Go Back   HeliFreak > R/C Electronics Support > Gryphon Electronics
Gryphon Electronics Gryphon Electronics Factory Support Forum
Closed Thread
Old 03-03-2014, 07:58 PM   #1 (permalink)
Default GSR7017 LMT connecting GSB1030 Solved
Hi, I just got this BEC for my new Goblin and I am using the switch. But they are not clear on connecting the "Switches" the GSB 1030P has a set of wires (3 wires on a connector - Red, white & black) then a second connector on 1 plug that is a single yellow wire. And the manual says Connect a compatible switch on the "switch:" connector. OK but where does the Yellow wire go.
Not very impressed, for this expensive of a BEC, I guess I should plug it in anywhere its ok it will work
can someone shed some light?? I'm sure its been asked before.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Quick reply to this message
Old 03-03-2014, 08:22 PM   #2 (permalink)
Ok I saw a picture of the 7017 on the Quasar site, shows the switch attached with the yellow wire plug going into the Aux port "sig" line. why cant they just say that in the manual. Ya I know it seems the only place for it to go, but come on, I don't just plug stuff in without knowing for sure.
Right now this BEC has a D- it better work great!! First time using this.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-05-2014, 10:38 AM   #3 (permalink)
Can check wiring when I get home later and let you know , if you havent done so yet . Walt
MQX---TREX 450 PRO FBL---TAROT 450 PRO FBL/AIRWOLF Fuse---FUSION 50 FBL--TDR---RotorMast V-22 Osprey----Mini-V--Beastx--Full V-Bar --Scorpion -- Kontronic Jive --- Pyro----DX8
FLYING IS SIMPLE---NOT HITTING THE GROUND IS HARD
airbound is offline        Quick reply to this message
Old 03-06-2014, 08:36 PM   #4 (permalink)
Angry
I have powered it up, and something is not correct. First let me say that I did see a picture of the second "yellow wire plug" on Gryphon's site. So now I had the Plug in the switch, I expected to plug the battery in and nothing happen (all blades off the heli) But the heli powered up full. I checked to see if I had the plug not fully in the switch, and the heli did drop power. But if you move the "pin with the red flag" around slightly the heli will power up easy (without removing that plug). like a semi loose connection, this is not right. When powered, The Blue light comes on, I put a low battery in and the red light came on also. But this pin is not a secure thing, slightly bump the pin and the heli will power on. This connection is no good.
So to sum up the switch seems to work, but the plug does not shut the heli off when you plug it in. You have to have the plug in just the right spot. no good!!
Help, I want to like this setup! but I'm real close to pulling it.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-06-2014, 09:51 PM   #5 (permalink)
Here is a Video showing the power switch problem
" frameborder="0" allowfullscreen>
Just a little twitch and it powers up??? that's not good.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-08-2014, 02:36 AM   #6 (permalink)
Hi
Did you wire as per this image?
If you did so, - then It seems like something is wrong. - The switch seems to have a fail, so i would not use it. maybe talk to the shop where you bought it, and they can replace it?
Best regards
Name:	Gryphon switch.jpg
RasmusDK is offline        Quick reply to this message
Old 03-08-2014, 03:53 PM   #7 (permalink)
Yes, that looks like the picture I found on the Gryphon site. So yes I hooked it up like that picture, it was the only way that made sense. I think I got a defective switch, not real happy with this product at this point. HeliDirect is sending me a new one, but they want me to pay to return the bad one. I don't know another industry that does this when they send you a defective part. Probably should have went with a 2s lipo, that's what I get for trying new stuff.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-08-2014, 04:45 PM   #8 (permalink)
Originally Posted by RasmusDK View Post
Hi
Best regards
By the way, thanks for your post! Not a lot of people in this thread so it's hard to get a reply. I appreciate your help
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-09-2014, 06:28 AM   #9 (permalink)
Your welcome :-)
Don't be afraid to use it when you got a new one.
Yours the first one I've heard having a failure.
Normally they work great.
I don't know how the law is in your country, but I'm not sure the shop has to say the shipment?
Anyway, I hope you will have a working pin switch in the end, and it will satisfi you :-)
Best regards
Old 03-09-2014, 12:08 PM   #10 (permalink)
I have gone this far, I will keep going. Don't like that it's on a Goblin 700. It would be cheaper on a Align or something else. I just expected better from all the things I have read about this BEC
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-09-2014, 03:53 PM   #11 (permalink)
I understand :-)
I'm sure the BEC will work great.
It's just the pin switch that have a failure.
I use this bec in beam600, kds innova700, gaui x7, agile7.2 and raptor e700.
And never head a single issue with any of them.
I trust them, and I'm sure it will work very well in your goblin too :-)
Old 03-10-2014, 08:28 PM   #12 (permalink)
Ok, so just to report and end the thread. The replacement GSB1030P arrived today. and it worked as expected, I just had a defective switch. Bummer but not the end of the world.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Closed Thread
