Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
06-09-2006, 10:16 AM | #61 (permalink) |
C'mon ... not having a card reader isn't a problem, it's an excuse!!! 14MZ owners didn't get card readers with their radios, yet when it came out, model files were easily available. Card readers are relatively cheap and widely available. IF you own one of these radios, you need to get yourself a CF card and reader. :mrgreen:
07-02-2006, 02:19 PM | #64 (permalink) |
linkage comp. inop.
I was one of the 12Z owners that complained that my linkage compensation adjustment did not appear to work. Well, I finally got around to rerigging my Cal 30 Eccpm and now the adjustment works. The changes I made in the setup were very minor, swash mix and pitch range, but the compensation now works.
One thing that I still don't understand is the asymetrical pitch travel. Starting with the servos locked neutral, blades at 0 pitch, bellcranks perpendicular, linkage lengths equal, and servo arms at 90 degrees, I ended up with 11 degrees positive and 7 degrees negative pitch. I fudged the servo neutral and extended the pitch curve negative side below -100 and clipped the positive side slightly short of +100. After doing this, the interaction adjustments were very minor, some requiring no tweaking at all, but all the adjustments did have an effect. Now I'm not saying that the basic setup is what I would really expect or like to see, but that it all worked out. The model flies much better than before. One of the earlier posts elluded to the possibility that in those setups that the linkage compansation did not work, it could be a combination of swash mix, throw. etc. Maybe it is. Now I'll see about the Stratus. Jim |
07-03-2006, 07:09 AM | #65 (permalink) |
Check the position of the bell/hiller mixer and set it so the bell side (the long link from the swash) is at 90 degrees to the swash rod. I've found the same thing you did in my fury tempest and after making this change (and before I went into swash detail) the +-pitch was was the same value.
Unfortunately, after cranking in a lot of link compensation the problem with uneven travel comes back. Even the collective roll and ele will not be even. I checked this both with the swash leveling tool and pitch on the blade angles. So as the solution I used the independent AFRs to get even values. With unmatched older servos this is a typical problem. Chuckie
Clint Akins |
07-03-2006, 07:26 AM | #66 (permalink) |
Chuck--- My Stratus worked out about the same as your Tempest and I also used the AFRs to get the values correct. The Cal 30 neede this also.
Jim |
07-16-2006, 09:03 AM | #67 (permalink) |
hi , I got 12z a few day ago and upon set it up on my stratus ,
the "low pitch "in the linkage compensation DOES NOT work at all the"high pitch" linkage compensation works fine. can anyone comfirm the update will help solve this problem? or what else I have to do to have this function works, thanks a lot |
07-16-2006, 09:15 AM | #68 (permalink) |
Many posts about the issue found in this section of HF, you may want to do a search for further reading.
Update doesn't seem to do anything to help in this matter. Some people are having this problem, other are not. Some that have had the problem, suddenly stop having them. Futaba/Hobbico is aware and supposed to be looking at this issue, however no word has been provided (after several months). |
07-16-2006, 09:42 AM | #69 (permalink) |
thanks for fast reply , i'll hang on my shirt... :glasses2:
07-17-2006, 06:27 PM | #70 (permalink) |
notsip mine started working but only on one model. If you have card reader i can have a freind of mine email it to you as my reader does not work.
Radikal G20 Ion Powered DX7 Infina Models ION Batteries.Transmitter and Receiver Lithuim Ion Dual Pack For Radikal |
07-17-2006, 06:29 PM | #71 (permalink) |
I guess there are more having this and other issues as I have gotten a few pms and emails concerning this issue. Not sure why mine started working on the one model, try making a new model and see what happens.
07-17-2006, 06:44 PM | #72 (permalink) |
thanks a lot Rodney, I do have card reader and compact flash card,
please have your freind send it to edit thanks again |
07-17-2006, 08:36 PM | #73 (permalink) |
Only CompactFlash cards will work! Stay with non-Ultra, non-high speed CF cards (CF type I) from known vendors like Corsair, Kingston, PNY, Samsung, etc.
07-22-2006, 12:50 AM | #74 (permalink) |
Hi , I just install update 07-21-06 from RCfan website into my 12z and
re-check the "low pitch" in the linkage compensation menu , it WORKS fine WITHOUT changing anything . Big thank to RCfan. You are the man... |
07-22-2006, 12:53 AM | #75 (permalink) |
Futaba deserves the thanks, not me. I'm just making sure everyone has access to the info.
07-22-2006, 05:10 AM | #76 (permalink) |
Man, I have got to get a card reader and a card
07-22-2006, 06:53 AM | #77 (permalink) |
Notsip,
Check on the information menu in the 12Z and tell us what the menu page says. It is the System menu, then scroll down to Information. Should see this: Editor / Encoder V. 1. 0. 4 / V. 1.31 David |
07-22-2006, 07:51 AM | #78 (permalink) |
Hi David , I just check on the info menu and YES it is :
Editor / Encoder : V . 1. 0. 4 / V . 1. 31 before update it is something like :v.1.0.2/v.1.24 if I my memory serve. now both side high and low pitch Works fine . Thanks RCfan again... |
