Old 05-27-2011, 05:15 AM   #1 (permalink)
Default Tail assembly question
Almost done with my build, but I have a little problem with tail being a bit tight.
It''s bit odd as I can make it smooth by rotating the wheel on tail pitch slider (the one which two special screws from tail pitch lever go into), but it's only one position where it works well - is this normal? Also, when I move tail pitch slider back and forth a couple of times, it eventually aligns itself and tail becomes quite smooth. I am just worried it will not stay that way during flight.
I have checked everything (tail shaft polished, smooth as butter), pitch lever rotating freely etc. I have sanded tail pitch lever in places where it makes contact with pitch slider, it helped a bit.
Any suggestions/ideas?
Thanks!
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 05-29-2011, 12:16 AM   #2 (permalink)
Did you align the special screws with the provided spacer?
it should be smooth as silk.
invertsick is offline        Reply With Quote Quick reply to this message
Old 05-29-2011, 02:55 AM   #3 (permalink)
Yes, I did.
It is smooth, but only in certain positions of the "wheel" - the one which these screws go in.
I'll check again today.
TDR/VBar
Logo 600SX 12s VBar
Old 05-29-2011, 10:22 AM   #4 (permalink)
Re-checked everything very carefully, it's still doing the same - it is silky smooth at certain positions of the wheel, on others it's not. Screws are perfectly aligned using spacer. I don't really know what else I can do.
TDR/VBar
Logo 600SX 12s VBar
Old 05-29-2011, 04:14 PM   #5 (permalink)
If i get your issue correctly, I would check that the arms on the pitch lever are perfectly aligned. You can try to pull out a bit (or remove ) the two screws that guide the wheel and see if it improves.
ziper_it is offline        Reply With Quote Quick reply to this message
Old 05-29-2011, 05:10 PM   #6 (permalink)
I've tried that (pulling off the screws) it does improve it, but it doesn't fix it. I may try replacing the arm, there is one in spare bag. Thanks for the suggestion.
TDR/VBar
Logo 600SX 12s VBar
