Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 04-20-2014, 11:55 PM   #21 (permalink)
Was hammering my NX4 over the weekend and doing a fast fly-by the engine cut..
AAARRRRRGGGHHHH - had to slow down quickly and auto before it flew past the field..
Came down at the end of the field and luckily only broke a skid pipe - phew!!!!
Turns out the silicon tubing of my clunk line had swollen and fell off the tube on the bung - so no clunk line and my header tank emptied..
The tank in the NX4 is quite easy to get out so was a 20min repair job on spot at the field the next day - all good again!!!! Hooting again the next day...
Unfortunately - 2 flights before I came down inverted backwards in my X5 and instead of levelling out I dumb-thumbed and nosed down into the ground Not nice...
All repaired (minus canopy) by midnight and flying the next day
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 04-21-2014, 06:57 AM   #22 (permalink)
Was on the 4th flight yesterday and it was having a hard time at idle.
At the end of the 5th flight I noticed drag in the drive train.
sprung clutch, still put it in the air for a 6th flight then tore it apart at home.
The clutch liner was very worn.
Think I got around 180+ flights on that clutch and liner, it survived 3 crashes.
Mighty good I'd say.
AMAIN Heli Team
u8at711 is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 12:32 PM   #23 (permalink)
Got 4 more fights in today. Loving it now @ 2400 with some smooth big air flying but need a rear engine bearing now
Sent from my XT1052 using Tapatalk
Synergy N5c,OS55HZr, Opti fuel, Msh Brain
Gaui X3, sk720, gensace power
Lynx team pilot
pugdavey is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 03:09 PM   #24 (permalink)
I maidened my NX4 this Wednesday. It went really well at first, managed to get the engine running well even though I'm total nitro noob. I was really surprised how well it flies. It felt like flying much bigger heli than it actually is for some reason.
Anyway, first thing I did on my forth tank was flipping it inverted, not realizing I'm in normal mode. Guess how that went . The damage was minor, have to wait for parts till next weekend though. First thing I do before remaiden is wiping out the normal mode in the radio , I'm going to spool it up using delayed throttle between flight modes.
Some photos from the maiden:
ID:	504694   Click image for larger version
DaveLister is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 10:13 PM   #25 (permalink)
Default gaui
I tried my new pivothead Glasses
here is a video. I was trying my new pivot head glasses.
motor over revved and not sure what caused it, magnets are still in and everything looks good
[ame]http://youtu.be/WVUeH69z_no[/ame]
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 04-26-2014, 10:56 AM   #26 (permalink)
I recieved my used NX4 last night. It may take some time to get it rebuilt/checked over but I am looking forward to flying it. Whoohoo!!
- Gaui NX4 - Pat's Highwind X5 FPV Racer - Armattan F1-5 Pod FPV Racer - DX8 - Taranis Plus -
S.Millar is offline        Reply With Quote Quick reply to this message
Old 04-26-2014, 12:05 PM   #27 (permalink)
That's awesome, Scott!!
Sent from the Samsung Galaxy S3
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 04-26-2014, 07:52 PM   #28 (permalink)
I maidened, crashed, rebuilt and successfully maidened. At 1.5 turns out this thing really gets greasy! One or two more flights and I'm gonna start to lean it out. Are most people running at about one turn out?
squeely531 is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 09:11 PM   #29 (permalink)
Ordered my NX4 today.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 10:02 PM   #30 (permalink)
Congratulations ChadL. Seems to be a fresh batch of us NX4 owners this spring. What's your setup going to be?
Old 04-29-2014, 07:06 AM   #31 (permalink)
Count me in! Just got my electronics yesterday and the kit should be here friday
-Phillip Johnson, AMA #954735
LegndarySaiyan is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 07:27 AM   #32 (permalink)
Futaba BLS153 on Cyclic
RJX FS0391T on Rudder
Align DS525 on Throttle
OS 37 (duh :-) )
Hatori SAB-6
CGY-750 FBL controller (awesome nitro gov)
KBDD Extreme edition main blades
Rail 80.6 tail blades
Formula head
Life pack, no regulator
Voodoo 400 SK540
Old 04-29-2014, 08:17 AM   #33 (permalink)
Mine is:
O. S. 37
Hatori SAB-6
Metal fan
MKS HV 9767 and 9780
HV micro servo on throttle
Gryphon tiny glow
KBDD green dampeners
Edge 72mm tail blades
435 Spin Blades
2S 1800mah no regulator
Vbar Silverline
Spectrum back plate sensor
Old 04-29-2014, 08:40 AM   #34 (permalink)
Mine is:
O. S. 37
Hatori SAB-6
Gryphon tiny glow
435 Spin Blades
Vbar Silverline
Nice set up.....I forgot to add I'll be using a SwitchGlo Pro.
Nice setup.
I'm really excited about this little heli. I've wanted one since they came out. I haven't had a nitro heli for over a year and I'm itching to smell nitro in the morning
Voodoo 400 SK540
Old 04-29-2014, 09:17 AM   #35 (permalink)
Me too!
I am about to start tearing mine down to check it over. I got it used.
Consider a metal fan upgrade to add to your list. Mine came with one from the previous owner
Old 04-29-2014, 10:19 AM   #36 (permalink)
Thanks for the tip. Ordered the gaui metal fan.
Voodoo 400 SK540
Old 04-29-2014, 03:28 PM   #37 (permalink)
Default What Did You Do With Your NX4 Today??
Maidened mine today. This thing is seriously fun. I burned two tanks before it got to windy 20+ mph. I don't think I could have bought a better first nitro.
Here's my set up.
IKON flybarless unit, setup with governor
- OS .37 engine
- Edge 423mm main blades
- KBDD tail blades
- Hatori pipe (Bobby Watts Special)
- Upgraded Red Gaui fan
- Align Governor Sensor
- Pushglow
- Gryphon GVR 5010 voltage regulator with switch you can operate without removing the canopy
- Align ds 515m servos on cyclic and throttle
- Align ds 525m servo on rudder
- Header tank
- Upgraded TREX 600 pitch slider
- Align fuel filter
- Nano-Tech 1500mah lipo
GAUI USA Field Rep./ Team Empire / Optipower USA Field Rep./Skookum Robotics Field Rep. / HALO Blades Field Rep./ OMG USA field rep.
mrob73 is offline        Reply With Quote Quick reply to this message
Old 04-30-2014, 10:39 AM   #38 (permalink)
Burned two tanks this morning,
Successfully made it through my first hydrolock situation, oh and did my first flips and rolls that weren't on the sim. Finally got past my mental block. It was a good morning.
Old 05-03-2014, 12:59 PM   #39 (permalink)
Started stripping my new to me NX4 down yesterday evening. I started with the tail section. Every bearing in the tail is caked with Texas sand. I don't have spares for these bearings because I have never needed them.
I took the sheilds off the bearings and blasted them out with automotive brake cleaner. They are almost like new after being cleaned and greased. The TT bearing was completely seized but I had a spare for that one.
How do you get sand inside the boom anyway...lol. Let the fun begin
Old 05-03-2014, 10:46 PM   #40 (permalink)
Finally flew it
Gaui NX4 (5 min 28 sec)
Keith
Goblin 700C Gasser -- Goblin 700C -- Goblin 570 -- Gaui NX4
#29
gcac399 is offline        Reply With Quote Quick reply to this message
