Old 09-30-2009, 04:56 PM   #61 (permalink)
wher is the micro sd slot?dont see any markings or signs of it in the pics
Trex 500 12s vbar I2 bling
Furion 600 12s vbar I2 bling
trex 700edl vbar 12s I2 bling
Tdrex 800e 12s vbar I2 bling
Bank account EMPTY
growmaster4 is offline        Reply With Quote Quick reply to this message
Old 09-30-2009, 06:23 PM   #62 (permalink)
Hiding within the servo port. There's no real reason to get at it though, once it's in there.
Skookum is offline        Reply With Quote Quick reply to this message
Old 09-30-2009, 06:26 PM   #63 (permalink)
will that be used for the data logger or for saving setups or both?and will the data logger show actual rotor rpm or motor rpm?i just got a castle ice esc and am a little dissapointed there is no rotor rpm only motor rpm
Bank account EMPTY
Old 09-30-2009, 06:59 PM   #64 (permalink)
Knowing motor rpm is enough to get rotor rpm. I don't know what CC data format looked like, but if it is similar to ET, you can import it to excel with very minor modification. A few excel small macros would calculate headspeed and plot any parameters you like.
Current Fleet: TRex-700/500/450/250 Vbar, Logo 600SE/600/500 VBar, Outrage Fusion 50/G5 VBar/FB, Blade mCPx x 2
ke6d is offline        Reply With Quote Quick reply to this message
Old 09-30-2009, 07:10 PM   #65 (permalink)
i know it is very easy to figure rotor rpm that way,but at the same time if its that easy why not implement it into the software?you already have to put your gear ratio for set rpm mode so it already knows that.rotor rpm is the more usefull data so why not include it
Bank account EMPTY
Old 09-30-2009, 10:58 PM   #66 (permalink)
if there is enough feedback to CC...hopefully they will release software/firmware that can do this in the system...i would like to get one of the new ice controllers...any reviews?
ps61785 is offline        Reply With Quote Quick reply to this message
Old 09-30-2009, 11:48 PM   #67 (permalink)
i would like to get one of the new ice controllers...any reviews?[/QUOTE]
i like it alot
Bank account EMPTY
Old 10-04-2009, 10:36 PM   #68 (permalink)
thanks, i know this wasnt the place to ask, but saw the comment about the headspeed stuff...thanks...
Old 10-05-2009, 12:00 AM   #69 (permalink)
hey guys, just did a GAUI FBL conversion on my Mini Titan...the mini titan is odd compared to other helicopters, in that by moving the swash down, the blades get more positive collective.
So i flipped the Gaui Grips so that the blade is leading and the arm thats part of the blade grip is BEHIND (or trailing) the blade. Follow me so far?
So i was wondering, will this have ANY effect on the flight characteristics? thanks!
- Logo 400SE w/Blueline Mini-V, ICE75, FBL EDGE 470's
- Thunder Tiger Mini Titan E325 Flybarless w/SK-360 Gaui head
- Align T-rex 250 w/ DS760 + JR DS3500G
heliaddict22 is offline        Reply With Quote Quick reply to this message
Old 10-05-2009, 12:07 AM   #70 (permalink)
this is a long debated question.if i were you i would leave the leading edge as it was designed that way and works great,all you have to do is reverse the swash mix for your pitch in the software
Bank account EMPTY
Old 10-05-2009, 12:15 AM   #71 (permalink)
really?
Old 10-05-2009, 12:45 AM   #72 (permalink)
if your swash mix is a positive number,make it a negative number and the swash will go to opisite direction.i flew mine with leading edge control
Bank account EMPTY
Old 10-05-2009, 01:01 AM   #73 (permalink)
Default Question for Art...
I am in the research mode now and evaluating all the options (V-bar, Gyrobot and SK..) I will definatly wait for the release of the new SK720 to see what options it will have.
Being a beginner myself I was kind of attrracted to the "Beginner Mode" on Gyrobot 900 but than again the price on it is no where close to my budget.
All I want to have is a unit that will keep the heli pretty stable and tamed down, I am not into 3D (I want to run a T-rex 500 with Scale Fuselage...)
Do you think SK720 will be something for me ?
heli4fun is offline        Reply With Quote Quick reply to this message
Old 10-05-2009, 01:02 AM   #74 (permalink)
definately since it has the bail-out feature....and you can put in GPS and a few others, so it will do what YOU want. Once the 720 is out itll be on my heli right away
Old 10-05-2009, 01:25 AM   #75 (permalink)
growmaster how do i decrease the amount of pitch it gives the heli? im getting 15-16 degrees and thats WAAY too much....the thing is, at center stick the blades are at 0 degrees....so is it a programming thing or?
Old 10-05-2009, 02:33 AM   #76 (permalink)
Why not just mount the grips so that they are leading?
Perhaps the Mini Titan's stock head is configured to where the swash must travel down for positive pitch, but you're not even running the stock head. Geometrically speaking, I don't see why you would NEED to maintain the same swash movement with the Guai head. The pitch links are a straight shot from the swash to the pitch arms. If you mount the grips in the "leading" orientation, upward swash movement will generate positive pitch, period.
Al Austria is offline        Reply With Quote Quick reply to this message
Old 10-05-2009, 01:13 PM   #77 (permalink)
i was just wondering if the 720 will have torque compenstion,looking at a friends vbar,this is a nice feature
Bank account EMPTY
Old 10-05-2009, 01:27 PM   #78 (permalink)
Yes, it has torque compensation.
Old 10-05-2009, 04:29 PM   #79 (permalink)
Hi Skookum,
Can you give us an update on the 720 development? Any light at the end of tunnel?
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 10-05-2009, 04:35 PM   #80 (permalink)
It's going...but we don't want to release it with any outstanding issues.
