Old 09-22-2014, 05:02 PM   #1 (permalink)
Default Trex 500 Torque tube tail conversion kit questions:
Sorry if this has been answered elsewhere and I missed it.
I have some questions regarding Align Part Numbers AGNH50092 and AGNH50092A: Trex 500 Torque tube tail assembly. Is there a difference between the two different part numbers I have seen for this tail assembly?
http://www.amain.com/Align-500-Torqu...ioORoC7nXw_wcB
I would suspect that the "A" version has the 36t vertical drive gear and the non-"A" has the 31t. Is this correct? Or is it just some other small revision?
The reason I ask is that I have an ESP airframe, but it is built with an older belted tail. I want to upgrade to Torque tube and add the new pitch slider assembly to my tail. I wanted to know the difference if any that way I know whether or not I have to replace the vertical TT drive gear with a different tooth count. All the Align specifications descriptions I have seen do not mention the vertical drive gear tooth count for either. Since these cost anywhere from $65 to $85 depending on where you get them, It would be helpful to know which tail drive gear spares I would need.
Any help would be appreciated!
SoXoS Strike 7.1 (x2) | Miniature Aircraft Whiplash Nitro NII | Miniature Aircraft Fury 57 | Blackout Mods : ??????
Teams: Aero Panda, Heli-Professional, SoXoS USA, 1ST RC, Xpert RC USA, Pulse Battery, iKon Flybarless, Blackout Mods USA
PowerDyne is offline        Reply With Quote Quick reply to this message
Old 09-23-2014, 05:57 AM   #2 (permalink)
The newer, narrower frame 500 Pros are all torque tube, whereas the older 500s and 500E were belt driven. So I would hazard a guess that the TT conversion kit you linked will work in your ESP. Just to be sure, you could give AMain a call.
*Spartan Vortex VX1e*
Old 09-23-2014, 01:01 PM   #3 (permalink)
Thank you for the response.
After looking at the display pictures for the assembly, it does appear to have the correct hexagonal pins for a 500E/ESP's spacing.
I may just get one anyway. If it's the wrong vertical gear I can always change it out.
Old 09-23-2014, 02:54 PM   #4 (permalink)
For the ESP frame you need the 31 tooth setup.
Allan
Old 09-23-2014, 03:13 PM   #5 (permalink)
I understand that. The question was about which TT drive gear comes with the conversion set. Align does not specify. I assume it';s the 31t, but there are two different model numbers of the TT assembly floating around out there: the standard, and the "A" revision.
I wasn't sure if there was a major difference.
*Edit* Just got word back regarding this, and they are one in the same. the A must be just a revision code or something. They are 31T.
Old 09-24-2014, 05:34 AM   #6 (permalink)
I don't understand how they can be the same, since the boom block needs to be wider for the ESP, etc. doesn't it?
Old 09-24-2014, 05:07 PM   #7 (permalink)
Yes, the boom block is wider on the ESP. The issue with the part number though was just a revision. the parts are the same between the different part numbers. At least that is what I was told.
Old 09-25-2014, 07:19 AM   #8 (permalink)
OK, I get it now.
