Old 12-14-2016, 06:20 AM   #21 (permalink)
Originally Posted by pril250 View Post
Yes I use the Spektrum DX7 and AR7000 which works well for my needs. It is funny the FM helps novices but requires you to be an expert to install and setup properly
Im guessing that 6 channel controller will still be ok ?
Dont want to buy something that wont be any good lol.
If need the 10 channel then will have to save up !!
karlos103 is offline        Reply With Quote Quick reply to this message
Old 12-14-2016, 06:57 AM   #22 (permalink)
Been looking at few more controllers.
We have -
Flysky i6 - 6 channel ( £43 )
Walkera DEVO 7 - 7 channel ( £44 )
Flysky i10 - 10 channel ( rough £140 )
Flysky FS-TH9X - 9 channel ( £66 )
or this on ebay ..bidding - Turnigy 9ER Pro with receivers.
this one buy it now - £80 = postage with reciever.
any thought ?
Cheers
Karl
Old 12-14-2016, 07:20 AM   #23 (permalink)
Originally Posted by karlos103 View Post
For some reason i sent a reply last night to this but has not come through ...so what i asked it -
is the setup you have ...gears wise ...a good combination ? and what is the 0.7mm at the end ?
Also noticed they do slanted gears ....what best to get ....straight or slanted ?
Have ordered the 25mm shaft motor ...only £31 from china ...bargain :-)
Cheers
karl
The "0.7M" is the "module" of those gears, a measure for the size of the teeth. The smaller that number the smaller, finer those teeth. Pinion and main gear have to have the same value, of course.
Slanted gears use 1.0M, so those gears are beefier than my 0.7M. That's a good thing because the larger that value the less likely they will strip (never had that problem anyway, though).
I would just get the pinion type that matches the main gear that's already on the heli. You can always convert to slanted gears later on if you want to.
getsuyoubi is offline        Reply With Quote Quick reply to this message
Old 12-14-2016, 07:21 AM   #24 (permalink)
If you are stuck on Flysky so I guess the 9ch sounds ok.
Blade400
pril250 is offline        Reply With Quote Quick reply to this message
Old 12-14-2016, 07:25 AM   #25 (permalink)
We have -
any thought ?
Cheers
Karl
You could also look for a used JR DSMX radio. That's the same protocol as Spektrum, which is the most popular one, while the build quality is fantastic. I have a JR X9303; I believe the model name is different in Europe, but you should be able to find out the corresponding European model on Google.
Old 12-14-2016, 07:40 AM   #26 (permalink)
no ...not stuck on Flysky ...
Looking at the Turnigy now lol
Old 12-14-2016, 07:43 AM   #27 (permalink)
Ok ...will see whats in heli when get it ..
Many thanks
Karl
Old 12-14-2016, 07:46 AM   #28 (permalink)
Its the Turnigy 9XER Pro
http://www.ebay.co.uk/itm/2919692003...%3AMEBIDX%3AIT
Are these any good ?
Old 12-14-2016, 07:55 AM   #29 (permalink)
Or just look for good second hand spectrum dx7 ?
But what receiver to use with it and how much ?
Cheers
Karl
Old 12-14-2016, 08:17 AM   #30 (permalink)
Basically after something goodish… but not mega bucks ..spectrums seems to fetch good money ..plus have to get receiver… the turnigy need receiver if by new but that should be around £110 all in .
There is also the frysky taranis which is supposed to be good .
Choices… .choices lol
Good job in no rush to get one as every time I find one I want ..I find something better lol
Old 12-14-2016, 11:27 AM   #31 (permalink)
If you get a Spektrum (or JR DSMX) radio take a look at Lemon RX receivers. They cost a fraction of the Spektrum ones and are supposedly very good quality. I replaced the Spektrum satellite on one of my helis with a $10 Lemon one, and it just works.
Old 12-14-2016, 11:41 AM   #32 (permalink)
The receiver you will need with a DX7 would be AR7100+Satellite, will be nice if you can find a second hand pair.
RX inc satellite.
http://www.ebay.co.uk/itm/Spektrum-A...UAAOSwEzxYOuXo
Good Deal but no satellite....
http://www.ebay.co.uk/itm/MINT-Spekt...AAAOSw2xRYRHDn
Blade400
Old 12-14-2016, 01:46 PM   #33 (permalink)
ok just won me a spectrum dx7 for £74.60 delivered .
Second hand but looks fine ...is that cheap ?
So what receiver do i need ? lol
Karl
Old 12-14-2016, 03:13 PM   #34 (permalink)
RX inc satellite.
ok ...just read your post lol ...ok so will def look into the second hand one :-)
thank you
Old 12-14-2016, 03:23 PM   #35 (permalink)
Right ...bought the receiver and satellites for £43.50 ...
So all in all its cost me £118 for the setup ...is that a good price ?
http://www.ebay.co.uk/itm/Spektrum-D...p2047675.l2557
http://www.ebay.co.uk/itm/322341554160
Old 12-14-2016, 03:54 PM   #36 (permalink)
You have done very well there, I hope the DX7 comes with a battery and charger.
If not
http://www.ebay.co.uk/itm/1221555317...%3AMEBIDX%3AIT
Blade400
Old 12-14-2016, 04:26 PM   #37 (permalink)
If not
Yes by the looks of it ...Ni-MH 1500mah 9.6v battery and mains adaptor.
By the sound of it ...this is one of the better controllers ....all i need now is the heli to arrive lol
cheers
karl
Old 12-14-2016, 04:44 PM   #38 (permalink)
Blade400
Old 12-14-2016, 04:47 PM   #39 (permalink)
Old 12-14-2016, 05:09 PM   #40 (permalink)
One piece of advice, if you intend to buy and install the Flymentor, by all means do it but first have a perfectly setup heli that is capable of flying, once it is all sound then you can proceed. I know that does not make great sense and all sounds back to front but so is the nature of the beast.
Blade400
