Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 02-17-2007, 02:32 PM   #1 (permalink)
Default Hurricane 550 anyone?
Any freaks flying the Hurricane 550?
Looks like an interesting heli and seems to be aimed at 450 size owners wanting a bigger heli without breaking the bank. Uses 2 common 11.1v lipos for power and comes with ESC, motor & blades. I have watched some videos of this heli and looks pretty nimble.
Just curious what other think about it? Im toying with the idea of getting one just to utilise all my HDX450 batteries, but wonder what parts availability would be etc.
Any views?
broke-again is offline        Reply With Quote Quick reply to this message
Old 02-17-2007, 09:16 PM   #2 (permalink)
Team Taco VP
I have been looking at them and thinking of actually doing a build vid on the thing. I like the push pull system and the general layout of components in the frame. It looks like a good heli from what I have seen!
Bob
Old 02-20-2007, 12:14 PM   #3 (permalink)
I just got my Hurricane last Saturday and so far I am very impressed with it.
Looking in the box it becomes very obvious that there is just not much to do putting this heli together. The quality of all the parts looks great and it all fits together quite well.
The head and tail assemblies are very tight with no slop at all.
Now that I have the thing built I hope to test fly it on Sunday.
So far I only have a few minor issues.
I really like the canopy style and design but it could be made to be a little more rugged,
although I would have to admit it does do what it was designed to.
The tail servo is in the frame and while this seems to be fine, the more modern approach is to mount the tail servo on the boom.
The instructions could be more detailed, but they are adequate to get you though the build and any subsequent repairs.
So far for the price of a Trex-450 SA I am quite impressed.
Hopefully I will still be impressed after I have had it for a while.
X30
X30PILOT is offline        Reply With Quote Quick reply to this message
Old 02-20-2007, 12:54 PM   #4 (permalink)
Boy im getting more & more tempted to get myself one of these. Iv'e done a bit of reading and so far owners really like it, seems it handles very well too. I see another build vid coming up Bob!
Good luck & Please let us know your set up & how it goes. Im also curious about what flight times are like
How much did your 550 set you back and where did you buy it X30?
Thanks for the feedback!
Old 02-20-2007, 03:15 PM   #5 (permalink)
mine has not impressed me. The frame is soft (flexi) and the battery mount area is a real pain to work with.
more than enough now
ozace is offline        Reply With Quote Quick reply to this message
Old 02-20-2007, 10:59 PM   #6 (permalink)
broke-again
I bought mine at www.backman-rc-expert.com for $345 with motor and speed control.
Putting this helicopter together was a pleasure. Parts fit is fantastic.
I have never seen head and tail assemblies with virtually no slop like this before.
The radio installation is well thought out and is a snap. On many of the other helis I have built, component placement appears to be an after thought.
Both the motor and speed control appears to be very high quality.
The canopy design provides for good airflow for the batteries, controller and motor.
When spooling this thing up with no blades it is smooooth.
Old 02-21-2007, 07:25 AM   #7 (permalink)
just wanted to share, saw the hurricane for the 1st time last tuesday, and i was blown away. uses 2 3s 2100mah packs so in essence its a 6S (can use existing trex batteries), has no slop in the head. check out the video
Gaui Hurricane 550 (pic)
Hurricane (video click to play)-
shauntot is offline        Reply With Quote Quick reply to this message
Old 02-21-2007, 10:58 PM   #8 (permalink)
I now have 8 flights on the Hurricane and it is one fantastic flying machine! Very stable in hover, wonderfully powerful in both pitch and cyclic authority and it has a wild pirouette rate. With a good set of carbon blades it would be fantastic. The power system seems to be well matched to this heli. I have found the battery mounting very convenient to work with. I have lined the battery mounts with wing seating tape and use Velcro straps to hold the batteries in place. On one of my last flights I flew this thing pretty hard for 5 minutes. Not hard core 3D, but plenty of loops, rolls, 720 stall turns and inverted flight, I wasn’t level for very long. The charger only put 1470 mah back into my 2200 mah batteries.
It went together and was very easy to set up with no issues, except the speed control. The default settings include a battery management system designed to protect your LiPos and a setting of helicopter with governor. This battery management system has shut down power to my motor prematurely several times and I am fortunate to have not wrecked the heli as a result of this. I have reprogrammed the controller to not use this feature and have had some great flights but for some reason the controller goes back to the default settings.
If I can’t resolve this I will put in a different speed controller.
X-30
Old 02-22-2007, 02:25 AM   #9 (permalink)
Hi guys Finaly I've got mine!!!
here it is
It looks well done machine! I still need to put gyro on it and it will be ready for fly
The only disappointed thing is that the servo mount holes on the frame is too big and i can't find good screws for servo installing
Piranha is offline        Reply With Quote Quick reply to this message
Old 02-22-2007, 08:01 AM   #10 (permalink)
this thing sounds fanatastic ! any more comments on battery life? 1470 back for 5 mins sounds amazing.
Yuchan is offline        Reply With Quote Quick reply to this message
Old 02-22-2007, 09:19 AM   #11 (permalink)
Where they not included in the kit Piranha?
Seems from my research that your not alone on this. I think i read somewhere that the ESC comes from the same manufacturer as Align, but it appears to over-ride any programming when it reads the battery voltage when you first plug it in. There dosent appear to be any fix for this yet, i would play safe and swap it out. Did you contact the seller about this?
Old 02-22-2007, 05:15 PM   #12 (permalink)
X30PILOT, How are these guys to deal with, I noticed they have an office right outside Dallas. How long did it take to get yours?
Steve
3D52 is offline        Reply With Quote Quick reply to this message
Old 02-22-2007, 06:58 PM   #13 (permalink)
Piranha/broke-again
The holes in the frame fit the JR DS-821 servos perfectly. These are the servos that are included in the 7202 and the DX7 radios.
3D52
I have had excellent service from backman-rc-expert.com. It took less than a week to get my Hurricane from them.
X30
Old 02-22-2007, 07:31 PM   #14 (permalink)
What other ESC would be suitable for this, would the Align 75a be ok. If i did get one, i wouldnt want to use the stock ESC.
Old 02-23-2007, 12:28 PM   #15 (permalink)
After great deal of reading and struggling with choices the wallet won and I ordered my Hurricane 550 this morning. The price / apparent performance as seen in some of Tom Viper's posts on another forum finally pushed me over the brink after I read that ozace had solved his frame flex problem by correcting an error made in servo disc template, properly seating partially seated (and binding) bellcranks and adding a brace behind the motor. Has anyone found a US source for parts - I checked Backman's and he sells the heli but does not confess to stocking replacement parts.
Have never flown anything larger than my Dragonfly 52 and HeliMax RotoFly so any words of wisdom and advise on assembly, setup, testing and transition from flying the little guys to this big girl would be humbly received and greatly appreciated.
larryl
'Remember - every take off is optional but every landing is mandantory!'
Raptor 90, Hurricane 550, Swift 550, T-Rex 450, Blade 400, HDX 300, Blade CCP,
Blade CX2 and Blade MCX (on the way in September).
larryl is offline        Reply With Quote Quick reply to this message
Old 02-23-2007, 03:05 PM   #16 (permalink)
Get the Finless videos on CCPM and Pitch/throttle curves. They work for every heli. I use the same setup regime from my Gaui EP100 Pro (165mm rotor blades) to my Quick of Japan EP8 (400 mm rotor blades). Works GREAT.
X30PILOT, you might want to check reports on those serovs, I have seen several reports of sheared output shafts.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 02-23-2007, 06:20 PM   #17 (permalink)
broke-again
Any speed control that can handle 50 amps and 6s should work. Certainly the Align Trex 600 controller would work very well.
larryl
I built my Hurricane stock except for putting some washers under the bolts holding in the motor mounting plate. I used the servo wheels off of the DS 821s. They are not quite as big as what is shown on the instructions; however they have holes in them that match the suggested offset perfectly. I can tell you from flying this thing that any airframe modification is a waist of time.
Pinecone
I tested my servos as some people have suggested on the net. I held the servos and operated them putting a lot of resistance on the output with my hand. Those who have reported problems have had the shafts sheer right off in their hand doing this. I had no problems, so I hope mine are ok. I’ll let you know if I have any difficulties with them.
X-30
Old 02-23-2007, 06:32 PM   #18 (permalink)
Thanks for the feedback x-30
Old 02-24-2007, 05:48 AM   #19 (permalink)
Just wanted to make sure you knew about the reports.
Sounds like it may have been a bad batch. I haven't followed it that closely. But if some are OK, that is a source for some cheap servos as people dump the ones from teh DX7 sets.
Hmm, may make the Hurricane move to the front of the pack for ordering.
Terry
Old 02-24-2007, 04:36 PM   #20 (permalink)
Default Interested 550. have a few questions
It looks like the Hurricane 550 is a pretty good heli. If I'm reading the post correctly for $350 you get the copter. brushless motor,and a esc. It looks like I would need servos.battery pack,and a setup to power the rcvr.. if I want to run the rcvr. on its own power source. Does the 550 come as a kit,or artf. Is there any other items or things to consider about the 550. Thanks Craig N
Boleia is offline        Reply With Quote Quick reply to this message
