Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 01-19-2014, 09:52 PM   #101 (permalink)
was wondering if naza h with the gps would work with a blade 450 3d and a dx6i???
Mikefinfan is offline        Reply With Quote Quick reply to this message
Old 01-20-2014, 08:05 AM   #102 (permalink)
Hello,
Of course it will work. Just 2 notes to remember,
Note 1 Naza-h needs good quality of servos as they workin all time of flight as naza try to correct.
Note 2 Bigger the heli better the behavior in atti and gps mode
Chris
CHRIS-AUDIO is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 12:22 AM   #103 (permalink)
A post in this forum says min 7 chanels is that correct ?
IF YOUR GONNA FLY LIKE LIGHTNING YOUR GONNA CRASH LIKE THUNDER
lastofthefew is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 02:14 PM   #104 (permalink)
Correct.
Old 02-10-2014, 06:38 PM   #105 (permalink)
Thanks Chris . You using the Naza H
Old 03-08-2014, 05:24 AM   #106 (permalink)
Well ive setup my naza H and it appears to have gone well ..
When setup complete and in manual mode i get 12deg cyclic ? how do i adjust that down to say 7
Old 03-08-2014, 05:26 AM   #107 (permalink)
im sure i saw a cyclic mix slider in the mix tab for ail & elv nut when i wen t make adjustments it was gone ??
Old 03-08-2014, 06:53 AM   #108 (permalink)
Last time I sem mine up that was done through the setup wizzard... I must check again though...
Gh
Sent from my GT-I9505 using Tapatalk
goodhunting is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 07:03 AM   #109 (permalink)
Yeah I did the cyclic part where you switch to atti or gps and then select measure and ive set it to 6.5 but in man mode it goes to 10
Old 03-10-2014, 05:12 AM   #110 (permalink)
can a DJI agent please clarify the questions asked in this post in particular the images
https://www.helifreak.com/showthread.php?t=608075
Old 03-10-2014, 09:54 AM   #111 (permalink)
I posted a hopefully helpful reply...
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 05:59 PM   #112 (permalink)
Default Semi-auto Take-off & Landing
Hello
Has the firmware been updated to peform
kept seeing this in forums(Will Be Available in The Following New Firmware)
Mine is on the way, just wanted to know Tks
FlyRC4aHigh is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 05:52 AM   #113 (permalink)
Default DJI Naza-H GPS Flybarless System
Not to my knowledge I checked only a month ago
Old 04-18-2014, 08:40 AM   #114 (permalink)
In the end,you flew the heli with Naza H?
SJM 400 V2 now FBL _my first love
HC 500 SE _my fiancée
Gaui X4 ll _my mistress
Outrage 550 _my big love
flydoc is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 06:52 PM   #115 (permalink)
Na not yet waiting on my bec pro
Old 04-20-2014, 10:47 PM   #116 (permalink)
Default BEC'S
Hello again
Those using the NAZA are you using the NAZA H BEC or using the ESC'S BEC I would like to use the Talon BEC cause it will let you just type in the head speed you want in programing the governor, Thoughts, comments, Thanks
Old 12-05-2015, 07:59 AM   #117 (permalink)
Default Naza-h problems
Hi
I am flying Align 800E with upgraded JR Servos with Naza-h with GPS
Naza h gps modes work well without gimbal.
with Gimbal 50% of the time it works well. but it goes into see-saw motion when putting on gps or att mode.
the conditions remains remains the same. with wind, without wind.
I make sure my heli is perfectly cg balanced before each flight.
Heli flights really well in manual mode.
I have tried lot of things, but this see saw problems comes and goes on its own. tried different settings etc.
please help. unable to figure this out. was thinking of changing NAZA.
I am unable to start my AP work because of the same
ss2sameer is offline        Reply With Quote Quick reply to this message
Old 01-03-2016, 07:00 PM   #118 (permalink)
Originally Posted by ss2sameer View Post
Hi
Make sure you put the correct distance between the GPS and the center of gravity (which in this case it is the main shaft), also make sure you do the compass/GPS calibration; you know to do the swing/dance, and finally make sure the GPS is mounted in an area where it is free of EMF so otherwise you vgot to do the swing/calibration every time you fly.
Naza is one of the best system out there, but when it comes to GPS it can get a little tricky
helikas is offline        Reply With Quote Quick reply to this message
