Old 12-31-2014, 05:40 AM   #481 (permalink)
Originally Posted by Ph@cops View Post
I hope you get her up and flying soon!!
Thanks, that photo is old. Been rebuilt a few times since then.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 05:29 AM   #482 (permalink)
Hi all,
Could anybody please share their VBar tail advanced settings for the 690sx? I'm having a small ccw 5-10 degree tail kick on hard positive punch outs and I just cannot get rid if it... Played with the gains, acceleration and pre comp as per Mr Mels vids with no luck.
Running stock blades with 12 degrees of pitch, stock motor and a 120A scorpion commander ESC with active governor.
Many thanks for your input!!!
Ph@cops
Ph@cops is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 06:45 AM   #483 (permalink)
Sounds like something i have seen many times when the headspeed drops on the punch - which governor are you using?
If its a passive one (especially Castle...) - change to Vbar gov.
If its Vbar - first check your gearing with mr mell calc. you want to be closer to the "+ performance".
check your gains and precomp for the governor before trying to fix the tail.
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 07:14 AM   #484 (permalink)
Thanks Omerco, good suggestion. Right now I am using the Scorpion gov. I will deactivate it the next time I am out and fly with a V throttle curve. If that gets rid of it I will move on to the Vbar gov, I am told it is very good.
On my 450L, however, I also run with the esc gov and I do not see this effect...
Ph@cops
Old 01-10-2015, 08:45 AM   #485 (permalink)
Managing torque in a 450 is a very different thing from managing it on a 700. The easiest way to get a perfectly performing tail is to turn off all precomp in the gyro and tune the governor by itself. Once the tail is as solid as you can get it just with gov tuning, then move to tail precomp to iron out any remaining bad tendencies (especially in tic-tocs where you're mixing in a lot of cyclic.)
I would suggest just running the vbar gov. There is really no way the scorpion governor could do a better job. Only downside is the need to run a phase sensor.
Team MikadoUSA
Old 01-10-2015, 09:09 AM   #486 (permalink)
V courve will not solve your problem, if it is the one i reffer to. Actually it will probably get worse.
You need a good reactive governor able to hold the rpm well when you give sharp pitch command. What happens is the torque goes up but rpm drops causing drop in tail rotor rpm and some lose of authority, usually short until the rpm recoveres.
You could try higher gains with scorpion, but best go Vbar gov. You will need the opto cable to connect to the vbar.
P.s. im using skookum governor but on my first 2 flights on the 690 I lowered the governor gain so it will not interfere with the tail while i tune it. This caused small similar phenomenon. I just tune the tail gain and only after the governor is solid i adjust the precomp
Old 01-11-2015, 02:48 AM   #487 (permalink)
Thanks for the advice. I will get myself the opto cable and give it a go. I am sure the VBar gov is miles better than the reactive scorpion gov.
Ph@cops
Old 01-11-2015, 02:52 AM   #488 (permalink)
Thanks. Opto cable has been ordered!! I hope this fixes it! I will report next week-end.
Ph@cops
Old 01-11-2015, 03:09 AM   #489 (permalink)
Old 01-28-2015, 04:19 AM   #490 (permalink)
OK!
Took me some time to get the setup where i wanted but here is what i did:
https://www.helifreak.com/showthread...74#post6322574
Amazing heli!
Old 06-02-2015, 10:43 AM   #491 (permalink)
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 06-02-2015, 11:20 AM   #492 (permalink)
Is there a good thread or video about governor tuning, specifically to minimize the tail kick?
I've had this problem on my Raptor E700 and when I get it back together, I'd love some new ideas for that.
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 06-02-2015, 02:18 PM   #493 (permalink)
There's an excellent podcast with an episode where they spend an hour on FBL tuning, which includes adjusting the governor to get the tail dialed. Unfortunately we're not allowed to refer to that particular podcast on this forum.
Team MikadoUSA
Old 06-02-2015, 03:08 PM   #494 (permalink)
have you tried google?
http://lmgtfy.com/?q=%22FLYBARLESS+T...-BAR%2FLOGO%22
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote Quick reply to this message
Old 06-02-2015, 05:09 PM   #495 (permalink)
Originally Posted by el guapo View Post
Google? I don't know. How do you spell it?
Old 06-02-2015, 05:41 PM   #496 (permalink)
It's spelled googol, as in googolplex.
Team MikadoUSA
Old 06-02-2015, 05:56 PM   #497 (permalink)
Thank you. "goggle" wasn't working for me.
Old 06-02-2015, 05:58 PM   #498 (permalink)
By the way, you snarkfest, the hit from this tells you to turn the governor off before you try to tune.
Not a bad idea, but not the same as turning the precomp off and tuning the governor.
I'm looking for governor tuning, but now that you're making me search things for my self I'll go do that, and share it everybody but you. So there.
