Old 09-12-2011, 01:47 PM   #21 (permalink)
The stretch belt is way more beefier than the regular one.
Even with aproximately the same tension, the regular protos drivetrain hasn't got the drag of the stretch.
It makes me confident, though...
I wish we could have a wider belt for the regular one (but not so thick)...
MSH Prôtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 03:10 PM   #22 (permalink)
i searched in europe for a 5mm belt for the standard protos. nothing.
corrado posted in a german forum, that i should get the stretch kit with 430mm blades.
if anyone finds a 5mm belt for the standard protos, please tell me, i´ll take a lot...
in speedflight, i have 3100upm @ 17° pitch. no problem for the belt. but tictocs with these settings are a really bad idea... the main blade holders are wearing out in a minute...
now go and hunt the 5mm belt!
torro is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 03:18 PM   #23 (permalink)
hey, how many people own a protos?
if all of them write an email to MSH, that the 5mm belt i a MUST, i think we could get it.
i´m gonna post it in german forums.
Old 09-12-2011, 11:06 PM   #24 (permalink)
Why don't you want to go stretch with the 340 blades? I have and love it. Belt does need to be 1 or 2 cogs longer if you don't run the smaller tail pulley. It's tight with a 15T pinion, almost perfect tension at min adjustment. 8 flights so far, maybe it will stretch a little?
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 12:47 AM   #25 (permalink)
This is what you want:
http://www.bearingstation.co.uk/Prod...M/PHG1344-3M-6
pitch length = 1344
pitch = 3m
teeth = 448
Same as stock non-stretched except 6mm in width. Stock is 4mm in width.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 12:57 AM   #26 (permalink)
pitch length = 1344
pitch = 3m
teeth = 448
Hmm. Pulley width is only 5mm. So you're only able to use a 4mm belt. 6mm width won't fit. A 5mm width I think would be inappropriate since you have no run-off left. So stock is your only choice.
Old 09-13-2011, 12:59 AM   #27 (permalink)
Personally, I think with correct tension, the stock belt is fine. Good compromise.
Is the stretch belt just thicker and longer? Or is it actually wider?
Old 09-13-2011, 01:19 AM   #28 (permalink)
Tell me why is the stretched protos are better if it is
More stable? more like a biger size heli or what?
Morus is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 02:52 AM   #29 (permalink)
There's quite a few threads on that already, but to summarise:
Lower disc loading, more hang time, bigger heli feel
The only reason I haven't stretched so far is that I have 2650mah batts.... I just ordered 2x 3000mah batts because the 2650's are dying and when they finally get unusable I'll stretch and buy 2 more 3000mah.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 05:53 AM   #30 (permalink)
Longer, thicker and wider... A women's dream!
I prefer to see it wider than the stock one. It fills more the main gear and the pulley.
I remember Corrado mentioned a mould for the stretch belt.
Ikarus F3A
Old 09-13-2011, 07:36 AM   #31 (permalink)
the stetch belt is 5mm wide
i´m gonna ask bearingstation if they could make a belt 5mm wide. maybe it´s possible...
Old 09-13-2011, 09:30 AM   #32 (permalink)
One of the places I found does make custom width. But I would think it would be much more expensive.
Old 09-13-2011, 01:45 PM   #33 (permalink)
i´ll take 50...
could you ask for it? i think, there are a lot of protos owners who would be interested.
Old 09-13-2011, 02:35 PM   #34 (permalink)
i´ll take 50...
I put in a request for a quote of 50. I'll let you know if they reply back.
Old 09-14-2011, 12:07 AM   #35 (permalink)
cool, thanks!
Old 09-14-2011, 02:13 AM   #36 (permalink)
just got a mail from Corrado:
We will have a 5mm standard lenght belt in about 6 weeks available as an
> upgrade.
Old 09-14-2011, 03:12 AM   #37 (permalink)
Wow!!!
sounds good
Old 09-20-2011, 03:27 AM   #38 (permalink)
[ame]http://www.youtube.com/watch?v=LQJUF9spDzQ[/ame]
my belt....again...
it was loose at the back....
Old 09-20-2011, 07:35 AM   #39 (permalink)
Waaaaay to much pitch Morus
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 09-20-2011, 07:54 AM   #40 (permalink)
it's 13 deg.
and 2800 rmp and 3mm deflection at the motor
It was loose at the back and the belt was skipping at the rear
I re adjust it and it was flying like a hero
I just put this video up to see when my belt is slipping
I'm waiting for the carbon frames and for the new screews
