Old 10-18-2014, 05:38 AM   #1 (permalink)
Default Trex700e hv dfc: what rx batt. do you use?
Hi Guys, what brand and type of rx batt are you using? I,m currently on Gens ace 4000mAh 2s1p but it can not hold the current peaks so i had to remove the electronics from the battery.
Other brands are to big when mounting the canopy. They are to long.
Thx.
Olivier
_____________________________
Mini Titan | Trex 700L DFC HV Dominator Gpro Sbus
Trex 450 Sport | Futaba T8FG
Traxx is offline        Reply With Quote Quick reply to this message
Old 10-18-2014, 11:40 AM   #2 (permalink)
2s 4000 gens at only 10c is 40A. I don't think your battery should be the issue. Or if it is, then the pack may have problems.
What ga. are your leads? Where are your battery connections? (Rx, fbl?). Make sure you have at least 2 separate high quality battery leads and that you are feeding directly to the bus with your servos plugged in.
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 10-18-2014, 12:14 PM   #3 (permalink)
Ok I have a Trex 700 V2 still on the box. I currently fly my 600's with 6S 4000 Mah batteries in 12 S setup. I fly scale to gentle sport and get 7 min flights with 3,8 V per cell when I land. Can I use the same batteries for the 700 as well?
Gh
goodhunting is offline        Reply With Quote Quick reply to this message
Old 10-18-2014, 05:19 PM   #4 (permalink)
Yes you can fly with 600 lipos. But 2*4000mah in 700 class. 4000lipos are light and maybe a nice flied 700 but not 7 minutes in the air. I have 600e pro heli so i am gonna make a test. Current sensor works great with vbar control so.
338federal is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 01:31 AM   #5 (permalink)
Originally Posted by Traxx View Post
Hi Guys, what brand and type of rx batt are you using? I,m currently on Gens ace 4000mAh .
Rx battery or flight battery? A pair of decent 6S 5000's would be the typical setup for the esc/motor. For the RX battery, I am using the Hobico 2S LiFe 2100
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX
rhodesengr is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 10:42 AM   #6 (permalink)
5000are the typical battery for a 700 but I think I am going to run 4500s. For my Rx pack I am going to run a pulse 2s 2600 may Rx pack.
Goblin 500: Kontronik Jive, Kontronik Pyro, MKS, Pulse, Mini Vbar
Goblin 700:Xnova, Yge, BK, Pulse, Ikon
All flown By a Spektrum Dx7 gen 1, and A Spektrum Dx9
Team Helidirect
Helis4Life77 is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 01:31 PM   #7 (permalink)
Hi, maybe some clarification:
I use tyhe Gens ace 4000mAh 7.4V Rx (see http://www.gensace.de/lipo-battery/t...tery-pack.html)
The problem is that the max cont current is 4A and the burst is 8A.
When all servo's are doing moderate action the current go's over this 8A and the electronics inside the batt.cut the power. I noticed it on the ground when initializing.
So now I'm curious to see what type and brand you are using because the canopy is close to the RX batt.
Olivier
Old 10-19-2014, 02:03 PM   #8 (permalink)
Hi, I am using a Turnigy NanoTech 2000mAh/2S/20C LiPo straight into the VBar. No issues since day one.
STAZZ is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 05:18 PM   #9 (permalink)
hmmm, I don't know about all that. First, 4000 mAh is pretty enormous for an RX battery. I use 2100 on mine , even my 700 gassers that fly for 10 minutes. I use about 2 amp average over a flight and that is running five servos.
Second, I seriously doubt you have any electronics in your battery let alone electronics that turn off the battery. If your electronics are cutting out, either the battery is just crap or you have another problem.
Third, the battery label says 5C which on a 4000mAh battery suggests a constant rate of 20 amps, yet the listed ratings are 4 continuous and 8 peak. So something is funky there.
Either try another battery, or you can also add some capacitors across the battery. They can help supply surge current. Hobby King the pretty cheap or you can make your own.
https://www.hobbyking.com/hobbyking/...dProduct=42429
This is the actual battery I have been using
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDVCC
It is LiFe and LiPo so the voltage is a little lower.
Old 10-20-2014, 11:56 AM   #10 (permalink)
http://www.hobbypartz.com/98p-4000-2s1p-2222-rx.html
Same pack, different site. Peak is shown as 40a here.
Everything rhodesengr said is spot on. And again, check the setup! You can't run just one, or small ga. leads.
AMA 373608
Old 10-20-2014, 02:09 PM   #11 (permalink)
Exclamation
I tried 2 other packs, same problem. After contact with supplier the Max amp is 8 A. Now we removed the small electronics part inside the battery and it works without any problems.
I am looking now for other brands because i lost faith in these pacs. The main batt. (5000mAh) from gens are performing perfect. One thing that i found strange from the beginning with the rx batt was the fact that the leads were only 0.5mm...
Olivier
Old 10-20-2014, 02:23 PM   #12 (permalink)
Could you post a pic of what you removed?
AMA 373608
Old 10-20-2014, 07:27 PM   #13 (permalink)
Default rx batt
the pulse 2s 5000 is not very big,actually smaller than the 2s 3600 lifesource
7HV,Trex 700N,Suzi Janis 800,500 DFC ,NX4 Warp,all on HC3SX, 230s
mmracecars is offline        Reply With Quote Quick reply to this message
Old 10-21-2014, 05:45 AM   #14 (permalink)
I use the same battery. Easier to take care of than a LiPo RX pack. I use only three flights per charge. They appear to support at least five flights per charge. These packs fit the RX battery tray and clear the canopy, no problems.
Use both servo leads, or better yet the deans connector, to provide power to your RX or FBL.
LizardMan is offline        Reply With Quote Quick reply to this message
Old 10-21-2014, 04:31 PM   #15 (permalink)
here is what I do. i cut off the Deans and put on an EC3 mainly because all my charge cables are EC3. Then I take a male to male servo cable, fold it in half and attach the mating EC3 at the fold. The EC3 connectors are my power switch and I have two power outputs. In my setups (BD3SX with a full Spektrum AR series RX) I plug one into the 3SX and one into the RX. Some current can back feed through the cable loom.
Old 10-22-2014, 01:13 AM   #16 (permalink)
I use a 1500 2s gens ace. No issues.
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote Quick reply to this message
Old 10-22-2014, 10:25 AM   #17 (permalink)
Nano-tech 2250 mah 65-130c discharge. I use an Ec3 on the battery and then a Ec3 to a servo plug Y connector and put both servo connections on the HC3sX I'm using. That's with all HV servos and two sats. I can get at least 4 flights and probably more, but with two helis at the field and 8 flights, I need a break lol.
ranchhand is offline        Reply With Quote Quick reply to this message
Old 10-25-2014, 07:08 AM   #18 (permalink)
I use pulse 6s 5000 45c&65c and a pukse 2s 5000 RX pack. All work flawless.
Trex700ProDFCHV,Goblin 770,Goblin 570, 14SGH
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 10-25-2014, 08:36 AM   #19 (permalink)
Pulse 2s2550 LiPo and Hyperion 2s2100 LiFe -- never an issue with either one.
700L SXTS Neo | Goblin 700 KSE Neo | Goblin 380 KSE miniVBar | Nano QX
rando is offline        Reply With Quote Quick reply to this message
Old 11-05-2014, 10:25 AM   #20 (permalink)
I will try to post the picture of the removed electronics tomorrow.
Olivier
