Old 07-23-2014, 10:56 PM   #1 (permalink)
Default Battery orings
Got my protos basically built now. The hardest part? Getting the orings on the battery. I practically break the skids trying to get them on. Anybody know a trick to make it easier?
IS FURY AND FIRE A RED LINE
tworst is offline        Reply With Quote Quick reply to this message
Old 07-23-2014, 11:39 PM   #2 (permalink)
How big is your battery? Mine go on effortlessly.
Trex 800 DFC Pro
Goblin 700 Competition
Trex 600 ESP FBL - R.I.P.
MSH Protos 500
Cleared2Engage is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 12:16 AM   #3 (permalink)
I use Velcro and rubber bands instead. The O rings don't last very long.
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 12:18 AM   #4 (permalink)
Put a zip tie on o ring give s more leverage cut the tail to make a handel .there pretty tight on 3300 glaicers
kayakboy69 is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 06:52 AM   #5 (permalink)
I hear you as I´m running 2x3S lipos from my MiniP in series, so my packs are fat. But the same o rings are used as sealing gaskets for automotive oil filters. Maybe you can find some with a larger diameter.
Also: http://www.oringsandmore.com
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 04:23 PM   #6 (permalink)
Standard 2700 mAh packs (Sky Lipo) work fine with the O-rings.
Llama v3, EXI 450 Pro, Nano CPX, 130X, Protos 500, various planks
Futaba 8FGH, Spektrum DX7s
18-channel scratch built tugboat controlled by modified Futaba Tx
R/C junkie for the past 25 years and counting...
kingmeow is offline        Reply With Quote Quick reply to this message
Old 07-24-2014, 06:00 PM   #7 (permalink)
2500-3300 packs on mine, no problems with the o rings at all. I like them better then Velcro. I pull way up on the o-ring creating slack then drape it over and hook it on, works every time.
Mike
Hirobo 450 Embla vbar
Protos 500 stretched vbar
Trex 600 efl Pro vbar
mike d1 is offline        Reply With Quote Quick reply to this message
Old 07-25-2014, 05:45 AM   #8 (permalink)
I bought slightly bigger (only 5mm or 10mm diameter) off eBay for my Gens Ace packs and they work a treat
Old 09-23-2014, 03:42 AM   #9 (permalink)
Those o rings are ridiculous! I also tried them and they are so strong they will **** up your battery. LiPo's do not like to be brutalize and indenting them with a stupid o ring is not a good idea.
CAUTION! Low tolerance to idiots and B.S.
qntt is offline        Reply With Quote Quick reply to this message
Old 10-04-2014, 10:24 AM   #10 (permalink)
Banned User
Post
What size batteries are you using? Oversized packs will not work well with the battery O-rings.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 10-04-2014, 11:45 AM   #11 (permalink)
Another option is to buy the o-rings for the SAB Goblin 630...700. Use two, one for each of the two hooks on the frame. In other words, wrap the o-ring around the two lower hooks on one side, up and over battery, and hook onto the two lower hooks on the other side. Do the same for the upper two hooks with the 2nd o-ring. This along with the velcro between the battery and frame keeps the battery in place and doesn't dent it.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
