Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
10-28-2013, 01:38 PM | #1 (permalink) |
which bec should I run between this two on my setup?
*which bec should I use with this setupI have two bec in mind the jeti sbec 40amp our the new hv2 my setup on logo is 4530-500kv with yge160 and bls sbus 175hv and bls256hv on tail I want the most outta my servos so I was thinking the hv2 its small like the look and can get a monitor with it but I also like the jeti what do you guys think?**********
10-28-2013, 10:12 PM | #2 (permalink) |
I bought the hv servo's so I could eliminate another electronic part ( potential failure )
I was reading a thread about the futaba hv servo's and that they're rated for a 2s lipo ( that quickly drops off a bit in voltage ) and aren't 'rated' to be used with 8.4 regulated. This is where the new WR super bec's that have a 8.2 option came into play. http://rcflightstore.com/product_inf...oducts_id=4795 Then on the other hand kyle flew his 700 at 5.6 volts for about 30 flights before they realized it wasn't set to 8 volts. I recall they reduced the voltage for programming a piece. So if kyle can lay down a XFC beating and hardly tell the difference from 8.2 to 5.6 Running a 2s lipo with the skim charge off the top , I have no chance of ever knowing the difference. So for me , I took the less electronics route . Martin
Logo XXtreme 800 8917 / 256HV VBC Logo XXtreme 700 on 14s 8917 / 256HV VBC NEO Logo XXtreme 770 14s 8917/9188 VBC Logo 600 8917/ 9188 4035-500 VBC NEO |
10-28-2013, 10:28 PM | #3 (permalink) |
I know that you did not mention this one, so I hope that you do not mind my pointing it out:
http://www.western-robotics.com/herc...BECPRO_hp.html 16 amps constant with a 22 amp peak, and bus architecture so that you can actually deliver all of the available amperage to your servos. I will be installing one myself, shortly.
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
10-30-2013, 11:34 AM | #4 (permalink) |
I'm using the WR Hercules Super Bec G2 and I'm very happy with it...
My servos are JR8717HV and MKS980HV.. I was tired of having another battery to charge and decided to go with the WR bec.. |
11-01-2013, 06:15 PM | #5 (permalink) |
not a bec ! but a switched system.
I use an emcotech 5.9or 7.2 volt switch. really small. http://shop.rc-electronic.com/e-vend...=6&c=541&p=541 |
11-01-2013, 08:31 PM | #6 (permalink) |
There is no need in getting the enormous Jeti BEC, or anything super expensive. Futaba BLS servos are ridiculously efficient. Your constant amperage even in wild 3d flight will only be around 7 or 8 amps with very few peaks that break 12 amps. That is about 2 amps over what I have seen with the set of 157hvs and 256 hv using the log built into the Jeti Mezon 130. I added 2 amps because the Logo is a bigger heavier machine and I don't fly super hard, but hard enough to put some stress on the servos.
Protos Max 700 Vbar, Synergy E7se Vbar, Rush 750 Vbar, Gaui X5 Vbar, Gaui X4II Vbar, Protos 500 Vbar, Compass Warp 360 Vbar, Gaui X3 Robird Controlled by: Jeti DS-16 |
