Blade 500X Blade 500X Helicopters Information and Help |
03-18-2016, 06:06 AM | #1 (permalink) |
Battey for 500x
I am using glazier 30c 3000mah. They are always out of balance.
High cell 4.3 low cell 3.9 others 4.1 to 4.2. One is lightly puffed. They do ok with around 4 minutes, light 3d. I have 3 of them and they are all about the same. What are some of u using? Jim Last edited by jmurray74; 03-18-2016 at 06:07 AM.. Reason: add comment |
03-18-2016, 06:15 AM | #2 (permalink) | |
What charger are you using? I don't recommend the stock charger and could be the source of your problem. I'm running glacier 3000s and they balance perfect after 2 years of use. |
03-18-2016, 07:44 AM | #3 (permalink) |
I am using a thunder charger TP-1010c.
03-18-2016, 05:07 PM | #4 (permalink) |
How are you connecting? Balance board or direct? How are you connecting the balance cable? Are you charging in balance mode? I believe TP has a different balance connector so I assume you're not connecting the balance cable directly to the charger. |
03-18-2016, 06:01 PM | #5 (permalink) |
Using a balance cable and cord to the battery.
Jim |
03-19-2016, 11:25 AM | #6 (permalink) |
I have been using the same 3 Turnigy's for the past 2 years
Looking to buy batteries this spring - had been leaning toward the Glaciers
Jerry P - 180CFX, OXY3, X3, 500X, TT 550E |
03-20-2016, 05:02 AM | #7 (permalink) |
I didn't realize my charger would show the voltage(I am still learning).
The charger shows the batteries in balance, but my voltage checker always shows cell 4 high. Tried a friends checker and his shows the batteries in balance, so it looks like my checker will not check a 6s correctly. It shows all my 3s as in balance. I am going to check the 6s today with a multi meter, to see what is correct Jim |
03-23-2016, 10:29 PM | #8 (permalink) |
I use the Glacier 3000mAh 30C in my 500X. I also use Glacier 3 cell in my 450. I don't do 3D, but I do like to fly fast and hard.
They come down pretty warm and usually swelled up a bit. When they cool, I can tell it's just the wrap stretched out that makes them feel puffed. They all still balance very well, if I balance charge. If I use the normal or fast charge they'll be within 0.020 to 0.040V. |
03-24-2016, 02:55 PM | #9 (permalink) | |
Actually I retired one before, making 5 of them total. It had a hole poked in it, so I retired it, but still was reading great electrically. Just didn't want to push it with a $500 Heli. |
