Like Tree9Likes
Old 09-14-2009, 10:50 AM   #201 (permalink)
I am at work right now, but I could post tonight. I can tell you that I took the cap from a sharpie and cut it down.
gene2197 likes this.
T-Rex 500 ESP GY401/9254, DS510 x 3, Align 425D,Turnigy 6s 2650-3000, Align 500L
T-Rex 450 GY401/9650, HS65MGs x 3, HC CF blades
Blade 400 GY401/9650, HS65MGs x 3, HC CF blades, Zippy 2200 20c x7(shared), Turnigy 2836-3700 Motor, CC35 in Fixed End Point mode, Turnigy 3A UBEC
E-Flite Blade mSR (stock) -- E-Flite Blade mCX (stock)
clkandcjk is offline        Reply With Quote Quick reply to this message
Old 09-14-2009, 04:11 PM   #202 (permalink)
Default 450 Night Blades with MCX Battery
Here are the pics I promised of my first attempt at night blades for my TREX450. I used 4-pin LEDs from RadioShack, copper tape from the doll house section of my LHS, and a ParkZone battery connector. They are so bright that I can't see my glo wire from HK.
ID:	115189Click image for larger version
Old 09-14-2009, 08:00 PM   #203 (permalink)
have ya flown them yet? if so how long did the batteries last?
Originally Posted by clkandcjk View Post
I just finished a set with mcx batteries. First night flight was last night. I even created a battery holder on the blade so I could remove them for charging or replacing.
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote Quick reply to this message
Old 09-14-2009, 08:05 PM   #204 (permalink)
Yes, I flew them last night for 30 minutes and they were not dead yet.
Old 09-14-2009, 08:06 PM   #205 (permalink)
i think ya need higher value resistors in line with the led's to tone them down some.
Old 09-14-2009, 08:08 PM   #206 (permalink)
way cool. i get 60 min out of a charge on my align blades. how many packs was that? my gearing gives me 10-11 min flights on 3s A123.
Old 09-15-2009, 08:06 AM   #207 (permalink)
I flew 3 packs during that half hour. I was messing around in between, but left the blade lights on.
Old 09-20-2009, 02:22 PM   #208 (permalink)
Default FWD Voltage
Does anyone know the FWD voltage on?
Hobby City Blue, Green White?
Hobby City Red?
Xerogear Green, Blue?
Xerogear Red?
I think they are all 20ma, but do not know the FWD voltage.
Thanks,
Jamie
Jamie Dumanski is offline        Reply With Quote Quick reply to this message
Old 09-22-2009, 10:14 PM   #209 (permalink)
Well I am still seeing spots, but readings off the XeroGear strips stock.
2S
Green 2.75
Red 1.85
Yellow 1.95
White 2.65
3S
Green 3.30
Red 1.92
Yellow 2.02
White 3.11
I could not find any blue right now but I think they were running the same as the green.
From my calculations they are running about 15ma so you will need 68 ohm, and 150 ohm resistors if running 1S, that is what I am using.
Mr.HillBilly is offline        Reply With Quote Quick reply to this message
Old 10-31-2009, 06:26 PM   #210 (permalink)
Mudbogger2 thanks to you for starting this topic and for all your ideas / info and to everyone else that's contributed too. I've spent the last week building night blades and getting my first night ship ready, I had my very first night flight tonight and had the greatest time. The home made blades are tremendous and make it easy to perceive the attitude of the heli. On my first flight I was rolling and backward / forward flipping. Can't wait to go again.
Eegie is offline        Reply With Quote Quick reply to this message
Old 11-06-2009, 10:03 AM   #211 (permalink)
I just built a new set of night blades using blue and green LEDs from Hobby City strips. I used one 15 ohm resistor for all three LEDs I put on. It is working great.
2S
Green 2.75
Red 1.85
Yellow 1.95
White 2.65
3S
Green 3.30
Red 1.92
Yellow 2.02
White 3.11
Old 01-20-2010, 12:32 AM   #212 (permalink)
cool
4g3freak is offline        Reply With Quote Quick reply to this message
Old 01-20-2010, 05:18 PM   #213 (permalink)
My night blades I have built. More pics here. Night blades Just scroll down.
ID:	135192   Click image for larger version
ID:	135193   Click image for larger version
thenewguy is offline        Reply With Quote Quick reply to this message
Old 01-30-2010, 06:33 PM   #214 (permalink)
Has anyone ever tried this method of producing night blades on TR blades?
Are there LiPo cells small enough to really make it work? Does the much higher RPM on the TR make problems for this construction method?
-Ray
Fired up!
Ray K. is offline        Reply With Quote Quick reply to this message
Old 01-30-2010, 10:02 PM   #215 (permalink)
-Ray
I'm working on it.
yes
yes
I'll know more in a couple of weeks. Parts are on order.
Jeff Borowski
flyinfool is offline        Reply With Quote Quick reply to this message
Old 01-31-2010, 05:43 PM   #216 (permalink)
ive made about 5 sets, mine i made all internal, good luck, nick maxwell flew them at ircha night fly competition
Team Horizon
merlin3 is offline        Reply With Quote Quick reply to this message
Old 01-31-2010, 09:53 PM   #217 (permalink)
Care to share???
Jeff Borowski
Old 02-19-2010, 08:34 PM   #218 (permalink)
guys ! I dont get this ; how are you getting a positive AND a negative from one piece of copper strip ? you are mounting the LED on the tape which is one piece ! what am I missing ?
SkinWalk3r is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 08:42 PM   #219 (permalink)
Its Magic.......
The positive buss is on one side of the blade and the negative buss is on the other side of the blade. If you look close at the pics you will see that the strip that the LED is mounted to runns around the leading edge to the other side.
Jeff Borowski
Old 03-12-2010, 06:18 PM   #220 (permalink)
subscribe
jongam0 is offline        Reply With Quote Quick reply to this message
