Closed Thread
Old 08-09-2012, 07:22 PM   #241 (permalink)
I have a real problem with 3.10/3.11 on one unit, I have two with 3.02 and they work just fine.
The swash hiccups when I switch cyclic channels on the 3.10/3.11 unit. There is no movement when switching cyclic channels on 3.02.
On the 3.10/3.11 I have reset the SD card, reset the accelerometers and there is no change.
Is there a way to force the 720 to reload the current 3.10 firmware?
Don S.
[ame]http://www.youtube.com/watch?v=xrLny6doBTc&feature=plcp[/ame]
ds1rc is offline        Quick reply to this message
Old 08-09-2012, 09:37 PM   #242 (permalink)
Don S.
Not directly or easily. Art could send you a rollback version? But no way to do it en mass off thier site.
Luvmyhelis is offline        Quick reply to this message
Old 08-10-2012, 03:02 AM   #243 (permalink)
And that is the problem. I can't understand why roll-back was available just for "chousen" beta testers, when the problem was obvious and related to all 3.10. Usually normal company makes general roll back for all the users until the fix is released.
Yesterday while I was making some set up I noticed that my SK reconnected to computer several times. I didn't touch anything. I was just sending changes to the card. Or even without it. I've tried different USB cabel and no changes. It looks like SK reseted while trying to write anything to the card. Also the software itself hanged 2 times so I've to finish it work with windows task manager. Logging is off.
I didn't dare to fly such unit.
Also with 3.11 software I've noticed that level sensor picture is not stable and trembling.
It looks like all 3.10/3.11 both firmware and software has a huge problem and bugged inside out.
It is big mistake for Skookum to release such software without proper testing and as far as the problem come out preventing simple users from rolling-back.
Tigron is offline        Quick reply to this message
Old 08-10-2012, 05:09 PM   #244 (permalink)
And still no update......
I think you should be alowed to install and version of firmware....
yellow303 is offline        Quick reply to this message
Old 08-10-2012, 06:04 PM   #245 (permalink)
Hi would this cause the swash to stop for a millisecond when i am moving the pitch up and down on the bench ? as i have just noticed it doing this or do i have another problem with some thing else , i am not losing power in the futaba sbus rx or sk720 unit as the lights all stay green all the time and dont flash...thanks all
van-man-123 is offline        Quick reply to this message
Old 08-10-2012, 06:09 PM   #246 (permalink)
I occasionally see this behavior too with Spektrum electronics (DX8 w/DSMx sats). As far as I've noticed, it only seems to happen withing a few seconds after powering up. It doesn't seem to affect the flight performance though.
NRPY is offline        Quick reply to this message
Old 08-10-2012, 06:12 PM   #247 (permalink)
Follow-up to post #241, I sent the entire post to Skookum including the video. Now if I can see what the swash is doing when I switch from one Cyclic to the other I wonder why Art can't. This is the answer I received:
"Hi Donald,
Do you mean that the swash jumps in collective, or tilts slightly, or
re-centers?
Best Regards
Art"
I could say, but I won't because at least the email was answered.
I have a solution:
I found an old setup from 2011 that I had saved, SK720_Installer_Rev305.zip. Since I didn't get answer to “how can I force a reload of the firmware.” I attempted to load 3.02 with the 305 installer. I got a conflict error and 3.10 stayed in the secret compartment however the "Check for Updates" face plate indicated the firmware was 3.02 that’s good.
Next step, run an update from the 3.11 installer hopefully get an overwrite of the current 3.10 firmware. That's what I wanted to try in case the firmware was corrupted before sending the 720 to Skookum for repair.
A quick test showed the reload was successful. It gets flight tested tomorrow.
Don S.
[ame]http://www.youtube.com/watch?v=xGGKAp6JwUE[/ame]
Old 08-10-2012, 06:24 PM   #248 (permalink)
That was AWESOME!!!! I wish mine would do that! I had the same issue as you.
Great posting!
Old 08-10-2012, 06:46 PM   #249 (permalink)
I just downloaded SK720_Installer_Rev305.zip and going to try it too!
Hope it works the same!!
Old 08-10-2012, 09:25 PM   #250 (permalink)
Mine have always doing this also, but it seems that since I turned off the logging it does not do that anymore, I guess it's when the logging started there was that little glitch.
That look similar to that current ''reset'' issue, but happen during flight.
T-rex 600E pro
T-rex 450L
Coaxial Collective Pitch 550
martin_ is offline        Quick reply to this message
Old 08-11-2012, 01:57 AM   #251 (permalink)
Should we believe what they are saying?
Support info@skookumrobotics.com
1:57 (7 tundi tagasi)
Vasta
saajale mina
I am hoping to post it today
On 10/08/2012 6:31 AM, Raimo Noormaa wrote:
Message: Hi,
How much more time will it take to correct the SK 720 v3.10 software?
Br,
Raimo
It seems this time we can!
Align T-Rex 600EFL Pro DFC, 3GX v4.0, TM1000; Align T-Rex 600N Pro DFC, 3GX v5.0; DX9
Riff is offline        Quick reply to this message
Old 08-11-2012, 03:54 AM   #252 (permalink)
Im glad im not the only one i have turned the logging off and i will see how it goes , this is happenining on a velocity 50 n and i am just powering the rx up on the bench it is futaba sbus running of a 2s lipo and am using power bus and all outrage hv servos my swash dose not tilt but just pauses sometime for a split second when moving the sticks around this is my 1st fbl heli so forgive me for being causious
Old 08-11-2012, 02:55 PM   #253 (permalink)
The update is now available, so everyone can quit whining and download it.
https://www.helifreak.com/showthread.php?t=443081
Old 08-11-2012, 03:47 PM   #254 (permalink)
=] Thanks Nick, it's taken a little over a month for SK to find this issue and release the patch, pretty good going in my book considering!
so I am going to lock it here, thanks for the 252 posts and the 9,178 readers! Georgi UK.
georgi UK is offline        Quick reply to this message
Closed Thread
