Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > FPV and Real time Video
FPV and Real time Video Discussions of receiving video in realtime from the aircraft
Old 12-06-2010, 12:18 AM   #1 (permalink)
Arrow FPV quad with GoPro = FUN
Hi
I am new to FPV and I am loving it! Totally addicted. This is my first FPV video.
enjoy
Set up
Gaui 330x-s running on 2200 mah 3s lipo
AR7000 RC reciever / JR DSX9 tx
Cut down Infinity hobby landing gear
Infinity hobby payload mount set on bottom
Custom made payload mount on top
1.3 ghz 300mW video tx (460mah lipo)
RMRC 480 camera
eagletree elogger and OSD
Hobbyking LEDs
Gopro HD hero for recording
Weight 965 grams
Flight time 8 minutes
Base station
1.3Ghz reciever with 8dBi patch antenna
Fatshark goggles
All running off a 1800 mah 3s lipo
mounted on a camera tripod.
juz70 is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 03:49 PM   #2 (permalink)
Juz70, hello man.
Great video enjoyed the scenary especially the kangeroos.
Frank
I held it in just like you said....from what tree?
Hirobo Shuttle, srb. Trex 450se V2, GY401, S9257, hs-65mg servos, 430XL Motor, 11v 2100mah, 325 cb Futaba 7cap Tx, RealFlight G-4.5, T-rex 500, 6sKP2600,GY401,9257, HC 3D, mCX,(2) HK 450's, telebee gyro, hxt900 cyclic.
maxout is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 03:53 PM   #3 (permalink)
really nice video i liked it : )
about how much range do you get with that 300mw? tx
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 03:59 PM   #4 (permalink)
Very cool, thanks for sharing.
miamiheli is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 07:35 PM   #5 (permalink)
Hey there
Not sure on range. Though, I am guessing that my rc range is less than video range, so I am limited by that!
The crash in the video was caused by losing video. It was about 500metres from me and my base station, though, there were many trees blocking the signal also.
juz
Old 12-08-2010, 11:11 AM   #6 (permalink)
First FPV video? wow, very impressive!
good times and happy landings
aaronredbaron is offline        Reply With Quote Quick reply to this message
Old 12-08-2010, 02:17 PM   #7 (permalink)
How about a picture of the Gaui with the camera and gear mounted on it?
KernelSanders is offline        Reply With Quote Quick reply to this message
Old 12-08-2010, 03:12 PM   #8 (permalink)
Sure
Here you go...
RMRC 480 camera
Hobbyking LEDs
Weight 965 grams
Base station
Fatshark goggles
Juz
Name:	330x front.JPG
Old 12-09-2010, 12:22 AM   #9 (permalink)
Very nice! Thanks!
The kangaroos cracked me up. :-)
Old 12-20-2010, 01:13 AM   #10 (permalink)
Those 'roos are scarey when they are coming at me through my video goggles.
Old 12-20-2010, 01:15 AM   #11 (permalink)
thanks
those 'roos are scarey coming at me thru my video goggles!
Old 12-20-2010, 01:31 AM   #12 (permalink)
That is quite inspiring. Nice setup, I love the simple way you mounted the GoPro.
Av8Chuck is offline        Reply With Quote Quick reply to this message
Old 12-24-2010, 05:00 PM   #13 (permalink)
Great vid! Thanks for sharing. I might need to try FPV too...
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 12-25-2010, 08:16 PM   #14 (permalink)
How come you used a separate camera for the FPV downlink? Can't you use the GoPro for both SD FPV and HD recording?
dswitkin is offline        Reply With Quote Quick reply to this message
Old 12-26-2010, 02:19 AM   #15 (permalink)
Sure, I could have done that, but the gopro is not a good FPV cam in low light situations ie. cloudy days, shadows etc. The image that I get in my goggles is always sweet with the 480 OSD camera that I use, either under trees, on dark days or even thru buildings... With my desire to fly high and low, fast and slow, through trees and around stuff, I need to be able to rely on a good image in my goggles at all times no matter what light is available. Also, with the few grams that the FPV cam weighs, its no problem.
juz
Old 12-26-2010, 02:37 PM   #16 (permalink)
That's great to know, thanks. I always prefer the simpler approach unless there's a good reason not to. Perhaps when I get around to building an FPV setup I'll start with the GoPro for both, and take your advice if the image isn't good enough (which would depend on the gamma and contrast of the goggles, among other things).
By the way, great video! I like the outtakes at the end too.
Old 12-26-2010, 02:51 PM   #17 (permalink)
Also, how's it holding up in crashes? Is it possible to mount the propellers using prop savers instead of hard mounts? Have you broken anything yet?
Old 12-26-2010, 05:37 PM   #18 (permalink)
I have crashed it several times. I have only had a small crack on one prop (it was still very flyable). And, one time the motor mount popped out a little. I popped it back in and flew again. They are a very durable machine. Not sure on the prop savers. Props are relatively cheap anyhow.
thanks again mate
Old 12-30-2010, 12:24 PM   #19 (permalink)
wow, great video, I like the ending
Synergy e7, Vbar, HeliJive 120, Hacker 12L, JR 8917 HV, BLS251
Logo 400, Vbar, Jive 60+lv, S9650, BLS251, Pyro 600-09
TRex 450 Sport, MiniVbar, 5065MG, DS420, 450MX
vanillagorilla is offline        Reply With Quote Quick reply to this message
Old 01-01-2011, 05:01 PM   #20 (permalink)
video 2 and 3
