Old 08-18-2014, 07:26 AM   #1 (permalink)
Default Specs for 1300Kv motor?
Anyone come across specs for the 6S motor? Like number of poles, Khz setting. Just got one and on the can it says, MSH 40118 1300KV ... nothing more.
Assuming it is somewhere in the range of the Scorpion 2221 series motors, although there is no 1300Kv motor listed anywhere on the Scorpion site.
On the basis of this presumption, I will set it up at 6 poles and 8 Khz.
But it would be good to know for sure.
kb1846 is offline        Reply With Quote Quick reply to this message
Old 08-18-2014, 11:50 AM   #2 (permalink)
The 6s motor is 10 pole.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 08-29-2014, 06:21 AM   #3 (permalink)
Can I check about the other specs. Including the amps drawn?
[TDR 1x 800 1x Speed] [Prôtos Max V2] [Kasama Dune] [Outrage Fusion 50 6HV head] [Prôtos 500] [Outrage G5] [SAB Goblin 380] [Mini Prôtos (Stretched)] [Warp 360] [vWinRC 450T (Stretched)] [FBLs 3Sx, Spirit, vBar, BeastX; mCPX BL; DX9]
SN1975 is offline        Reply With Quote Quick reply to this message
Old 08-29-2014, 06:52 AM   #4 (permalink)
It's about a 600 watt motor. Amp ratings are not very helpful (and seemingly made up by the manufacturers), so I wouldn't put much stock in them. For the purposes of using it in a Mini Protos, the only vital bit of info is the pole count (for governor). Frequency (Khz) setting for any motor can be hit pretty close using this formula:
F = Motor Kv x Motor Pole Count x Nominal volts used / 20
Chris Boultinghouse
Old 08-29-2014, 04:53 PM   #5 (permalink)
Default Huh? Frequency calculation ...
That calculation applied to this motor [1300KV x 10 poles x 22.2V / 20] comes to 14,430 ... how does that work out? I have been advised it is 8kHz. Get my Protos gear from Ark RC in Melbourne, Oz. I have sent them a copy of the detailed specs from a similar motor on the Scorpion web site and Nate at Ark has sent that on to MSH with a request for them to provide similar detail on their motors. Now, as always ... we wait! MSH put out Scorpion motors under their own brand, but with the Mini Protos 6S 1300KV there is no Scorpion equivalent [nearest is a 1360KV], same apparently with the 880KV motor they put on the Protos 500. IF we get details on the motors, I will post them.
Old 08-29-2014, 06:00 PM   #6 (permalink)
Great thanks a lot bro.
This would indeed be very helpful.
Much appreciated.
Old 08-30-2014, 02:27 AM   #7 (permalink)
Is anyone think this motor is strong enough to do mild 3d with 3800 blades and decent rpm (i have one in stock for my new project).
SAB Goblin 380 / Xnova 2820-890kv / Yep 90Lv / Beastx v3 / Tgy 306g Hv / BK DS-5005HV
Blade Nano CP-X BL
Rcx 250
Spektrum DX9
michalss is offline        Reply With Quote Quick reply to this message
Old 08-30-2014, 03:23 PM   #8 (permalink)
That works out to 14kHz. The formula is a rule of thumb, you can try other settings and use what gives you the best balance of power, heat, and efficiency. You won't do any harm trying the various settings.
Chris Boultinghouse
Old 08-30-2014, 04:08 PM   #9 (permalink)
Good idea to play with pwm setting !
Blade Nano CP-X BL
Rcx 250
Spektrum DX9
