Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 04-13-2014, 05:39 PM   #1 (permalink)
Default Blade 200 SRX Tx compatability?
So I downloaded the manual to check to see what the settings would be on my DX6i
http://www.bladehelis.com/ProdInfo/F...-Manual_EN.pdf
As far as I can tell, the DX6i isn't listed.
I won't be buying a new radio just to fly this.
Looking at the Bind-N-Fly site shows this...
http://www.bindnfly.com/#compatibility
This is indicating it would be compatible.
Never underestimate the predictability of stupidity!
Leadsled is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 07:51 PM   #2 (permalink)
The DX6i will fly it perfectly fine.
jadewarrior is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 06:01 AM   #3 (permalink)
Should be basic enough to figure out seeing as how its just a little fixed pitch heli. i couldn't imagine that any part of setting this bird is even remotely hard to do.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 08:21 AM   #4 (permalink)
Any of the Spektrum transmitters DX5e and "higher" will work though with the DX6i may have limited functionality. You don't need a computer transmitter, but it doesn't hurt anything either.
Most models equipped with SAFE, have 3 flight modes. The DX6i only has a two position flight mode switch, so it's a little more complicated to allow it to enter AS3X (no bank angle limit) mode but it is possible.
Zeal Rotor Blades
Team Horizon Hobby
Brian James is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 09:08 PM   #5 (permalink)
What are the chances of flying the 200 SRX with a Devo 7e/Deviation? Only two 2-position switches. Maybe the fine folks at deviation.com will figure it out.
HeliTree is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 11:12 PM   #6 (permalink)
You'd have to do some sort of Spektrum hack to make it work, but I've read that it can be done.
Old 04-15-2014, 05:55 PM   #7 (permalink)
I don't think the spektrum Rx in this is going to be any different than the dozen or so that are out now that deviation will bind to. You might have to run through a setup real quick to make sure it is all working properly first. It's not hard to learn and is a skill you will need sooner or later anyway if you move up past BnF helis or crash one.
Old 04-16-2014, 05:35 AM   #8 (permalink)
The Tx setup is Acro mode, I think for ease of safe mode switching. But like with the nano cpx, people will find a way to transfer it into heli mode.
The Tx is comes with looks just like what came with the SR! But for safe mode.
It's funny, HH didn't publish msrx settings either, had to create our own.
jaybyrd is offline        Reply With Quote Quick reply to this message
Old 04-16-2014, 09:56 AM   #9 (permalink)
Guys have made the DX6i work with DJI Naza .
I just remembered the Nano QX only came with ACRO settings. Took no time for some sweet HELI settings to appear.
Figuring this out should not be hard for the great minds on this forum (me excluded).
Seems like my concerns were unfounded!!
Old 05-09-2014, 12:11 PM   #10 (permalink)
3flight modes maybe you cn skip one of these? and the bail out mode... not sure what settings you would need. I have a DX7 Not dx7s I guess i could figure out programming. it do most things the dx7s will do
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 05-09-2014, 04:53 PM   #11 (permalink)
The 180QX uses the gear and mix switch to go between 3 modes on the DX6i. I am sure they will do the same for the 200.
snoopybeagle is offline        Reply With Quote Quick reply to this message
Old 05-18-2014, 08:11 PM   #12 (permalink)
Default (no bank angle limit) mode but it is possible.
I am very new to RC helis and I just recently purchased a DX6i and the 200 is in the mail!!
MY QUESTION IS HOW is this possible.
Thanks for your time
Ekim Sebor is offline        Reply With Quote Quick reply to this message
Old 05-24-2014, 07:24 AM   #13 (permalink)
I just posted my work-in-progress on the Deviation forums
http://www.deviationtx.com/forum/mod...e-200srx#23567
Chromose is offline        Reply With Quote Quick reply to this message
Old 05-25-2014, 10:19 AM   #14 (permalink)
You must have placed an order for it would be my best guess....
Heli-cat is offline        Reply With Quote Quick reply to this message
Old 05-25-2014, 05:20 PM   #15 (permalink)
Default dx6i has no 3 way switch
Sure glad I bought a dx6i in March since they told me it would work with the 200 SR x when I ordered it. IT DOES NOT! No 3 way switch on a dx6i and no way to add one with the circuitry it has, so I am told by hobbytown. Even Blade's sight says any DSMX transmitter will work but they fail to tell you only on a limited basis. NOT HAPPY, wouldn't have purchased the dx6i otherwise and am ticked that I spent $135.00 for a transmitter on their advice that doesn't fully work. Is this a regular thing in the RC world?
bilbowbone is offline        Reply With Quote Quick reply to this message
Old 05-25-2014, 08:12 PM   #16 (permalink)
It does work. Just takes a bit more effort.
https://www.helifreak.com/showthread.php?t=625083
Zeal Rotor Blades
Team Horizon Hobby
