Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > FPV and Real time Video
FPV and Real time Video Discussions of receiving video in realtime from the aircraft
Old 09-16-2007, 04:48 AM   #1 (permalink)
Default 2.4 Downlink Cam Power Source
Anyone Run a 2.4 Downlink Cam direct from the Receiver Power Switch?
I am lookimng at doing this to save weight - but won't do it if could cause a problem.
KarbonBird is offline        Reply With Quote Quick reply to this message
Old 09-16-2007, 05:50 AM   #2 (permalink)
what's the camera's power requirements?
I am using a 900mhz trasmitter that requires 12v . so I am using a cheap small 1050mah LiPoly for the power.
R-4-L is offline        Reply With Quote Quick reply to this message
Old 09-16-2007, 07:51 AM   #3 (permalink)
Runs on 9V
Old 09-16-2007, 08:30 AM   #4 (permalink)
wrh
Default Use A DC-DC Converter
Try using a Dimension Engineering AnyVolt Micro Universal DC-DC Converter. This device takes a 2.4V - 14V input and produces a 2.4V - 14V output (adjustable with a potentiometer). At 9V output the converter can produce 500 ma, which should be sufficient for the camera that you are using (I have the same system). You can purchase the converter for US$19.99 at:
http://www.dimensionengineering.com/AnyVoltMicro.htm
wrh is offline        Reply With Quote Quick reply to this message
Old 09-16-2007, 04:30 PM   #5 (permalink)
You can run a 9v downlink directly off a 2S LiPo directly with no issues
Tony Stott
Trex 450 XL,JGF450TH,GY240 500e fuse, and Hubdave CF frame, JGF450TH,GY401, A109 fuse
1/4 scale hot-air balloon and Rokkaku/Sutton FF16 kites, Brooxes KAP rig, Olympus SP350s
13m Spiderbeam mast, Askman mount, A640, all above with 2.4Ghz downlink
Tonystott is offline        Reply With Quote Quick reply to this message
Old 10-27-2008, 03:54 PM   #6 (permalink)
FWIW, if you're running 5V video equipment like those from www.microwireless.com, www.rangevideo.com, a small ESC in parallel to the motor's ESC will do. Just run the video equipment off the servo wire that usually goes to the Rx.
This is what I've done with my FPV HBK2 with good results...
scrtsqrl is offline        Reply With Quote Quick reply to this message
