Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 08-15-2013, 12:52 PM   #1 (permalink)
Default Fusion - new life
Has bothered to wait when there will be a normal upgrade on Fusion has decided all to make, now it is possible to put blades of 660 mm without fear that the basic gear wheel will not sustain OWG, or. A frame new, it is made Fusuno, carbon 2 mm, the basic gear wheels from Aurora 90, OWG from the Aurora 90, TT gear wheels steel from ballistik FSO.: Thumbup:
Here now I am happy
ID:	443717   Click image for larger version
ID:	443718   Click image for larger version
ID:	443719   Click image for larger version
ID:	443720   Click image for larger version
....The acquired mind does not compensate the stupidity given at a birth....
NRS63 is offline        Reply With Quote Quick reply to this message
Old 08-15-2013, 05:00 PM   #2 (permalink)
OHH, very nice upgrade
Could you please share with us the links for each part and steps for what you did?
kefou is offline        Reply With Quote Quick reply to this message
Old 08-15-2013, 06:22 PM   #3 (permalink)
X2
Steve
Have stuff from when I still played...
smrceo is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 06:27 AM   #4 (permalink)
http://optionhobby.com/35-cnc-boom-m...city-50n2.html
AVR-AV900212 Avant 99T Delrin Main Gear
Or AVR-AV000105 Avant Metal Tail Spur Gear (20T)
Or AVR-AV000104 Avant Delrin Tail Spur Gear (20T)
AVR-AV900211 Avant 97T Constant Drive Delrin Gea
AVR-AV900224 Avant Main Sprag Hub Assembly
AV00-200-669 Constant Drive Gear Hub (1)
AV00-200-671 Main Shaft hub Sleeve
AV00-200-676 Main Sleeve key (1)
YEI-ND-YR7-AS1146 Curtis Youngblood Steel Helical Tail Gear Set (Front)
YEI-ND-YR7-AS1149 Curtis Youngblood Steel Gear Torque Tube End Set
YEI-ND-YR7-AS1147 Curtis Youngblood Steel Helical Tail Gear Set (Rear)
Frame from FUSUNO ,Frame Fusion 50 khach dat hang Rev2,carbon 2 mm
http://www.lancasterarchery.com/east...row-shaft.html
Shaft TT, length is made of an arrow of 694 mm.
KDERCP-M1D6T12 KDE Direct Revco Hardened Steel Mod1.0 Pinion Gear (12T)
http://www.amainhobbies.com/product_...haft-R30V2-R50
These are the bought details, then I shall draw sketches as this all to collect and what details need to be made most.
Name:	Left with red.jpg
Old 08-16-2013, 08:38 AM   #5 (permalink)
Very cool!
Tom
stang281472 is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 11:27 AM   #6 (permalink)
Smile
For the further work the lathe and the good master is necessary.
It is necessary to increase apertures under bearings in a forward and back case, steel gear wheels differently will not be located. And also it is necessary to make some details, they are necessary for the coordination steel a gear wheel and shaft. Apertures in steel gear wheels have diameter of 6.5 mm, shaft have diameter of 5 mm.
Bearings it is pasted on green lock, the bronze sleeve it is pasted to a gear wheel on red lock
For installation of the necessary backlashes between gear wheels it is necessary to use thin washers
For manufacturing of a TT of a shaft we use an arrow, it it is necessary to cut off of 693-695 mm on length, and to drill apertures in diameter of 2 mm on distance of 10 mm from edge. The arrow perfectly approaches, very strong and easy, such arrow is used by Kasama. I to drill exact apertures the conductor has made of a steel tube, now I insert an arrow and through an aperture in the conductor easily and precisely I drill apertures in an arrow.
After the tail shaft will be collected, it is necessary to reduce diameter of a gear wheel, differently it will not be located.Это it is possible to make having clamped a shaft in a cartridge of a drill and to bring to a rotating abrasive stone, it will occupy 1-2 minutes.
I used an abrasive disk from diamond.
It is necessary to receive diameter no more than 14.5 mm.На it all nuances a tail case are finished, I will describe further a front case.
ID:	443950   Click image for larger version
ID:	443951   Click image for larger version
ID:	443952   Click image for larger version
ID:	443953   Click image for larger version
ID:	443955   Click image for larger version
ID:	443956   Click image for larger version
ID:	443957   Click image for larger version
ID:	443958   Click image for larger version
ID:	443960   Click image for larger version
ID:	443970   Click image for larger version
ID:	443971   Click image for larger version
ID:	444002   Click image for larger version
Old 08-16-2013, 06:54 PM   #7 (permalink)
Wow, great work.
* Goblin 700C, iKON, Torq 9180/9188, Quantum 4530-500, Edge HV160, Cyclone 695
* Outrage Fusion 50, SK-540, Torq 9180/9188, Quantum 4135-530, Edge HV80, SAB 630 Blk 3D
* Align T-Rex 500E DFC, SK-540, ICE 75
* Futaba 14SG
Arcturus97 is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 08:35 PM   #8 (permalink)
Default Re: Fusion - new life
I wish you were in the states I'd send you a fusion to do up...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Steve
Old 08-19-2013, 10:23 AM   #9 (permalink)
Very ridiculously, it's a small world, dear friend if it is necessary to make something distance does not play the big role, Russia only other party of our globe.
P.S : Forward case I will start to collect and photograph after the necessary details th to tell the truth when collected the helicopter least about it will come thought, and already the collected car - the hand does not rise to assort.
Old 01-11-2014, 06:57 AM   #10 (permalink)
The last modifications, new head from RJX has allowed to put blades of 690 mm, a tail beam of 770 mm from GAUI 7, from it and tail boom support. The flight weight from batteries 4000 ма, makes 4600 gramme.
ID:	478124   Click image for larger version
ID:	478125   Click image for larger version
ID:	478126   Click image for larger version
Old 02-27-2014, 06:35 AM   #11 (permalink)
thanks for sharing
we need all the help we can get if we expect to keep this heli in the air
Outrage Fusion 50 FBL / Futaba 8FG / Beastx / Scorpion HK4025
sansone is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 12:59 PM   #12 (permalink)
Very reasonable design, is pleasant to me more and more. That flies very well, very sympathetic tail. Probably awake to order one more frame and to collect already the third Fusion, the design very is pleasant, I consider its as one of best of modern helicopters.
Old 04-22-2014, 01:48 PM   #13 (permalink)
I have made some upgrades after has changed the motor for 4530 quantum rewound by a wire of 1.6 mm, delta.
https://www.helifreak.com/showthread.php?t=615575
Name:	??? ???????_1.jpg
Old 04-23-2014, 08:07 AM   #14 (permalink)
agree very pleasant design, flies great also.. will be looking to keep mine in the air by finding parts from other helis..
your work is impressive and as said before, thanks for sharing
Old 09-14-2014, 12:29 PM   #15 (permalink)
Ha, Ha - helicopters live eternally... In Russia, at due service.
That actually it would be necessary to us from model-that it it is convenient in operation and it is inexpensive in service, to these criteria of Fusion responds to the full, I think still many will regret having refused this design, Fusion for ever!!
Name:	???????? ???????? ? ?????1.jpg
ID:	535966   Click image for larger version
Name:	???????? ???????? ? ?????.jpg
Old 09-21-2014, 09:07 AM   #16 (permalink)
http://www.ebay.com/itm/251637937853...%3AMEBIDX%3AIT
boom mount from China
fpainter is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 09:13 AM   #17 (permalink)
But it where is more pleasant for making own hands, yes it and more precisely turns out, at Chineses absolutely badly with accuracy...
