Old 01-03-2017, 08:30 AM   #1 (permalink)
Default Help to set curves for T-Rex 450 Flybar
Hello
I am a picking up my 450 Flybar tomorrow
I need help setting my pitch and cyclic curves please, I am a beginner at helicopters, I have never done this considering I only have a Blade 230 S and it is RTF
For the throttle curves I was thinking about:
Idle Up 1
100
70
37
0
37
70
100
Idle Up 2
100
83
50
0
50
83
100
Could you help me please?
gb48301 is offline        Reply With Quote Quick reply to this message
Old 01-03-2017, 09:16 AM   #2 (permalink)
This link to a PDF manual is for a 450 Sport V2 flybar Align. May be similar to your helicopter. Check out page 20. I'd start with those curves.
http://rvmhc.com/manuals/450%20Sport...20kx015081.pdf
If you need help programing your transmitter, that is a different question. Which transmitter do you have?
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 01-03-2017, 10:03 AM   #3 (permalink)
Hey,
I have a DXe transmitter. With the DXe transmitter you need a programming cable to create a new "slot" for an other model you'd like to fly with the DXe. If you have a Tx to audio cable, you can then transfer the info to the DXe programming app, and easily switch between your models via Bluetooth.
I don't have that so if, say, I fly my 230 S, then want to fly the 450, I will have to plug the DXe into the computer to switch between the two models.
What I am trying to do here is find how to program my transmitter for the 450 in particular (so that my 230 S won't have the same curves and settings).
I don't know if I am clear, I hope so! 🙂
Old 01-03-2017, 11:15 AM   #4 (permalink)
You are going very drastic in your rpms. Also, in idle up you should never ever have a zero. You're motor will die and then start up again when you go inverted.
Try this
Normal
0-80-80-80-80
Idle up 1
90-80-70-80-90
Idle up 2
100-90-80-90-100
Try not to have big huge jumps in your rpm's. The heli will shoot up. I try not to have more than a 15 percent jump in throttle.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 01-03-2017, 11:39 AM   #5 (permalink)
I'm not familiar with the DXe, maybe someone else will chime in here.
Old 01-03-2017, 02:21 PM   #6 (permalink)
@newbheliusr, If the model is going to be spooled up in normal mode for lack of a soft start governor would it be better to make the second point 40 to allow a bit more control?
If the ESC has soft start and no governor then I maybe wouldn't bother with a traditional normal type curve.
If the ESC has a governor then all curves would be straight lines.
My approach for some time now has been to move collective to near mid stick or a little negative pitch on blades to remove load and then just flick out of throttle hold.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 01-03-2017, 03:23 PM   #7 (permalink)
Yeah, 40 probably sounds better. But definitely not 0 throttle at mid stick. That's a crash.
Heli's I have:
Old 01-03-2017, 04:44 PM   #8 (permalink)
Okay, that sounds absolutely logical newbheliusr. Thanks for the info, I feel like every day on this forum I learn something new 😅
Alright, I will try those throttle curves when I get the helicopter tomorrow.
Thanks a lot for your answers guys. For the rest of the settings I will use the helicopter manual's recommended settings.
Old 01-03-2017, 04:50 PM   #9 (permalink)
If you want, feel free to PM me if you have any questions. I am by far not the gospel for rc helicopters. But I can get you started. If not, that's ok too.
Heli's I have:
