Brand Specific Charger and Battery Support Brand Specific Charger and Battery Support |
12-17-2012, 12:11 PM | #21 (permalink) |
Will the pro-orders go out today?
Bunch of Planks, DX18, over-inflated sense of self worth! Helis I've had: Trex 500, Compass 500, MCPX, Nano CPX |
12-17-2012, 12:14 PM | #22 (permalink) |
Yup
LAHeli - Mikado - Henseleit - FASST
Powered by ProgressiveRC & Spyder Batteries |
02-10-2013, 09:38 PM | #23 (permalink) |
What is the latest firmware release version for the iCharger 4010duo? ProgressiveRC shows a version of 3.14 with a date of Dec, 2010. I am hoping that the latest charger does not have or use a 2 year old firmware. So, where do I get and confirm the latest release?
Trex-450 | Trex-550e | Trex-600e Pro | Trex-700e | Custom Multirotor | Citizen 29 |
02-10-2013, 09:40 PM | #24 (permalink) |
For the last firmware Junsi is giving support in this link. http://www.rcgroups.com/forums/showthread.php?t=1801512
Mikado Logo 800XXtreme, Vbar 5.3, 813mm Edge Blades, 14S Kontronik Cool Kosmik 200HV. ALIGN T-REX 550E DFC with 600 Boom, 603mm Edge Blades, Kontronik Heli Jive 120HV, Pyro 600-12, Mini Vbar 5.3 Pro, V3 Tail, Black Gears, Many KDE Upgrades. |
02-10-2013, 10:42 PM | #25 (permalink) | |
The date is a type-O. The charger was released toward the end of 2012. Try the link above for the latest firmware. |
02-10-2013, 10:47 PM | #26 (permalink) |
The very first post its current. The Firmware is the current one.
"Last edited by junsi; Feb 04, 2013 at 12:34 AM"
02-10-2013, 11:07 PM | #27 (permalink) |
I just set mine up to run off of a 48 v golf cart. I made three videos of it as an introduction to this power house. I am very impressed with mine so far. Perhaps I should do a video on accessing the menus and features.
Link if anyone is interested... [ame]http://www.youtube.com/watch?v=F9jUzT4l0vs[/ame] |
02-11-2013, 11:32 AM | #28 (permalink) |
Nice video. That is 4C each battery. I don't like charge that fast unless that is a Thunder Power 12C charging Rated.
Usually the 5C batteries are overrated. at the field i don't like charge more than 2.5C-3C At home 1C is perfect. No rush.
02-11-2013, 11:33 AM | #29 (permalink) |
Check mine with parallel boards.
02-11-2013, 04:08 PM | #30 (permalink) |
Re: iCharger 4010DUO
Where do you get the parallel boards?
Sent from my Galaxy Nexus using Tapatalk 2 |
02-11-2013, 04:26 PM | #31 (permalink) |
To me those take up WAY too much room... I just use the squid cables.
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles |
02-11-2013, 04:38 PM | #32 (permalink) |
Me too, Slyster. I just wanted to know where he got 'em.
02-11-2013, 04:41 PM | #33 (permalink) |
I actually like them, looks more organized.
I think I'll be ordering this charger soon. What's a good power supply to go with it?
http://www.facebook.com/RC.HangarTime |
02-11-2013, 04:43 PM | #34 (permalink) |
Deep cycles for field... for home charging I bought the Feathermerchant 24V47A.... it will power the charger fine.. but not too it's full capacity... but good enough.
Scroll to bottom www.feathermerchantrc.com
02-11-2013, 04:45 PM | #35 (permalink) |
I went with two PowerMax PM3-75 from progressiverc, but Fishjunky can hook you up with some server power supplies. I'm planning to get some deep cycles for field charging later this spring.
02-11-2013, 04:50 PM | #36 (permalink) |
Voltage is key! you are severely limited by 12-13V. Deep cycles have no amp limits so they are the best power source.. I usually use dual deep cycles and may go with 3... of course puling 50-60A out of them won't go easy on them.. but mine have 2 year full replacement.
02-11-2013, 04:50 PM | #37 (permalink) |
I'm going with a generator, no need for deep cycles
02-11-2013, 04:51 PM | #38 (permalink) |
So you want the feathermerchant 24V setup.. or ideally 2 of them for 48V
02-11-2013, 05:32 PM | #39 (permalink) |
If you are referring to my setup, I did not purchase it for the 4010. I got it for my two 306Bs. If I were to get a 4010, I would not be getting it for fast charging purposes. Rather it would just reduce the clutter at my charging station. Because I mainly have Turnigy batteries, I would still be charging all 12 batteries for my Fusion at 1C. My setup works fine for that arrangement.
02-11-2013, 07:41 PM | #40 (permalink) | |
http://www.progressiverc.com/fma-uni...or-jst-xh.html Check the link on top. It came without connectors. I decide use the EC5 but you can use bullets and change the connector at your convenience. I like the idea of the 40Amps fuse for any emergency or short circuit. :-)
