Old 11-25-2014, 06:30 AM   #1 (permalink)
Default Dx9 setup
Hi! Does anyone have a link for a setup sheet for the dx9? Just got my dx9 and cant find setup for 300x anywhere..
Thanks!
Ole
aoello is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 06:55 AM   #2 (permalink)
Should be same as the dx8/dx18. Only issue might be swash type, single servo type is listed as normal.
Anything else?
sp00f is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 09:50 AM   #3 (permalink)
Anything else?
+1 the servo type was a bit annoying... took a while to figure out (for me)
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 12:24 PM   #4 (permalink)
Thanks for replying! I have only setup my dx6i for helis one time so none of the settings are ituitive to me.. sorry. Im looking at the dx8 setup sheet now but there is so many differences in the menues that i cant figure out what to put in where.. for example in flight mode setup the alternatives is totaly different from the dx8.. also what switches to use for d/r and expo. It would help alot to have a setup sheet for the dx9 or a .spm file and take it from there..
I cant understand why there is no setup sheets or youtube vids that adress the issue
Thanks for the help though!
Ole
Old 11-25-2014, 01:06 PM   #5 (permalink)
Thanks for the help, looking forward to firing up my 300 this weekend.
jasond1979 is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 06:36 PM   #6 (permalink)
I based my 300x set up on the dx8 for my dx6 (I think it has the same airware as the dx9) and it works. If the dx6 spm files can be loaded into the dx9 I can send you a copy. You may have to change servo reversals depending on what servos you are using.
Blade 450X - Savox, Scorp 2221-8 13t Slant Edge Lite50
Blade 450X (3D) - Hitech Servs Std ESC and 420 Motor
Blade 300X - Savox Servos, lynx tail, OWB, Talon 35, Hyperion 2213 3585 14t std main, DX6
andycrazy is offline        Reply With Quote Quick reply to this message
Old 11-26-2014, 05:09 AM   #7 (permalink)
Thanks! I dont know if the setup is the same for the dx6.. I found the spm file for the 300cfx on spektrums site https://www.spektrumrc.com/Products/...0#prod_manuals. Do you think that would work?
Ole
Old 11-26-2014, 07:04 AM   #8 (permalink)
It should be near enough. You may have to play with the servo settings. It would be worth a try as it costs nothing!
Old 01-14-2016, 03:56 AM   #9 (permalink)
Ole
aoello,
I am having the same problem in setting up the DX9 for the 300X.
I have been advised that the 300CFX is NOT compatible with the 300X, but I have not checked it out myself.
Did you eventually manage to program the DX9?
Any information gratefully received,
Tony
tony#1 is offline        Reply With Quote Quick reply to this message
Old 01-14-2016, 07:15 AM   #10 (permalink)
Originally Posted by tony#1 View Post
aoello,
Tony
Nope, they are mounted in different positions from factory so they wont have the same settings. 300cfx is mounted normal and 300x inverted inside the frame...
300x with top mounted fbl would have the same settings as a 300cfx
Old 01-18-2016, 05:22 AM   #11 (permalink)
Thanks Livan75.
I shall see how I get on with the 300CFX set up when flying the 300X with my DX9 once I have altered the AR7200 Rx position.
Tony
