Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 01-07-2012, 11:32 AM   #1 (permalink)
Default Layout Not the Same as Manual
I recently purchased a Velocity 90 and towards now as I am getting ready to install the servos/electronics I am noticing some things are different than in the manual.
The big difference in the layout of the servo locations. On the right side of the helicopter (looking at it from the front) the servo layouts are as shown in the manual. However on the left side they are setup differently. I will attach a picture showing my difference.
I also was looking in the picture section and the layout on the left side is different then the ones I see in the picture section.
The main issue with this is how I fit two servos in directly apart from each other? There is not enough room.
Thanks for you help.
Chris
Pic: You will notice at the top of the helicopter the servo mounts are right across from one another as where in the instruction manual it is located underneath and to the front of the helicopter a little which I circled in black.
ChrisRCHeli is offline        Reply With Quote Quick reply to this message
Old 01-07-2012, 09:30 PM   #2 (permalink)
Looks like you have two left side frames, the throttle is a vertical opening and is on the left side of the heli, I look at the helicopter from the rear what you are showing in your picture is a left side frame mounted on the right side of the machine.
In the manual the right side frame has a horizontal opening for the tail servo in the middle front section with horizontal slots cut in the frame below the servo.
The picture you posted definitely shows 2 left side frames mounted, you need to get a right side frame, if that is how it came in the kit, contact your dealer and advise them your kit had (2) left side frames and you need to get a right frame.
It doesn't appear that your that far along so changing out the right side should be a snap and you'll be back in business.
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 01:32 PM   #3 (permalink)
Thanks for your reply, I will contact my dealer and let them know of the problem, an yes changing out the right side of the frame should be no real problem at all thank you!
Chris
