Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 08-08-2016, 07:29 PM   #1 (permalink)
Default What is jlog?
I was talking about getting a mui sensor for my heli to work with my jeti transmitter and I got a response, why do you use a jlog? I have no idea what a jlog is so I'm sorry for my ignorance.
Can some give me a quick run down on what it is and it's applications?
I have 3 heli's with Kontronik Kosmiks
HELIDIRECT - HOBBYWING - XNOVA - XPERT - PULSE - ROTOR TECH
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 12:22 AM   #2 (permalink)
Jlog acts as an interface between the ESC and the transmitter. I use general terms because it works with many ESCs and many transmitters.
In the case of Kosmik, it will provide all the telemetry data that the Kosmik puts out including voltages and currents for pack and BEC, mAh consumed, RPM, and more temps etc...
On the transmitter side its compatible with Jeti, Graupner, JR, Futaba and some others as well.
It has a bit of a learning curve, but that is simply because it is soooo versatile and so compatible with so many system.
But I would say it is one of the coolest little devices in this hobby.
Also it's creator, Tom (dl7uae) is a super guy that is on her all the time and does great support for his product.
Current hardward is Jlog 2.6 and he is working on Jlog 3. There is a thread on Jlog 3, whats new and when to expect it.
A\ziz - Citizen 672
Minicopter Diabolo 700 Black, SAB Kraken 700, Kraken 580, Minicopter Diabolo 600, Minicopter Diabolo 550, Henseleit TDR Mark II, Henseleit TDR
Jeti DS24 / VControl Touch
aziz76 is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 12:33 AM   #3 (permalink)
Here is a link on the HF forum for further info.
https://www.helifreak.com/showthread.php?t=716255
To add, the UI sensor is limited in terms of info compared to the JLog.
Also, with UI you need to add another connection within your power system and thus another potential point of failure or losses.
allen james is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 12:41 AM   #4 (permalink)
There's a Jeti TelMe module also...
http://www.kontronik.com/produkte/zubehoer/regler/produkte-rc-modellbauzubehoerreglertelme/telme-jeti.html
But i don't know jeti accessories well. So, an adapter may be needed to use telme with jeti transmitter.
Rasim Ozturk
[Prôtos Max V2][Prôtos 380 Evo][OXY3 GL][Vbar Neo][Vbar Control]
rasheem is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 01:02 AM   #5 (permalink)
If you're running Kontronik, the Jlog will be a much cleaner install than a MUI sensor, and also means you don't need to solder in extra connections between your ESC and battery.
And on top of that you get telemetry to monitor things like ESC temp, etc. And it can log all the data for you if you wish.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 08-09-2016, 02:46 PM   #6 (permalink)
Wow thanks guys for all the information, so glad someone mentioned this before I purchased a mui sensor. Seems the jlog is the superior choice
Old 08-09-2016, 05:41 PM   #7 (permalink)
I only use the MUI sensor when I have no other choice.
The cleanest Jeti telemetry install is using a Jeti Mezon ESC, but the Mezon's have had too many reported failures on 12S to, so not the most reliable ESC for larger helis. Also, the Mezon governor performs about the same as the Castle's, so you would most probably want to use the FBL unit governor with the Mezon (and Castle).
For Kontronik Kosmik ESC's, the TelMe units seem to be a much easier plug-and-play option compared to the JLog 2.6, but they come at a high price. The JLog's are only $70, and they work on multiple ESC's and transmitters. The Kontronik TelMe units are more expensive at $86.90, only work on Kontronik ESC's (not sure if it works on JIVEs, but the JLog 2.6 works for sure on both Kosmik and JIVE ESC's), and are transmitter brand specific.
The JLog's do not currently read some of the parameters (BEC voltage, BEC current, BEC temp., etc.), so you would have to access that data via the Kontronik microSD card log if you are interested in those parameters. However, the JLog as a cool function that lets you adjust the displayed mah consumption to match the mah charged back by the charger.
The JLog's have suffered from compatibility issues whenever new Kosmik firmwares are released, but Tomas has been very diligent and expedient in updating the JLog's to keep up with Kontronik's cat and mouse game.
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
jhamel is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 02:35 PM   #8 (permalink)
JLOG and Telme are advertised as logging units. To me, "logging" means various conditions are stored for review after the flight. I've never been clear on this........can either a Futaba or Jeti transmitter be set up to use the output of JLOG/Telme during flight to notify the flyer that the heli has consumed 80% of the pack and it's time to land? In other words, can JLOG/Telme units provide real time event notification to the pilot or must you land to review what has occurred during the flight?
Mike
Protos Evo 700: Goblin 700C : Diabolo 700 SE: Oxy 5 Meg: Goblin 570 : Diabolo 600 : Mini Comet : Oxy 2 : Futaba 18SZ : Jeti DS-16 : Jeti DS-24 : Kontronik Kosmik, Jive Pro and Kolibri: Scorpion Tribunus: MSH Brain 2 : BK Brushless : Xpert R1 and KD
MKMAERO is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 04:34 PM   #9 (permalink)
Jlog is available in two versions, GW which functions as a telemetry gateway, and the Full version which adds on board logging capability and also supports sensors such as the CVS16. Both versions will calculate mah used so that it can be displayed in some form (dependent on your radio system) on your TX. Some radios such as Jeti have their own internal logging capability which can be used to review data after a flight. Alarms can also be set based on real time data.
Vertical Flight Technology Inc.
Distributor: bavarianDEMON - DryFluids
AeroPanda LLC
Distributor: soXos Helicopter
F1 Rocket is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 07:19 PM   #10 (permalink)
I do have a Jeti DS16 so it appears I can use JLOG to notify me that the heli has reached 80% lipo consumption and it's time to land. Thanks for the clarification.
Mike
Old 08-11-2016, 02:27 AM   #11 (permalink)
Mike
Indeed. The Jlog GW will already make this possible. On the Jeti you can then also review the logs of all telemetry data received.
However the sample rate of the data stored on the tx is much lower than on the logging version of the Jlog. I only use the Jeti logs for very quick review of for instance rpm and pwm.
For battery current data (amp spikes) and detailed pwm/rpm behaviour it is much better to take the Jlog logging version or just the Kosmik logs.
I have the logging version of the Jlog myself but only because I also use the CVS16 so I can review individual cell voltages later.
For you I think the GW version of Jlog is more than enough and yes it is really superior to the UI devices.
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 08-16-2016, 02:38 AM   #12 (permalink)
The S32 (NG JLog) will log generally.
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 09-03-2016, 04:47 AM   #13 (permalink)
got Scorpion 130A esc and got TM1000 and using DX9 with vbar blueline , can I use j-log 2.6 , what do I need would like to have mah used data
G700 heli
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 09-03-2016, 07:45 AM   #14 (permalink)
No, not really, because there is no data from a Scorpion.
After the S32 has been released we'll probably bring our "S32-UIR", - finally, the design laying around since almost two years. I'll have to make the software implemention, of course, in UIR's microcontroller as well as in S32.
Output (through S32's data bus) will be:
- minimum: voltage, current, rpm
- perhaps as goodie on top: pwm
Temperature(s) through one of the common sensor options on S32.
RPM could be also already measured w/o having the UIR option.
(S32 is the NG JLog, some people call em "JLog3"... not yet released)
JLog today (of course also S32) could do the following w/ respect to the Scorpion:
- measure the voltage through the sensor option "CVS" (S32 can do that also natively, standalone)
- measure motor speed and derive also the rotor speed
- measure temperatures
What is missing, is the current, thus mAh accumulation. Although there is support for an option for that purpose (HiTec C200 Hall core), this is not supported as a general sensor option than only in relation w/ some ESC's which do not deliver the electrical current.
An alternative could be "UnisensE" or "Unilog" from SM Modellbau, Germany.
Whoops, just noticed: SPEKTRUM.
SM does not support SPEKTRUM telemetry.
Tom (j-log.eu)
