Old 06-08-2014, 10:58 AM   #1 (permalink)
Default Just a quick heads up for those using the new Lynx Tail Rotor
I disassemble all assemblies and put them together myself before install.
If you're using this tail rotor, you should check this:
-The thrust bearings inside had no grease on them
-The thrust bearings were in the wrong orientation. Mine had the larger inner diameter thrust bearings toward the outside of the grips. They larger inner diameter should be toward the hub. Don't know if this was just a mistake on mine, but its worth checking.
-The radial bearings have loctite on the outer race, basically bonding them to the grips - this I don't understand because the tolerances are already tight enough.
-I cleaned all bolts in alcohol and there was a decent amount of machining residue that cameo off them which is a good thing, but you should get that off there before loctiting.
-I use red loctite on all rotating assemblies.
Just a heads up.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 06-08-2014, 11:01 AM   #2 (permalink)
How do you get the bearings out ?
Fooferdoggie is offline        Reply With Quote Quick reply to this message
Old 06-08-2014, 11:33 AM   #3 (permalink)
After I removed the spindle bolts, I cooked the tail rotor in the oven at 300 degrees for 15 min. Then used a driver and a pinion removal tool accessory to sort of pry the grip off the hub. You'll have to get a little creative. There was some excess loctite around the tip of the spindle preventing the grip from sliding off it, so you have to clean that up as best you can and just work at it little by little.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-08-2014, 03:12 PM   #4 (permalink)
Well that was fun.........
Ran into a pretty big issue. I think I read about others having this problem as well. I guess I'm one of those unlucky ones today. Installing my full Lynx tail (Arm, Pitch slider, and tail rotor) and run into this...........
As you can see, the machining on the arm is not symmetrical on the upper and lower section. The upper section sits high above the pitch slider, while the lower section actually makes contact with it, causing major major binding. It is not flyable like this. If you look at the two bolts where the pitch arm is attached, you can see the arm is fully seated and centered between the tail case fork so its simply a bad product it seems.
I know I read some having this issue and having to "modify" the arm to clear by fling it. I am not willing to make such a concession on a tail assembly I just spent $60 for. We'll see what happens now......
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-08-2014, 03:45 PM   #5 (permalink)
Lynx will tell you it's a defective plastic tail case moulding. I had the same issue, but with hot air gun and careful twisting you can get it perfect.
Actually I got brand new tail case halves and they did join perfectly. So their is some truth in what Lynx say.
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 06-08-2014, 03:58 PM   #6 (permalink)
I would believe that if I hadn't just taken off a stock assembly that was perfect and butter smooth.......My MiniP has never been involved in a crash and the tail case halves don't even have a mark on them.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-08-2014, 04:05 PM   #7 (permalink)
I was able to loose the bolt on that side and it was ok. Better with the lynx pitch slider. I had a new case on mine and it was still like that.
Old 06-08-2014, 06:17 PM   #8 (permalink)
sounds like a lot of work. but I bet this explained why I had way to may vibes with this hub when I was at 3000rpms.
Old 06-08-2014, 07:42 PM   #9 (permalink)
The hub has issues as well that I ran into but I can't test it to see for sure.
I just tried lightly heating the tail case forks with a heat gun to try and bend them down a couple mm so the lynx arm would clear. Let's just say my tail case is now no longer usable......
I'm done with this for now. I now have a bird that was flying that is now currently benched with an A arm that won't work and a ruined MSH tail case. Awesome.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-08-2014, 08:38 PM   #10 (permalink)
That sucks bro, hopefully you can get this sorted out asap sucks to be dwn .
Vbar Cont/Dx9 Align 600XN my first Nitro ! Original Goblin 500 stretched/Lynxed out Oxy2 now stretched and a few micros
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 12:28 AM   #11 (permalink)
so attempted to take the hub apart but one of the bolts on the grips the head broke off. the heat did not really help getting the bearings out I found a motor shaft for this bird was great for removing the bearings. but one of the shim washers got suck before I removed the bearings. it popped out broken then the bearings came out.
Old 06-09-2014, 01:01 AM   #12 (permalink)
I had same issue with my first one. I send a picture to Lynx and they send me a new one that's perfect.
njs77 is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 02:56 AM   #13 (permalink)
oww..I just push the trigger on the lynx tail pakcage. But I had sent an email to their service department about doing some pre-check before shipping the items. Hoping all are in working condition when I receive it later.
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 04:02 AM   #14 (permalink)
When you go get it sorted, it's a good upgrade.
I had already made my own thrusted tail grips, using stock parts
https://www.helifreak.com/showpost.p...2&postcount=21
So the pitch level and pitch slider were the parts I needed.
Old 06-09-2014, 05:15 AM   #15 (permalink)
Thanks the message in hf we made a quick check on the manuals just to be sure was corect and it is.
Than we open 3 set from our lx stock and we find grease and corect tb onstallation.
I request to disassembly all the miniprotos tail hub just to be sure 100% that the case signalated was just it.
I also open a service issue in my assembly room because I want discovery who made the mistake and why.
Thanks again for the information will for sure usefully in terms of quality.
Sent from my GT-I9500 using Tapatalk
Luca Invernizzi
Lynx Heli Innovations
OXY HELI
ininverno is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 09:49 AM   #16 (permalink)
Make sure they don't use too much loctite my bolt broke trying to remove it.
Old 06-18-2014, 12:41 PM   #17 (permalink)
DC flyer.. what are they doin for yours.. mine came and assembled just as yours did, and after reading this thread... I refuse to bench a flyable bird because of a faulty machined part. I sent a email with pictures detailing the problem to Luca and his service team, have yet to hear anything back.
Hoping this gets worked out because like you said I just spent 60 bucks and would like for it to work. I think I could make the thrusted tail work with the stock slider but, that's not why I bought it.
Dx7s, exi 450 pro(I swear it's a trex by now lol)
MSH Prôtos: 500 fbl,MSH Prôtos 450 fbl
Blackout 250
ZMR 250
Dazhim is offline        Reply With Quote Quick reply to this message
Old 06-18-2014, 09:00 PM   #18 (permalink)
Got mine yesterday but haven't made any inspection yet...a bit busy this week
Next project:
Old 06-18-2014, 10:49 PM   #19 (permalink)
Issue was just on few pc silver.
Was possible determinate who purchased the defective one and we already contact they for a replacement.
If you buy silver one but we dont contact you for a service replacement or if you buy red or black your part are ok.
Install it and try it.
If you want made mantenece PLEASE read the manual.
I suggest test first because we are sure ok. I personally recheck all stock and assembled more parts.
Remenber to reduce tail gain. Start reducing 5 point and test.
Any support need let me know.
Luca Lynx
Luca Invernizzi
OXY HELI
Old 08-09-2014, 10:59 AM   #20 (permalink)
Just wanted to give a quick update on the new Lynx tail assembly since I had trouble with some of Lynx's parts fitting the stock tail case. When the full Lynx tail case came out I grabbed one and was able to put the entire assembly together last night.
I'm happy to say that the entire assembly is pretty much perfect as far as fitment goes. I was able to put a couple flights on it this morning like this and compared to the all stock tail assembly the difference is quite huge. Its like i'm flying a mini Logo now.
Everything lined up perfectly, all the bolts that didn't require dis-assembly were well loctited from Lynx already. I basically just put it on. When everything is fully tightened down and seated there is ZERO binding and the assembly is absolutely butter smooth with ZERO slop....and I mean zero. This paired with a DS95i tail servo is an absolutely surgical tail now.
While I had the boom exposed I also added Lynx's new little pushrod support which helped tremendously to support and stiffen up the stock carbon rod. I don't know why the MSH rods have so much flex in them, but this little part certainly helped get the tail fully locked in.
Next on my desk waiting for install is the CNC idler pulley and Y-support from Lynx. All this extra weight pretty much necessitates more power so I planned for that and put in the 2520-1360 a while back. Good power, but the weak point is still the pinion which i'm hoping we'll have answer for soon.
Lastly, I found some nice turnbuckles from Midlandhelicopters that were the right size pushrod and weren't too big/bulky for the Mini. I know some were having problems finding some for this heli so I thought i'd mention that.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
