Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 01-20-2008, 06:56 PM   #1 (permalink)
Default Gaui Hurricane 550 Weight
Can anybody confirm the weight of this heli...well equiped?
Please include setup.
Thanks.
BobOD is offline        Reply With Quote Quick reply to this message
Old 01-20-2008, 07:54 PM   #2 (permalink)
Flying weight is 4 pounds 3 1/3 ounces.
jnngill is offline        Reply With Quote Quick reply to this message
Old 01-20-2008, 08:21 PM   #3 (permalink)
4 lbs even with 2500 poly's
4lb 3 oz with 3300 poly's
this includes weight of eagletree v2 plus monitor.
airtronics styd servos, gy401, 515 cf blade, mostly metal head, Z20 980kv motor, 1320 mah tp rec batt.
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 01-21-2008, 03:20 AM   #4 (permalink)
Hurricane @ 5350 5S,
BEC 2S 800,
Eagle tree complete sensor layout
CF 550 blades
ALU LiPo bracket
_____________________________
2650g (5,83 lbs)
Phoinix is offline        Reply With Quote Quick reply to this message
Old 01-21-2008, 04:26 PM   #5 (permalink)
Bob,
Mine ways 1738grams without batteries but with Trex 600 u/c, Futaba 146iP Rx, but no lipos as they vary depending on the size - my Kong Powers weigh 206 grams each the A-Plus's 2200 25C weigh 180 grams each.
Therefore weight with 2 x KP = 2150 grams, 4lbs 11oz
or with 2 x A-Plus = 2098grams, 4lbs 10oz
Cheers,
Mike.
Old 01-21-2008, 05:46 PM   #6 (permalink)
4lb 3 oz? That's 1903 grams. Assuming a 6s3300 battery is 515 grams, that means your at 1388 grams without the battery.
MikeJ is at 1738g without the battery and without the eagletree I presume.
How do you account for the difference?
Old 01-21-2008, 10:41 PM   #7 (permalink)
I must have measured wrong the first time....I had a problem balancing the heli on the scale. This time I used a platform and zeroed out the tare wt.
Empty wt is 4lbs 1852 g
2500's wt 14.8 oz 424 g
3300's wt 1lb 3oz 544 g
so my max wt with the 3300 is "5lbs 3 oz" 2396g
2500's 4lbs 14.8 oz 2276 g
Sorry for the mistake.....that seems to be more in line with others and is much more accurate the way I weighed it this time.
Mike
Old 01-22-2008, 01:24 AM   #8 (permalink)
Bob,
Unfortunately it is without an Eagletree as I don't have one yet
The weight (1738 grams) is fully built with Futaba R146iP rx, Dimension SportBEC, Gaui 50 amp ESC, Gaui 850Kv motor, 3 x 3001 on cyclic and 3151 on the tail with a Telebee gyro, it is with short boom and 500mm main blades and CNC pitch, aileron and elevator levers, plastic main frames.
With 2 x KP 2200's it weighs in at 2150 grams.
Cheers,
Mike.
Old 01-22-2008, 05:24 PM   #9 (permalink)
Mike
Ah, that looks much better. Thanks.
Mike...get the Eagletree...you'le love it!
Old 01-22-2008, 05:29 PM   #10 (permalink)
It looks as if my 550 needs to go on a diet I know that part of this is down to the Trex U/C, and I have just bought a DX7 so putting the AR7000 in should help also. Then I can put some of the weight back on with the Eagletree
Old 01-23-2008, 05:19 AM   #11 (permalink)
Readyheli CF frame
All cnc head (except seesaw)
Trex cnc tail (complete)
CF 500 blades
plastic canopy
Trex 3D landing gear (heavy)
Trex carbon tail supports
Quark 65 esc (heavy)
Z-power z-30 (heavy)
JR RS77S RX
gy401 gyro + 9254 tail servo
3 x futaba 9650 servos on cyclic
5A BEC
total weight 1840g
6s 4100 lipo (hextronic) 640g
---flying weight 2480g---
ianjh123 is offline        Reply With Quote Quick reply to this message
