Old 07-10-2011, 08:11 AM   #1 (permalink)
Default How Telemetry Sensors Work on TM1000
I'm an engineer and have been keenly interested in learning how the Spektrum TM1000 telemetry system works. This weekend I learned how the temperature, voltage and RPM sensors work and am posting that info here so others can benefit.
First, this information is based purely upon observation of how my system works. Unlike most electronics companies, Spektrum does NOT publish the specifications for their radio systems which means we have to reverse engineer them to understand what they can really do. I would very much like to know things like: rf power output & spectral purity, TX and RX power drain with and without telemetry, telemetry update rate, telemetry resolution per channel, telemetry sensor range, telemetry sensor accuracy and so on and so on.
What I have found so far:
RPM port. When looking into the TM1000, the left-most connector is for the RPM sensor. The three pins going from left to right are: +, ground and signal. The + power supplied to the sensor by the TM1000 seems to be around 3.5 volts on my TM1000 when using a BEC with a 6V output (TREX 450SE). I think this is because the TM1000 can actively turn on/off sensors if you have them enabled/Inhibited in the DX8. I saw that power to the RPM sensor does not come on immediately when you plug in the battery, it becomes active a few seconds later.
RPM Signal. The good news is that the type of signal fed to the TM1000 from the RPM sensor is a simple square wave pulse where you get one pulse for each trigger of the sensor (crank pin swing, gear tooth, optical reflection, etc.) This means a whole host of sensors can be used with the TM1000 as long as the signal is within the voltages on the + and ground pins. Many magnetic (Hall effect) and light sensors are available that would work right out of the box with the TM1000. Typically they are 3-wire devices which can plug directly into the TM1000 (power, common and signal). Just make sure they work at 5V or lower power supply.
My first RPM sensor. I was able to plug-and-play with a brushless motor RPM sensor from Eagle Tree Systems. http://www.eagletreesystems.com/Supp...shless-rpm.pdf
The ETS sensor comes with a full size servo-type connector and so an adapter will need to be made. I used a Spektrum satellite RX cable and servo extension to make a patch cable. IMPORTANT: The ETS sensor wires do NOT follow the typical convention used for servos! On the ETS RPM sensor, the black wire is +, red is ground and white is signal. If you swap the wires correctly the brushless RPM sensor works very well with the TM1000.
Temperature Sensor. The TM1000 temperature sensor is a NTC thermistor, or "negative thermal coefficient" resistor. I measured it's resistance at two temperatures (room and in hand) compared against a 10K NTC thermistor I had on hand and the two agreed within 5%. But I only had the one and it was consistently slightly lower in resistance than the 10K. The next lower standard NTC size is 8.5K which would be considerably lower that what I measured, so I conclude that the TM1000 expects a 10K NTC thermistor.
Temperature & Voltage Connection. The temperature & voltage sensors are connected to the TM1000 in the center port. The Y-harness should be used in this port if using both temperature and voltage sensors simultaneously. The port pins (and color from Y harness) from left to right are Voltage (red), Common (black) and Temperature (orange).
Voltage Sensor. This is the easiest as the TM1000 relays the voltage measured between the common and voltage input wires.
What's missing. I still need to determine what the min/max values are for the RPM pulse rate, voltage and temperature measurement capability. The NTC thermistor has more precision at room temperature that at engine cylinder head temperatures (so BEWARE! and check the temp sensor against a known thermometer before putting your $$$ aircraft on the line).
**IMPORTANT
I have found both by research and my own experience that if you plan to use telemetry you MUST be sure your BEC can supply enough current. A ship with lots of digital servos, gryo, RX, sat RXs and a TM1000 will use a LOT of current. I am near the limit already on the TREX 450 and am thinking about a stand-alone BEC for safety. If your RX power drops too low during flight you can loose control of the aircraft!
Good luck and I hope this helps!
tskloss is offline        Reply With Quote Quick reply to this message
Old 07-18-2011, 06:47 AM   #2 (permalink)
cool, was wondering what these were about...
toonttm is offline        Reply With Quote Quick reply to this message
Old 09-17-2012, 06:28 PM   #3 (permalink)
coool very goood thanks
jac_2011 is offline        Reply With Quote Quick reply to this message
Old 10-30-2012, 02:39 PM   #4 (permalink)
hi received my sensor please
could you put a picture as I left your system does not damage my DX8
agradesco it infinitely greetings
Old 06-04-2013, 01:02 PM   #5 (permalink)
Tskloss you are a super star!
Been struggling to get my EagleTree RPM sensor to work with my TM1100. I had no idea the red and black were the wrong way round!!!
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 06-04-2013, 01:54 PM   #6 (permalink)
[good thanks regards
Old 04-10-2014, 11:28 PM   #7 (permalink)
Thanks for this awesome write up.
I don't understand the voltage sensor.
If it connects directly to the positive wire, how does it monitor individual cell voltage?
skiiermike is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 12:04 AM   #8 (permalink)
Mine only registers the overall pack voltage not individual cells.
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 12:12 AM   #9 (permalink)
So I guess you just multiply the low voltage per cell by the number of cells and set your alarm for that?
Sent from my SGH-I747M using Tapatalk
Old 04-11-2014, 12:35 AM   #10 (permalink)
Yes, correct... but you will have to find your sweet spot to avoid alarms when the voltage drops on hard maneuvers...
Old 04-11-2014, 08:03 AM   #11 (permalink)
Thanks for the advise.
Old 05-13-2014, 01:37 PM   #12 (permalink)
Default problemas con configuracion
Buenas a todos a ver si me podeis ayudar, no consigo ver los datos en la pantalla y la emisora me dice que no esta configurada. tengo el sistema ar7200bx y t-1000 con la dx8. Enlaza bien pero no tiene seņal menos la del voltaje. muchas gracias saludos.
palasheli is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 07:49 PM   #13 (permalink)
Amen brother, thanks Tskloss!!
Wishing you many Happy Landings!!
-=S=-
Scream is offline        Reply With Quote Quick reply to this message
Old 01-06-2015, 10:54 AM   #14 (permalink)
Default TM1000 Telemetry - AR9000 RX issue
Many thanks for all the great information however, my question is two issues, one is binding problems between the TM 1000 and the AR9000. The AR9000 RX will not bind using the side button as instructed on the TM1000. I had to bind the two using a bind plug in the Bid port on the RX. It also does not engage the TM1000 everytime I power up the system.
Secondly when the telemetry is connected and operational it loses connection (or something) whils the heli (T-Rex 600 Nitro) is flying.I would greatly appreciate it If someone can please enlighten me which way to solve these issues. (I have sent two requests on these issues to Horizon Hobbies who have not responded, why I don't know!)
Mark Coetzee is offline        Reply With Quote Quick reply to this message
Old 04-18-2015, 02:42 AM   #15 (permalink)
TM1000 compatible to brushless rpm speed sensor HW-SM824Dul ?
Item Description
Hobbywing Brushless RPM Sensor HW-SM824Dul-RPM Sensor RPMSENSOR
Specifications:
1. Size: 23mm(L)*10mm(w)*2mm(H)
2. Weight: 6g (Input and output wires are included)
3. Working voltage: 3.5V to 8.4V(1S to 2S Lipo)
4. Current: 1 to 5mA
5. Voltage range of the motor wires: 2 to 14S Lipo
6. RPM range (for 2 poles brushless motor): 1000rpm to 300000rpm
7. Working temperature: 0 to 50 Celsius degree or 32 to 122 Fahrenheit degree
poli27 is offline        Reply With Quote Quick reply to this message
Tags
rpm, sensor, spektrum, temperature, tm1000
