Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 11-21-2010, 12:37 PM   #1 (permalink)
Default Extra 300 with gyro?
Has anybody seen or heard of installing an Align 3g 3 axis gyro system in a 3D plane. I have read about installing 3 separate gyro's but am wondering if it's been done before.
I am currently building an Extra 300 32e from Eflite and have a 3g system to try.
Machinistdude is offline        Reply With Quote Quick reply to this message
Old 11-22-2010, 10:30 AM   #2 (permalink)
If you can set it to operate 90 deg (like mechanical ccpm), you could conceivably try it. I'm not sure I would test it on a balsa plane since you can't really set the gains without flying it, do you have any foamies that you could test it in first?
Ace4 is offline        Reply With Quote Quick reply to this message
Old 11-22-2010, 11:12 AM   #3 (permalink)
I don't have any foamies but I have an old Biplane that I can sacrifice as an experiment.
Old 11-23-2010, 12:21 PM   #4 (permalink)
Don't have much knowledge to offer but I would turn the gain way down and set it to a switch at first and then dial it up, could get outta hand fast and a switch could be the difference between a failed test and a totalled airplane testing a gyro.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 11-23-2010, 11:35 PM   #5 (permalink)
When gyros are used in a airplane they have to rate gyros. Heading hold gyros do not work. Back some years ago a turbine jet had a Rate/Heading Hold gyro on the rudder when they switched it in to heading hold it did not let the tail weathervane and caused all sorts of problems.
Paul
Paul Hinz is offline        Reply With Quote Quick reply to this message
Old 11-24-2010, 07:50 PM   #6 (permalink)
If I've figured correctly the 3g is rate mode on elevator and aileron as it centers itself no matter what the orientation is and the rudder can be set to rate mode only. I'll check this out before I fly and I will set the gains near the bottom of travel. If I turn them off completely the servos won't function.
Old 01-03-2011, 06:50 PM   #7 (permalink)
Just got back from my maiden flight on the 300. For the first try with a gyo I went with an align 780 running 5% in rate mode on the rudder only.
The plane took off and landed dead straight (4 times) with no rudder input from me, in a small cross wind (runway is quite narrow and the wind doesn't usually flow that way). Rolls were very linear and knife edge was almost too easy. The only thing I have to get used to is using the rudder to assist in sharp turns as the plane wants to stay on axis. I tried a little hovering but the cold weather really put a damper on my flight times, that and ice build up on the wings.
Next I will try to install a 3G from my Trex 500 and see what happens.
