Mars/Poseidon Mars and Poseidon Helicopters |
07-09-2011, 04:58 PM | #21 (permalink) |
Hey "Gazaur Brothers", finally got my heli, started installing ny servos, motor. Had to order feather shaft and some small stuff. Just received parts and hopefully gyro will be in soon. question,, is the Poseidon and Mars canopy interchangeable? need to order canopy and was considering a couple for custom paint. Going to add some CF for "Bling" already has stretched tail!
any advice would be appreciated, Thanks,
Rick, Team pilot , EGODRIFT, KST, Helidirect, Lynx/Oxy |
07-09-2011, 08:17 PM | #22 (permalink) |
greeting's from the south. thank you for the kind words furex. sounds like you miss your sweety (poseidon) a bit? mars is having a sale.
hello crickr1, the mars canopy will work on the poseidon frame. i'm not sure the poseidon canopy will fit the mars frame? the front under part of the canopy is cut a bit longer on the mars. i have floodlight keeping the poseidon from sliding all the way back. if the flood wasn't there. i think the poseidon would work on mars too? someone else with the pair would know? hint hint. i would suggest starting with the gazaur 340mm woodies, and keep the HS a bit low until comfortable. (depending on motor/pinion size). what size motor and pinion you going to use? A beintot |
07-09-2011, 09:09 PM | #23 (permalink) |
Hello Apollo7,
Thanks for the info, and you said the Mars is a bit longer in the nose? That works great for a couple of packs I wanted to use, they were a little long. I started a new thread,"New Gazaur build (re-build) I have some other questions posted there. BTW Nice heli! Love the lights!! Can't wait for my maiden,hopefully later this week. Waiting on gyro.
