Old 12-03-2008, 07:17 PM   #21 (permalink)
Hi,
Can they be used on these cnc blade grips (Sonix)?
Helihabit is online now        Reply With Quote Quick reply to this message
Old 12-04-2008, 06:33 AM   #22 (permalink)
Originally Posted by Helihabit View Post
Hi,
What is the thickness of the blade grip at the blade bolt?
HEIM JOINT
HEIM JOINT is offline        Reply With Quote Quick reply to this message
Old 12-04-2008, 07:18 AM   #23 (permalink)
Hello HEIM JOINT,
The thickness is 0.453 Inch (11.5mm.). When the blades are in and the bolt/nut is thightened it's 0.433 Inch (11mm.).
Thank you.
Old 12-04-2008, 07:19 AM   #24 (permalink)
HEIM JOINT
I bought Heim Joint's kasama and stock bolt mods, the stock ones worked the best.
T-Rex 250 super combo
T-Rex 450 PRO - I love this little guy! T-Rex 450 SE V2 - Sk360 in Airwolf fuselage
T-Rex 500 Blinged to the extreme - Sk360 - Gy401/S9257 - 5045MGs
T-Rex 600 LE - KDE everything, waiting on RL53
Raptor 50 eCCPM 140- QuickUk everything - G7703D/S9254 - S9252s - RedLine53
Gutaaaooo is offline        Reply With Quote Quick reply to this message
Old 12-04-2008, 07:32 AM   #25 (permalink)
Hello HEIM JOINT,
Thank you.
The Align metal set would fit and be the best balance.
HEIM JOINT
Old 12-04-2008, 08:02 AM   #26 (permalink)
Thanks! PM sent. Edit: Paid ;-)
Old 12-05-2008, 06:50 PM   #27 (permalink)
Originally Posted by saltyzoo View Post
Bob, I have a question for you.
Based on the evidence presented it seems obvious that the mod works and works very well.
So the question is, with this mod being fairly commonplace on the net for at least a year, why do you think none of the latest released helis have implemented this design yet?
MSH Protos has Chinese weights integrated into the tailgrip design. It would be very interesting to see Heim Joint's precision measurements on the stock Protos tail.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 12-06-2008, 10:19 AM   #28 (permalink)
Hey Bob, could you check and see if these will fit through the tail grips on the Atom. I'm pretty sure they are the same size, but I was wondering if you could see if they will work with the Atom grips before I go out and buy a set. You are the only person I know with both an Atom and a T500
Trex 450 w/ Flybarless G5 Head - SK360/Digital HS5065MG - Spartan/3500g - 14T Medusa 3400kv - CC35/Set RPM - 3000rpm
Compass Atom 500 - JR Z3650s - Spartan/3500g - 9T pinion 100% Flat on Stock Motor...for now...
Compass USA Rep
simon021 is offline        Reply With Quote Quick reply to this message
Old 12-06-2008, 10:31 AM   #29 (permalink)
Team Taco VP
I'll check it out this weekend.
Bob
Old 12-06-2008, 05:21 PM   #30 (permalink)
Heim Joint,
R u going to working on some weights for th etrex 250?
Barry
mainblades50 is offline        Reply With Quote Quick reply to this message
Old 12-07-2008, 01:18 AM   #31 (permalink)
Team Taco VP
TRUST ME! After doing and playing with the 250 today! It is in DIRE need for a tail weight mod!
I am not kidding and I SHOWED this to Align today... The tail STOCK is worse than a 450 SE as far as servo forces go..... SERIOUSLY...
More playing with this soon so stay tuned but I think after the demo I did today...... We may see more balanced grips soon... Wanna bet ?
Bob
Old 12-07-2008, 04:28 AM   #32 (permalink)
So does the MA Furion
John
Old 12-07-2008, 06:57 PM   #33 (permalink)
Default Trex 500 Stock Blade Grips
HEIM JOINT has done a great job on his research and product. I finally put a set of his handy work on my Trex 500 with stock blade grips and wow what a difference. The piro rate is much faster and I had to reduce the gain I had on my GY401.
Tennessee-drifter Heli is offline        Reply With Quote Quick reply to this message
Old 12-08-2008, 02:20 AM   #34 (permalink)
The TREX600 uses the same bladegripps as the 700.
But the tailblades on the 700 are bigger.
Can i still use the 600 mod on the 700, even if it may be off a bit.
And can I use anything for the Bade400? (indoor play thing)
wrobijns is offline        Reply With Quote Quick reply to this message
Old 12-08-2008, 06:34 PM   #35 (permalink)
Originally Posted by mainblades50 View Post
Heim Joint,
Barry
They are designed and tested, I havent posted the results yet because thanks to finless I cant make these fast enough.
I also made an upgrade for the blade grip with a bearing spacer set that takes all the slop out of the t250 blade grips. those should be ready in about a week.
The pushrod forces with new blade grip bearings and the chinese weights is less than 2.5 oz.
I have video posts on all the above that I will post on the T250 forum.
HEIM JOINT
Old 12-08-2008, 06:37 PM   #36 (permalink)
The weights are signifigantly different between the T600 and T700 because of the blades. I have them designed and tested for both the stock plastic and Kasama grips in both 600 and 700 sizes.
I will post the test videos In thier respective forums They will be ready to ship in less than 2 weeks.
HEIM JOINT
Old 12-08-2008, 08:36 PM   #37 (permalink)
Default Link to T250 Chinese weights
Post of the Chinese weights for the T250
https://www.helifreak.com/showthread...879#post997879
HEIM JOINT
Old 12-09-2008, 03:23 PM   #38 (permalink)
HEIM JOINT
Robin, you da man.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote Quick reply to this message
Old 12-09-2008, 05:44 PM   #39 (permalink)
HEIM JOINT
I am waiting on a set of weights and spacers. SAVE ME A SET!
U THE MAN!!!!
LOL
Barry
Old 12-10-2008, 03:07 AM   #40 (permalink)
Are those the weight mods at the base of each blade grip? I love my furion but didn't know if it needed a kit. I was going to do some testing this weekend.
SDGeo is offline        Reply With Quote Quick reply to this message
