Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 01-19-2013, 03:20 PM   #81 (permalink)
solder the motor wires directly to the esc. You will get a better connection. You may have to switch 2 wires if the rotor runs backwards. It is a flip of a coin.
soupy01833 is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 05:50 PM   #82 (permalink)
I have a pjacq kit ordered as of this morning and can't wait to try it. I hope the stock lipos do okay on it because I have six of them.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 06:26 PM   #83 (permalink)
I've been happy with my stock lipos performance with this kit.
pas2knut is offline        Reply With Quote Quick reply to this message
Old 01-19-2013, 06:56 PM   #84 (permalink)
Great! pjacq said they worked and that's one reason he prefers the milder kit.
My flying skills have grown by leaps and bounds on the 450 since I got the Nano.
I learned on the Nano first to do a figure 8s half upright and half inverted with a side flip in the middle you know. Once I got the sticks down on the Nano it was even easier on the more powerful, stable FBL 450. Also learned backwards and forwards inverted figure 8s and tight inverted circles as well. And also did my first right rudder half piro flips on the Nano. And I can't forget nose in upright circles.
Its a good practice to do circles in all orientations upright and inverted and I have practiced all that stuff on sim countless hours.
Old 01-19-2013, 11:52 PM   #85 (permalink)
Default Batteries
In a lot of the pictures posted here it looks like they are using the mCPX skids with a larger battery. Anyone confirm this??? mCPX skid with a 300mAh battery???
tmacrc is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 02:10 AM   #86 (permalink)
Default WOW, this is me!!...
I love my nano cpx, and this looks to be the perfect kit for simplicity of install...
How does it perform with the stock tail motor? Or should it be paired with the brushless tail? I would prefer an inrunner tail if anyone has any thoughts of what could be used.
Any vids of it installed and flying yet?
Billz_01 is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 06:26 AM   #87 (permalink)
The same kit can be got with the brushless tail as well. pjacq just built one and sold it in the helifreak classifieds.
Old 01-21-2013, 07:08 PM   #88 (permalink)
my kit will be here tomorrow would have got it today stupid mail
super bad is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 08:14 PM   #89 (permalink)
This is a great kit. The frame spacers are awesome and really stiffen up the frame after cutting out the support for the motor. I like the fact that you can reuse the kit on a new frame later too. No glue.
finally got around to installing mine. I did airtime skids, lynx swash, and some MH blade grips at the same time. I already had made a solid tail boom. This thing is flying rock solid now. I just need to get some better batteries with a bit better discharge rate now.
zemurray is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 09:15 PM   #90 (permalink)
We're do you get one of his kits from? Thanks
Drew7601 is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 09:34 PM   #91 (permalink)
Send a PM to pjacq to see if he has any available.
MCPX BL, 130X, 450X, Nano QX, ProtoX
Spektrum DX7S
spiff72 is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 09:42 PM   #92 (permalink)
He had both the Mild and Wild kits on Saturday when I ordered mine.
Old 01-21-2013, 10:25 PM   #93 (permalink)
Thanks guys.
Old 01-21-2013, 10:43 PM   #94 (permalink)
PM pjacq
Old 01-22-2013, 11:09 AM   #95 (permalink)
Originally Posted by xpcm View Post
i use hakko fx888
Good bang for the buck
.2mm bent conical tip for smalls
Real thin solder helps also
What temp do you use for the Nano board?
vrex01 is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 11:11 AM   #96 (permalink)
I run my Weller around 580 degrees.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 09:05 PM   #97 (permalink)
Question esc connectors
Has anyone kept the connectors on for this mod?
Looking at my kit there doesn't seem to be the room to keep them on but would be convenient I would think.??
WOW these are small. The build pics make everything look manageable.
Nervous for that fet connector
Braydubya is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 03:09 AM   #98 (permalink)
I started with mine on, but like you say the battery wouldn't slide in so I went straight to the board.
I got lucky on the fet front and back ;-)
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 03:11 PM   #99 (permalink)
Well my pj kit didn't come today. I can't wait to get it and get it installed. My Nano is not worth flying right now with its weakened main motor. 2 minutes of mediocracy is not worth charging 6 lipos individually. I also have the right parallel cable ordered for it too, I mistakenly thought the MCPX parallel cable would work but the connectors are too large.
Old 01-26-2013, 02:57 PM   #100 (permalink)
My kit came today and I have everything ready but the signal wire. I can't tell exactly where pjacq soldered it into the board from his video. Does anyone have a really good blown up
pic of it?
