Old 10-16-2012, 05:06 AM   #41 (permalink)
Originally Posted by gs550t1981 View Post
Will the mcpx tail fit in the nano frame and work? and where did you get those canopies????
Yeah should do as the Nano tail fits perfectly in the mcpx frame (2mm carbon rod).
I purchased all my canopies from:-
http://www.fast-lad.co.uk/store/inde...page=3&sort=1a
Pretty sure I've since seen them all for sale on ebay too.
Strangedaze is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 08:05 AM   #42 (permalink)
Hey indoorheli thanks a lot
i totally agree with you about 5!
and a ratio of 1.75 for 4 seconds if the tail holds is really great, and never be achieved with a mCP.
I'll get my greedy hands on one as soon as i'm done with this freakin' thesis, again thanks for your feedback.
one more question, is it enough to wear the motors in for like 3-4 hower flights (no right pyros) with about half throttle?
Prost
Originally Posted by indoorheli View Post
Here you go
1) I have still crashed pretty hard and I have not noticed an increased damage rate.
2) I am using a hp03s with a modified mount and a xp3A esc with BLHeli code and the stock tail. Though I would suggest waiting for Dylans modified hp03 as it will be easier to install.
3) 51g stock thrust was about 4-5 seconds at full charge
4) No I measure as stock would fly with tail left plugged in
5) While the numbers of the mcpx and nano seem to be comparable the big difference is full power doesn’t strain the system like the mcpx main motor did. Soon as I got rid of my mcpx main and went brushless my tail became stronger. I did not notice the same on the nano and the tail authority was solid anyhow unless my battery is crap or I have vibrations somewhere.
6) IMHO the nano is the best indoor heli I have ever flown for capabilities and durability
7) Stock it has no problem doing basic 3d and I am sure a real pilot can rock it and even do sharp tic tocs. My timing isn’t the best so I need more power to do certain maneuvers. But for rainbow’s, flips and funnels it can easily do all of that stock
The.K is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 11:26 AM   #43 (permalink)
Default Help.....
Okay... I have been dying to get my NanoCPx Brushless......
I have the Dylan motor and ESC but am stuck with the ESC....
Problem is I should have asked Dylan to flash it and I ordered a new one from him last night. I have the stick and have fought it for two evenings now. I am going cross eyed. I am having connection problems when flashing. I have checked my connection..... Could it be a driver problem? Could someone point me to a YouTube video maybe on doing the process?
How To Use BLheli Software with the Oversky 10A PNP ESC (8 min 2 sec)
PS.... I did find one. Is this right?
Bjanzen is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 01:04 PM   #44 (permalink)
Default nano kits
Ive just finished the final design of my parts I have made to convert mine to brushless...all I need now is my 8 tooth gear for the motor and I will give it a test...
I made a two part spacer for the servo the first is a frame stiffener / spacer and the second is the just a spacer..the black ring is the motor mount that is press fit in the frame...
Name:	2012-10-16 12.42.48.jpg
ID:	358014   Click image for larger version
Name:	2012-10-16 12.43.03.jpg
ID:	358015   Click image for larger version
Name:	2012-10-16 12.43.16.jpg
ID:	358016   Click image for larger version
Name:	2012-10-16 12.43.28.jpg
pjacq is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 02:21 PM   #45 (permalink)
https://www.youtube.com/watch?v=3zHk...e_gdata_player
It should be as simple as soldering the 3 wires to the pads on the esc, applying power and flashing.
Blhelisetup 7 has a bug for me when flashing new escs though, have to erase the chip first, or flash with an older version first.
8 was just released last night too, havent tried it yet though
Dylan ~ www.AstroidDesigns.com
Old 10-16-2012, 02:21 PM   #46 (permalink)
I like it whats the weight on the spacers?
Old 10-16-2012, 02:42 PM   #47 (permalink)
I just tried it and it holds terribly...... why would that be???? also the vibrations and wag is bad
gs550t1981 is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 02:44 PM   #48 (permalink)
Vibrations Effect tail hold more than anything else. Get rid of vibes.
Old 10-16-2012, 03:24 PM   #49 (permalink)
Dylan,
Thanks...... I was told that the stick had to be soldered to other spots on the board or it would be ruined.......
Just trying to make sure ;-)
Old 10-16-2012, 03:35 PM   #50 (permalink)
Just thought I would post my setup for the motor. Was quite simple..... Just a 1/16 G10 disk 8mm CA'd to the lower mount. I did have to carve a little space and slot for the motor screws.....
[IMG][/IMG]
[IMG][/IMG]
Old 10-16-2012, 03:46 PM   #51 (permalink)
The 3 solder pads are identified in the blheli thread, first post, and in the supported esc pdf on github, links to both are in a new section "BlHeli info" on my site.
The solder joints have to be good, short wires between the stick and esc help. I use flux on the 3a pads to help get a good joint.
Old 10-16-2012, 03:47 PM   #52 (permalink)
[IMG][/IMG]
[IMG][/IMG]
Looks good, still dont like the long shaft needed using an unmodded hp03s though.
Old 10-16-2012, 03:50 PM   #53 (permalink)
Okay......I have scoured your site and stared at pics in this thread and yours..... All show soldered plug for flashing in the center of the board. Can I use the same pads as for the 3-1 input for signal and power?
Old 10-16-2012, 04:04 PM   #54 (permalink)
No, you have to solder to the pads in the middle of the board.
Old 10-16-2012, 04:08 PM   #55 (permalink)
Fantastic Dylan! What a great BLHeli compilation on your site This will make things a lot easier for a lot of people
timox72 is offline        Reply With Quote Quick reply to this message
Old 10-16-2012, 04:08 PM   #56 (permalink)
Do you want me to solder a 3 pin flashing plug on your esc? What toolstick are you using?
Old 10-16-2012, 04:09 PM   #57 (permalink)
Okay then..... Guess I will wait til you send me a new one..... I placed my order last night. I am sure your skills are much better than mine and WELL WORTH the 5 bucks ;-) I tried to solder to those spots and first time I unplugged my lead I pulled the positive pad off the board :-( Signal seems loose now as well. I ordered a set of three prongs..... Maybe you can just leave it on the board for me.... Hint hint ;-)
Old 10-16-2012, 04:11 PM   #58 (permalink)
Yes please...... I have your stick but can put any connection on it....
Old 10-16-2012, 04:12 PM   #59 (permalink)
Fresh information? Yeah! Didn't find that last night...... Have some learning to do tonight
Old 10-16-2012, 04:15 PM   #60 (permalink)
That page is less than 12 hours old I'll be adding more to it too
