Old 09-29-2015, 04:25 AM   #61 (permalink)
Originally Posted by anthony1 View Post
i think you mean throttle curve not pitch curve , if I'm reading your abbreviations right , that is . it looks good because I wasn't using the gov , the next graph is without an alarm set but using the gov, not quite as good!
Anthony
=] I have corrected it now, as it isn't quite PC (politically correct) to call a throttle curve PC (a flat line come to that??!) when in fact it should read TC (throttley correct!)
Old 09-29-2015, 07:47 AM   #62 (permalink)
I have good news and bad news, I will start with the good news, it isn't the sk540 , the bad news is , it did it a couple of times today,
first flight , didn't miss a beat , great I thought let me have another go, second flight about 20 seconds in it slowed down briefly and then the rest of the flight was ok , the time it slowed seemed quicker , third flight it slowed down during spool up but then was ok for the rest of the flight , so now I'm thinking radio ...there isn't anything else left .
Anthony
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 09-29-2015, 09:57 AM   #63 (permalink)
=] get the log up Ant, it's odd the first flight worked ok, thereafter faltered? bet you thought we had cracked it?!!
Old 09-29-2015, 11:09 AM   #64 (permalink)
yes I did, just plugged it in and there is no log file, hmmmm. I checked in the software and its on playback so I don't know why there is no log file
Anthony
Anthony
Old 09-29-2015, 11:19 AM   #65 (permalink)
oh well I will just have to try it again
Anthony
Old 09-29-2015, 12:14 PM   #66 (permalink)
=] it's still unstable, and also odd because the 540 chip just over-writes itself, so there should be Something on it??
Old 09-29-2015, 12:53 PM   #67 (permalink)
it has the config file on it
Anthony
Old 09-29-2015, 01:07 PM   #68 (permalink)
=] that file is empty, doesn't contain anything, it can be deleted and will re-appear when usb-d....
Old 09-29-2015, 02:50 PM   #69 (permalink)
if I remember correctly I plugged my lcd in before the flight to check that the alarm was off ,then unplugged and flew, would that cause the log to not work for that flight?
Anthony
Anthony
Old 09-29-2015, 03:37 PM   #70 (permalink)
=] should have made no difference, maybe bench log a few times to check the capacity?
Old 09-30-2015, 04:58 AM   #71 (permalink)
Anthont
It doesn't look like your Tx Rx system, at least on the last few logs. It looks like something in the software.
You should get Art to have a look on it. Via Gergi should be a goid way
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 09-30-2015, 07:37 AM   #72 (permalink)
do you believe in mind over matter? , I had 3 flights this morning , none of them missed a beat , I did nothing differently the flights were back to back and everything was as it should be , I'm confused , maybe I just need to talk to my heli's , give them some moral support , I will of course let you know IF it happens again , but with the power of positive thinking I know it wont , (there isn't an emoticon for taking the p!$$ is there?)
Anthony
Anthony
Old 09-30-2015, 10:43 AM   #73 (permalink)
=] I didn't see any reason when you reported it was fixed on that first pack, but then misfired again?....
Perhaps me being PC, and Omer going abroad helped??!
Old 09-30-2015, 10:51 AM   #74 (permalink)
Returning tomorrow.. .
Old 09-30-2015, 11:53 AM   #75 (permalink)
=]. idle up 4 then.......
Old 09-30-2015, 02:43 PM   #76 (permalink)
maybe omer's proximity to florida helped to alleviate the problem , if he has moved out of psychic range of me maybe the problem will resurface , I will have to check tomorrow . nothing else has changed so that's the only possible theory, (or a software issue)
Anthony
Anthony
Old 10-01-2015, 07:32 AM   #77 (permalink)
3 more flights today without incident ,could it have fixed itself?
Anthony
Anthony
Old 10-01-2015, 10:03 AM   #78 (permalink)
=] I only have one more ace to play which is logging related, but surely it's looking ok?
Old 10-01-2015, 12:09 PM   #79 (permalink)
I'm happy with it atm. I'm going to keep flying it and see if it happens again, until then I believe its case closed(for now)
Anthony
Anthony
Old 10-01-2015, 08:33 PM   #80 (permalink)
so I thought I would see if there is a log to upload just to see if you could see any difference, but again there is no log, I have checked the software and it is set to playback , i'm a bit reluctant to change it as the heli is behaving itself , but I think that this could be the route of my problem, if I do change it and it starts misbehaving is there a way to get back to where I am now?
Anthony
Anthony
