Old 11-16-2016, 05:45 PM   #1 (permalink)
Default I think my head speed is too low?
So i was checking my telemetry logs and noticed i'm not even hitting 3000 rpm on my head speed. Is my gearing off? or is this just tired batteries?
the first 3 flight are 3300mah zippys with lots of flights and the last 2 are 5000mah with only like 3 flights on the batteries.
i'm running zeal 430mm don't know if that would make any difference or not
oh yeah this is a trex 500 dfc pro
Name:	TEST FLIGHT 1.jpg
Blade 300CFX, 450. Align: 450pro(3S), 500(6S), 600E(12s), 600N, 800E(12S). X-cell: Ion700(12S)
HELI_FUN is offline        Reply With Quote Quick reply to this message
Old 11-16-2016, 05:48 PM   #2 (permalink)
Old 11-17-2016, 01:27 AM   #3 (permalink)
5000MAH lipos in a Tex500? Does it even lift off? LOL. Heaviest I've ever flown with were 3300 and I didn't like the weight. Changed to 2600 and its lovely. Most pilots are using 2600 or 3000 on the Trex500.
You havn't provided any detail about your setup so your question about the headspeed cannot really receive any useful answers.
Allan
Old 11-17-2016, 11:49 AM   #4 (permalink)
what else would you like to know. I have battery, blades, model
motor - stock
esc - stock
gearing - umm stock?
gear ratio in TX - 11.14
motor - 6 pole
FBL - spirit pro
the 5000 make it sound bad ass when you pitch pump. the 3300 fly great but then again that is all i have ever flown
Old 11-18-2016, 01:43 PM   #5 (permalink)
[QUOTE=HELI_FUN;7188371. the 3300 fly great but then again that is all i have ever flown[/QUOTE]
The 3300 is what balances best on my fb 500
2600 is too light and it winds up tail heavy.
Sometimes I throw in a 4600 for additional stick time and it's nose heavy to the extreme with that!
aldrichg9 is offline        Reply With Quote Quick reply to this message
Old 11-18-2016, 02:19 PM   #6 (permalink)
3000 is the best for the 500 IMO
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is offline        Reply With Quote Quick reply to this message
Old 11-18-2016, 02:51 PM   #7 (permalink)
i'm sure the 5000 would work good for speed runs since it's already front heavy and wont be going up side down
Old 11-18-2016, 02:52 PM   #8 (permalink)
I think i might play with the motor timing and see if i can get some more rpm out of it. that or i need a different motor pinion
Old 11-18-2016, 08:51 PM   #9 (permalink)
Not sure what you are looking for, but 3000 is a very high head speed for 500. Take a look at the threads above on set-ups
MCX2, 120SR, Blade 4503D w/Robird G31, Trex 500 w/RC Aerodyne A109 Scale Fuselage, 2X Trex 500's, Trex 550 w/ BD3SX, 2X Goblin 570's, 2X Goblin 700's w/BD3SX DX6i, DX9, Phoenix Sim, and a credit card. HF member #178,534, AMA
danfornow1 is offline        Reply With Quote Quick reply to this message
Old 11-21-2016, 12:39 PM   #10 (permalink)
I asked about head speed in a different tread before got everything from 2900 to 3100.
Old 11-21-2016, 12:40 PM   #11 (permalink)
looks like im at 2100 rpm in normal 2500 RPM in IU1 and 2750 in IU2
Old 11-23-2016, 01:26 PM   #12 (permalink)
2900 is all you need on a heli this size. I never used as much HS when i was doing 3D with mine.
Also the small tail blade grips bolts make this heli quite suscetible to failure at high HS, specially if you have vibes.
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 11-23-2016, 01:27 PM   #13 (permalink)
Yeah my 470 is nuts at 3000rpm and it's quite a bit smaller (380mm). Surely 2900 is plenty on a 425mm heli.
Old 11-23-2016, 02:10 PM   #14 (permalink)
i guess my head speed is where it needs to be, I just remember some people going up to 3100.
With all the main blade failures at high head speed plus the tail like said in a previous post I think ill just stick with what i got.
Thanks for the reply guys
Old 11-23-2016, 02:21 PM   #15 (permalink)
How many degrees of pitch do you have?
Old 11-23-2016, 02:23 PM   #16 (permalink)
i think around 12.7 + / -
might take it up to 13.5 and see how that does, I would need to manage collective well because it can be loaded down some what ez on the 3300 mah battery
Old 11-23-2016, 02:33 PM   #17 (permalink)
The 500 is pretty heavy, I'd run 13+ if it were mine. 3300 is pretty heavy, too, making the problem worse.
Old 11-23-2016, 02:46 PM   #18 (permalink)
ok so more pitch and some lighter batteries and it should come alive. Thanks for the help.
Maybe I will go with some 3000 or 2800mah
Old 11-23-2016, 03:55 PM   #19 (permalink)
3000 is a good match. I'd even say 2600-2650 would work too, but watch your flight time. The original 500 flew with 2600s but the Dominator has a more powerful motor.
Old 11-24-2016, 04:35 PM   #20 (permalink)
I used to run 2600 packs, and a buddy of mine flying low RPM preferred 2200, on a very light 500, the old ESP with plastic main bearing blocks.
T500 AP
