Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
07-04-2013, 11:49 PM | #161 (permalink) | |
wis1
Trex 600N Pro,YS56, BeastX, Goblin 630C SK540, GAUI X5 FES SK540 http://www.swarmheli.com |
07-05-2013, 07:18 PM | #162 (permalink) |
I will try changing the ramp rate, I know that the speed sensor is working.
07-06-2013, 03:37 AM | #163 (permalink) |
my GOV is working great but the tail is horrible.
gone try replacing servo next
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
07-06-2013, 07:52 AM | #164 (permalink) |
I run a Hobbywing esc and after updating to 3.40 the gov quit working. For me the fix was to change the Overdrive setting from 100 to 0. Try that.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo #nodroneshere - 104 |
07-06-2013, 10:18 AM | #165 (permalink) |
I tried everything, I guess for me was just leave well enough alone. It work fine with trottle curve. I guess I will have to run it that way until I can fine a fix are replacement.
07-08-2013, 02:02 PM | #167 (permalink) |
Well I upgraded to 3.40 over the weekend and have now had 10 trouble free flights over the past two days. It's definitely an improvement and the bounce is now gone on my 700E DFC.
Now to try and get the Skookum Governor working rather than using the YEP's one |
07-08-2013, 04:16 PM | #168 (permalink) |
Rev 3.40 is up
I just noticed that throttle is not being logged by the SK-720
Don't know why... Maybe because I'm coming into the SK using PPM? But the other channels are logged fine... I doubt that it's been turned off in 3.40. |
07-09-2013, 03:58 AM | #169 (permalink) |
played with logging
Hi, just enabled playback logging and was able to plot throttle? i am however not using ppm
250 vbar| 450 Sport vbar| 450 PRO sk720| Compass Warp360 sk720| KSM Dune sk720be+GPS| KSM Srimok 90n sk720 |
07-10-2013, 12:19 AM | #170 (permalink) |
Gov back on track. thksfor the help.
07-10-2013, 09:12 AM | #171 (permalink) |
changed my dampers on the Trex600 from original to trueblood - elevator bounce is gone.
had tail issues (hunting with low gain) - found that both boom braces had one loose end. fixed that yesterday. hope to test soon.
07-10-2013, 09:30 AM | #172 (permalink) |
Rev 3.40 is up
Just confirmed with another SK-user.
No throttle is being logged when using PPM. Hopefully this is just an oversight and there are no other hidden or undiscovered issues when using PPM... |
07-10-2013, 11:26 AM | #173 (permalink) |
Hi, I just got a brand new SK540 loaded with 3.40.
Does anyone get an error state while powering up? (LED = Red light flashing rapidly) The PC software says Sensor A and Sensor B error. But if I cycle the power repeatedly (5 or 6 times) it will start up right. (LED = Red solid then Green solid) I have asked Art about this problem and he said it was due to an extra check on the USB connection during startup. But he did not say whether it is safe to use it. I want to know how many of you are facing this problem. Thank you |
07-10-2013, 11:30 AM | #174 (permalink) | |
I confirmed on my 3 SK-720's running 3.40 that the Throttle option is always grayed out in the menu. I can't guarantee that the throttle information isn't included in the log, but the Log Viewer software does not allow me to select Throttle in order to see throttle values on the graph. Since the log format is proprietary I can not verify what the contents are.
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
07-10-2013, 11:42 AM | #175 (permalink) | |
07-10-2013, 12:12 PM | #176 (permalink) | |
Team Synergy Field Rep, Rail Blades |
07-10-2013, 12:32 PM | #177 (permalink) |
Yes, when the LED is flashing RED, the sensor is still working properly in all directions.
So, it is a GO! Hope they will fix this soon. Guruduck |
07-10-2013, 12:35 PM | #178 (permalink) |
Yeah, he said that some units that take a few milliseconds longer to boot and throw that error. He did also say they'd be fixing it in an update very soon.
07-12-2013, 01:06 PM | #179 (permalink) |
mr Rigid helped me with the update to 3.40.
And after a couple of testflights, I ended up with a very good flying heli. Tailgains about 10% higher, dampinggain on elevator up to 16. And no wobble! Very good Skookum!
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV Quad 250 : Openpilot CC3D |
