mouth any one here, im just asking that if there is a internal flaw that K will fix the items at little or no charge! Thanks for your point about fixing, will keep that in mind!
11-19-2013, 11:31 AM | #29 (permalink) | |
11-19-2013, 11:50 AM | #30 (permalink) | |
11-19-2013, 11:57 AM | #31 (permalink) |
What does Kontronik typically charge to have a Kosmik looked over? I figure if they open mine up and see anything suspect, they'll likely fix it rather than risking it catching on fire.
nothing wrong with mine that I know of, so it would be sent strictly as a prevention thing.
Rush 750 / JR 8917HV / MKS HBL980HV / Kosmik 160HV / Scorpion HK-4525-520 Ultimate / HC3SX / AR8000 / TM1000 Goblin 500 / Hitec HS-5245 / MKS DS760 / Talon 90 / Quantum 4115-1200 / HC3SX / AR8000 Blade 450X / mSR / mCPx / CX2 / |
11-19-2013, 11:57 AM | #32 (permalink) |
Thanks Richard, thats why we all support K
11-19-2013, 12:10 PM | #33 (permalink) | |
11-19-2013, 12:27 PM | #34 (permalink) | |
11-19-2013, 12:47 PM | #35 (permalink) |
I don't know who the birdie was. I don't know what he twittered.
Some visible things in a design may be suspected to cause problems, but only at the end of a successful investigation such a strange looking stuff could be called "design flaw" afterwards, - or not. Well, mostly you need much luck as manufacturer to be able to see the same symptoms as a user had to experience. The damn thing does not want to do a favor to go in the same way to the happy hunting grounds as it did with a user - and especially not if you try to provoke it. That all needs some time, but it also requires that you listen to everything that little bird chirping. All, you can do for now: - to use a buffer pack (respectively device ) for the R/C voltage - to use the fuse - to pray to the R/C God
Tom (j-log.eu) |
11-19-2013, 12:50 PM | #36 (permalink) |
I sent him a set in anticipation of his eventual aquisition, although last I heard he hadn't received them yet. They haven't arrived in Germany yet either, but everyone else got theirs.
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
11-19-2013, 01:29 PM | #37 (permalink) | |||||
Rest assured, knowing Sabine and Kontronik she would not be sleeping soundly if there was a known issue with the Kosmik. Kontronik as a brand is trusted the world over, not just by us hobbyists but by industry also. A little know fact is a vast part of Kontronik is industrial applications that are used in the automotive industry and the medical industry and the RC side is given every bit as much attention to detail as the components used in the medical industry. They will be all over the Kosmik checking and double checking making sure everything is perfect!! Use a buffer and fit the fuse as advised to limit the risk to yourself and your model
The difference between knowing your s**t and knowing you're s**t! Optipower - Kontronik Drives
11-19-2013, 01:34 PM | #38 (permalink) | |
11-19-2013, 11:19 PM | #39 (permalink) |
All this being said if i am correct in my assumption the fires only occured on the later firmware upgrades, initially we read about shutdowns now fires, maybe thats where the problem lies, Time will tell but personally i prefer the shutdown
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200 |
