Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 09-02-2014, 06:36 AM   #1 (permalink)
Default Aileron Differential ?
Can someone explain Differential as used in a DX6I or DX7S.
My parkzone Spitfire (44") has a very quick roll rate and I want to see if I can slow it down.
Will using diff help ? and if so values to start with ?
Nigel.
A few little tiddlers ..SR, 300X, TRex 500E Pro with DFC, Trex 700DFC..... and quite a few Planks and Tanks !
nbells is offline        Reply With Quote Quick reply to this message
Old 09-02-2014, 06:41 AM   #2 (permalink)
Member
Differential is not used for roll rates. Sorry, headed to work. Someone else will chime in to help out I'm sure.
Sent via phone
Old 09-03-2014, 11:12 PM   #3 (permalink)
I'd use the dual rates to tame it down. It's what I do on my other planes.
And by the way, I just picked up a used PZ Spitfire myself yesterday. Hopefully I'll have a chance to maiden it on Saturday.
TexanPilot is offline        Reply With Quote Quick reply to this message
Old 09-03-2014, 11:35 PM   #4 (permalink)
Differential is used to vary the control surface movement in the up and down directions...
Usually used on gliders to decrease drag or unwanted yaw interaction by having aileron travel limited on the downside of the wing.
Dual rates are the best solution and travel adjust / endpoints are the second. In my experience, planes also tolerate high expo rates (40%) without problems.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 05:02 PM   #5 (permalink)
Aileron differential is also for non aerobatic planes like Cubs. In a banking turn differential is used to have more up aileron on the inside wing and less down aileron on the outside wing. What this does is cause more drag on the inside wing which assists in the turn requiring less or no rudder. You wouldn't want differential in an aerobatic plane.
700 size scale Bell Jet Ranger 206BIII, 450 size scale UH-1N, 180 size fpv race/freestyle quad w/Fatshark Dominator V3 goggles, mCPX BL, some edf jets and a plank or two, DX8, AMA# 923167, Clubs: Silver Hills RC, Coeur D Alene Modelers Association
JasonJ is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 10:18 AM   #6 (permalink)
That is so not true. You need to watch this video to see what differential does. http://www.modelairplanenews.com/blo...how-to-use-it/ The aerobatic plane part is not true.
cyjonz is offline        Reply With Quote Quick reply to this message
Old 09-13-2014, 03:49 AM   #7 (permalink)
Aileron differential is to help prevent adverse yaw caused by the drag of the ailerons.. Typically you set it up with more "up" aileron than "down" aileron.
-Kevin
Skiddz is offline        Reply With Quote Quick reply to this message
Old 09-13-2014, 12:30 PM   #8 (permalink)
My planes are all set up with 40-50% less down.
