Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree6Likes
Old 10-07-2014, 12:15 AM   #21 (permalink)
On all the Goblins I've ever seen all the shaft holes are slightly oversize allowing slop where every bolt passes through. The only difference is the front tail pulley is the only thing not slotted allowing it to clamp. There have been numerous threads about slop on the head, main gear, secondary pinion and lower clamp. I use a T handle wrench on all those bolts and am able to get everything tight enough to achieve no play.
Goblin 630 Comp / Spartan VX1 N Fbl
Goblin 700 Comp / Spartan VX1 N Fbl
TRex 550 DFC Pro stock w/Spartan VX1 N Fbl
TRex 450l Dominator stock w/Spartan VX1 E Fbl
SRJay is offline        Reply With Quote Quick reply to this message
Old 10-07-2014, 07:12 AM   #22 (permalink)
Does anyone know why the holes in these shafts are over sized? I've never seen this on any other helis I have owned.
ranchhand is offline        Reply With Quote Quick reply to this message
Old 10-07-2014, 09:30 AM   #23 (permalink)
Originally Posted by Slyster View Post
What is slotting?
The process of adding a slot to the gear. Also a cut. If you look at the main gear it has a vertical cut in the aluminum hub. I just called it a slot. Probably not very descriptive on my part. ;-)
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 10-07-2014, 11:05 AM   #24 (permalink)
Slotting or slitting is the correct terminology. The head has it, main gear, and the secondary pinion has it. I used a 1/16" slotting saw in combination with my mill to slot the first gear I tried.
Old 10-07-2014, 11:52 AM   #25 (permalink)
Thank you SRJay, very good info.
Rotorexploder is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 10:27 PM   #26 (permalink)
i wish i would have seen this a few days earlier so i could have time to fix them before HFFF. Guess i have a bit of wrenching to do when i get back
Hobbywing US factory team pilot BK Servo Spartan RCTeam LynxTeam OXY Team Xnova I get high by getting LOW!!
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 10:31 PM   #27 (permalink)
If you already have the required tap and drill it only takes about 10min to do the mod. Simply slide the tail pulley off (you shouldn't need to loosen the belt) disassemble the pulley, drill, tap, and reinstall.
Old 10-08-2014, 10:36 PM   #28 (permalink)
Perhaps someone could do a video? I don't get it.. and never used or own any taps etc.
Old 10-08-2014, 10:38 PM   #29 (permalink)
not sure if i have that size tap. I bought a set a couple months ago, now i just have to remember where they are lol
Old 10-08-2014, 10:39 PM   #30 (permalink)
try searchng on youtube. It may already be there. If not ill post one when i do it if someone else doesnt beat me to it
Old 10-08-2014, 10:40 PM   #31 (permalink)
Originally Posted by DarkSyd3D View Post
try sea(***WARNING*** Stop Spamming Helifreak)g on youtube. It may already be there. If not ill post one when i do it if someone else doesnt beat me to it
UMMMMMM SPAMMING?!?!?! this is something new to me
Old 10-08-2014, 10:44 PM   #32 (permalink)
Ok, thought the picture said it all. I will go do a quick video to post.
Old 10-08-2014, 10:46 PM   #33 (permalink)
It did but some people are visual learners
Old 10-08-2014, 11:01 PM   #34 (permalink)
I've never used a tap either but there are several videos on the net showing the process that can be found. The abbreviated version is below.
1) Drill the appropriate sized pilot hole
2) Twist tap into hole until you feel it get tight
3) Back out the tap a half turn (this breaks off the bit of thread you just carved in step 2)
4) Repeat steps 2 and 3 until the tap threads all the way through.
700L SXTS Neo | Goblin 700 KSE Neo | Goblin 380 KSE miniVBar | Nano QX
rando is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 11:12 PM   #35 (permalink)
Careful using the Y word. I think that's what got me the spam warning
Old 10-08-2014, 11:20 PM   #36 (permalink)
Weird since folks link to videos on that site daily. The tag for doing so contains that very same word! In any case, I removed it just to avoid any sort of heavy handed action by the forum admins.
Old 10-08-2014, 11:58 PM   #37 (permalink)
that's it, it's as easy as screwing a screw in.
use some oil, it'll help a lot
XLPower Specter V2 - Rotorflight - ELRS
OMP M2 Explore - Rotorflight - ELRS
TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 10-09-2014, 12:17 AM   #38 (permalink)
At the request of Slyster here is a short video of how to do the mod.
Goblin Tail Pulley Mod. (5 min 15 sec)
Old 10-13-2014, 05:51 AM   #39 (permalink)
TT
GREAT CATCH SRJay!
I'm getting ready to apply this fix to a Goblin 700 and two 500s. I've been getting a mysterious clicking noise during maneuvers requiring full tail throws...actually trying to get it to blow out. I thought it was belt slap or whatever. I removed the pulley bolt and it has been taking a beating...so bad that I think it would eventually fail.
My experiences with set screws against shafts lead me to believe that a flat spot on the shaft would be a requirement but I was worried about grinding one due the thin wall of the shaft as you had mentioned before. Then I came up with this: Run a 4mm tap through the pulley bolt hole and the shaft simultaneously on one side then use a M4x8 grub screw to secure the pulley to the shaft...then do the same to the other side. 3mm tap/screws may work but I'm guessing the holes in the pulley and shaft are too big already.
It certainly wouldn't move after that! No flat spot required, no extra holes, redundancy in case one of the grub screws somehow broke or backed out.
Thoughts?
TT is offline        Reply With Quote Quick reply to this message
Old 10-13-2014, 12:15 PM   #40 (permalink)
I've owned 4 Goblins and have never had the clicking noise on any of them. Must be lucky I guess. After reading this thread I did check the three Goblins I still own and the tail drive pulley is tight on all three.
SAB KRAKEN JIVE 120, BK CYCLIC, BK TAIL, PYRO 750-500, THUNDERBOLT, VBAR
GOBLIN BT SPORT HELIJIVE 120, BK CYCLIC, BK TAIL, XNOVA 4525 530, SWITCH, VBAR
GOBLIN 570 JIVE 120, MKS SERVOS, XNOVA , SWITCH MAINS, KBDD TAILS, VBAR
seefest is offline        Reply With Quote Quick reply to this message
