Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters
Walkera Helicopters Walkera Helicopter Support
Old 02-20-2010, 10:46 PM   #1 (permalink)
Default 2.9g Tail Motor
Did a quick search but couldnt find much info...
Does anyone know of a 2.9g tail motor that will work with a cb100? I know of the motors from wowhobbies and other walkera dealers but im looking for something as cheap as possible. Does anyone have a link to something from hobbyking or somewhere similar?
steetyj is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 11:25 AM   #2 (permalink)
There you go...
http://www.chinesejade.com/walkera43BLMotorEsc.htm
Some people have a problem for every solution...
john aeras is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 01:32 PM   #3 (permalink)
You will need a new holder for it as well. I wanted an indestructible one with an indestructible fin for the 2.9g motor on my 4G3, so I bought one from here:
http://www.micro-heli-concepts.com/
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 05:24 PM   #4 (permalink)
Hi All
I have this 2.9g Tail motor upgrade, Chinese Jade also supplies an offset tail motor holder as well. This is a very strong little carbon fiber support that is far more superior to the stock one.
I have mine installed on a solid CF tail boom and run the wires externally. The boom is extremely solid. I think the length or carbon rod was 3 bucks.
The only issue I have with it is securing the tail rotor, the stock motor had a flat edge on one side and also allowed the two little pegs from the rotor to sit in the motor to lock it in. The only way I can get the tail rotor to stop spinning on the 2.9g motor is to apply CA every now and then. (or i could just stop hitting things with it)
Any ideas on a better way to do this would be good.
Walkera CB100, 4G6, 2801 Pro TX
T-Rex 500 ESP
T-Rex 250 SE
Futaba 10CH
Rockers is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 05:42 PM   #5 (permalink)
i got this from him:
CB100 Complete Upgrade Combo
This Combo Included:
1) HP05S Outrunner Brushless Motor (Included mounting screws, 16T pinion, and plug compatible with Walkera Speed Controller)
2) 2.9g Outrunner Brushless Motor
3) Carbon Fiber 2.9g Brushless Motor Holder for CB100
4) 3 Pins Plug
Item No: HM-100-FullCombo
Price US$59.85
with the +3 extreme blades i now get 8+ min of flight.
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote Quick reply to this message
Old 02-24-2010, 05:29 AM   #6 (permalink)
Originally Posted by Rockers View Post
Hi All
Use proper glue?
The 4G3 tail rotor fits very tightly onto the shaft of the 2.9g motor since it's designed to fit on a shaft with a flat side.
Dusty
Old 02-24-2010, 03:38 PM   #7 (permalink)
Originally Posted by Dusty1000 View Post
Use proper glue?
Dusty
I have used CA, should i maybee use some expoxy and try the 4G3 tail rotor ??
Has any one tinkered with making a carbon firbre version of the tail rotor ??
T-Rex 500 ESP
T-Rex 250 SE
Futaba 10CH
Old 02-25-2010, 08:38 AM   #8 (permalink)
great suggestions. I was planning on buying the upgrade kit from chinese jade for 60 bucks. Just wanted to check here first.
Do u guys think the kit is worth the cost? I dont wanna keep breaking tail motors...and i guess its necessary to upgrade the main motor when going to a 2.9g tail?
as far as the solid tail boom...i assume most hobby shops carry solid carbon rod? ill check it out this weekend as i destroyed my last boom a couple days ago.
I also keep destroying canopies...does anyone know if the mia canopy is actually any tougher? or should i just get a few more stock ones?(planning on ordering the mia landing gear as well)
oh and ya...even though i keep breaking the thing I am getting better at flying lol...gonna get my first flight in on my copterx 450 as soon as my batteries arrive
Old 02-25-2010, 10:06 AM   #9 (permalink)
Walkera canopies tend to break so easily.
If you can DIY, cardboard canopies tend to have less weight and tougher. I tend to make streamlined paper canopy templates for my micros that you can print, unfortunately, I don't have a 4G3!
timewerx is offline        Reply With Quote Quick reply to this message
Old 02-25-2010, 11:45 AM   #10 (permalink)
i wish someone made paper canopy's for the cb100 gunna try teses on my 4#6.
Old 02-25-2010, 12:02 PM   #11 (permalink)
wow cool idea on the paper canopies. im gonna have to try to fab one up
Old 02-25-2010, 02:49 PM   #12 (permalink)
Most LHS should stock the CF Rod, I brought the 4mm and machined it down to the correct size.
T-Rex 500 ESP
T-Rex 250 SE
Futaba 10CH
Old 02-25-2010, 09:12 PM   #13 (permalink)
Check out this link... all you need is a color printer!
http://www.rcgroups.com/forums/showt...asm+4g3+canopy
Old 02-26-2010, 08:44 AM   #14 (permalink)
ok now that is awesome...will these fit on a cb100? or will it need to be resized?
edit- looks like it will need resized and/or trimmed but I can prob make it work
Old 02-26-2010, 09:34 AM   #15 (permalink)
You can try mine. But I made it for the 4#3B, same size as the CB100 but still I'm not 100% sure if it will fit. Of course, artwork needs changing too But it's better if you're also looking for performance because it's streamlined - less drag on the rotorwash will even give you more lift and longer battery life.
https://www.helifreak.com/showthread.php?t=187311
