Hurricane 425 Discussion and support of the Gaui Hurricane 425 |
09-16-2012, 11:30 AM | #81 (permalink) |
here is mine
having hard time with pictures upload
09-17-2012, 04:28 PM | #82 (permalink) |
flybarless and all !! good stuff gimballina jolie
-roger OriginHobbies.com OMPHOBBY RADIOMASTER GAUI MSH-Brain2 SCORPION dealer (FI/EU) |
09-18-2012, 06:37 PM | #83 (permalink) |
mine
this is mine and its for sale....
plus a few other stuff i have |
12-01-2012, 01:10 PM | #84 (permalink) |
My new (to me) Gaui 425 with the quick paint job I threw on it. I plan on trying some fancy stuff this winter with an air brush, but I just wanted to get something on the stock canopy to get in the air. The stock canopy is actually pretty easy to put together, I found the Testors orange plastic model cement worked perfect.
The theme is "Visibility": Ya, the monocote trim sheet I used on the tail is not a perfect match, but I think it will work. Next time I am in St Louis I will head by Mark Twain Hobby and see if I can find a better match in person. I was able to do a test flight this afternoon, it flew great. A couple of twist of a link to get the blade tracking in and a bit of trim and it would hover without my thumb on the cyclic. Wow 500 class rocks! EDIT: Here it is with the boom and tail blades painted. It looks much better I think.
Gaui Hurricane w/ 530mm blades & Robird G31 Walkera Super CP Walkera Devo 10 w/ Deviation Last edited by SQRT(-2); 12-05-2012 at 06:12 PM.. |
01-09-2013, 10:17 AM | #85 (permalink) |
I just wanted to share the Gaui FBL and with new wiring.
I made a bottom plate in the body with plywood, I drilled a hole in it and put a thin plywood bottom that slid between the skids and the frame. I hid all the coils of wire between these two bottoms.
Gaui Hurricane w/ 530mm blades & Robird G31 Walkera Super CP Walkera Devo 10 w/ Deviation |
02-04-2013, 06:26 PM | #86 (permalink) |
Thank you PTcaflyer! Got it put together this afternoon... Now to learn what I need to look over and check out before the first flight.
02-04-2013, 08:12 PM | #87 (permalink) |
HF MR Support
You are Welcome!
You will have fun and soon you too will have the"Gaui Grin"!!! PT
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1 AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD |
02-05-2013, 08:10 AM | #88 (permalink) |
Awesome job with the wiring. I also see that you have made your own flybarless head out of the original 425 head. How is it working out for you? Would love to know how you made it .
cheers,
02-05-2013, 08:19 AM | #89 (permalink) |
Works just fine for me.
I ran the Jesus bolt through the flybar seesaw bolt hole to lower the head. The links I made out of threaded rod. I bet you could find a rod that is the correct length, but I could get the threaded rod local. The extensions are these: http://rcdumbthumbs.com/G-204706.aspx For the swash follower you can mod the FB ones our use this: http://rcdumbthumbs.com/G-204707.aspx I imagine a Trex 500 FBL head would also work, Tarot has one for $45 http://tarot-rc-heli.com/Tarot_RC_He...less_Rotorhead EDIT: Sorry, man did not see you were in Finland there. I don't know where to get those in Europe, but I bet you can figure it out. I'll keep the links to where I know to find them so you can see exactly what I am talking about.
02-05-2013, 02:44 PM | #90 (permalink) |
I di dthe same mod for my 550 - I used some rods that I had for the swash to grips - they are either the cyclic servo to swivel links from the Gaui 550 / 435 or from a Raptor
02-05-2013, 06:54 PM | #91 (permalink) |
Gaui 425
I like this... are parts hard to get?
02-06-2013, 03:33 AM | #92 (permalink) | |
cheers,
02-12-2013, 02:03 PM | #93 (permalink) |
Slighty off topic here, but I came back to this thread just to see SQRT's FBL setup. I have also read that the Trex 500 FBL head is a direct fit to the stock main shaft, anyone see any reason why the Trex 500 DFC head wouldn't work either?
02-12-2013, 08:57 PM | #94 (permalink) |
DFC uses a shorter main shaft. (I think.)
04-06-2013, 11:28 AM | #95 (permalink) |
My gaui 425 before my first take off (boom is medium boom but blades are 425mm)
Hacker A40-12S 1350kv CC ICE 75 Futaba S3152 on cyclic and BMS 661DMG on tail 2 lipos turnigy 3S 3000mAh 30C I bought it on ebay (no motor and no esc) nearly 18 monhs ago And I did not put the canopy for the flights |
04-06-2013, 01:40 PM | #96 (permalink) |
Looks great...love that canopy!!
Blade QX, Align Trex 500, Gaui 550 Hurricane, HK600GT, 450 Quadcopter I have a perfect record in helicopter flight......I've never left one up there!!!!! |
04-06-2013, 01:47 PM | #97 (permalink) |
HF MR Support
Looks Great! Those canopies are collector items!!
Try bumping that gyro gain up at least 10% and go to 500mm blades...!PT
