700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-17-2012, 07:33 AM | #81 (permalink) | |
This makes sense and should work well.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar T-Rex 450L Dominator | JR DSX9 9503 Mode 2 |
12-17-2012, 08:41 AM | #82 (permalink) |
Dino, no offense, but that won't work in this case. The black umbrella is so large a diameter it will not go into the ID of the bearing. I could not even get it to start. I even put a small chamfer on the end trying to get it to start. When I tried tapping it in, it was so tight it destroyed the bearing
The remaining 3.5 hours was spent sanding/scraping the black gear to fit into the new/last bearing I had on hand so as not to mess it up. BTW, I am now waiting on some small shims to arrive, as the new tail shaft shoulder is about .1mm too short and lets the shaft move back and forth when the tail case is assembled. Put the original tail shaft back into the case, no play, reinstall the new tail shaft, play is back and when the shaft is loaded to the tail blade side, it makes the mesh too tight. Load it the other way, and it's as smooth as (well lets just say it's smooth). I am waiting on a backup set so I will see what the new shaft does when I receive it. Ralph
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550 Amain Hobbies Team Rep |
12-17-2012, 09:03 AM | #83 (permalink) |
I had the same play running that way to see what happens, just make sure to shim it correctly or it will wear the gear out, on a side i am sending them an email about the gear being so tight
thanks Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba |
12-17-2012, 09:13 AM | #84 (permalink) |
My gear had a similar problem. It was about an 0.008 inch interference fit on the shaft side of the bearing shoulder and 0.004 on the gear side. I worked it down to a uniformed 0.004 over the entire shoulder. I turned an aluminum arbor and sleeve to press the end bearing on and then into the case. The gear mesh looked good; although, if I were to do it again I might consider a couple of small shim to increase the contact pattern.
12-17-2012, 09:36 AM | #85 (permalink) |
I have a question that is not directly related to the gear but hopefully you guys will know at least Dino. I got the new gears last week and before I could put them in I crashed the bird (servo horn screw came loose ) . Anyway I will be putting the new Gear in on the rebuild but my question is that the DFC has new part numbers for the TT and Boom can you use the original 700 parts or is there a difference in the parts? My supplier does not have the DFC parts in stock but I can get the originals. Thanks for you help.
Nathan |
12-17-2012, 09:49 AM | #86 (permalink) |
Is it necessary to replace the umbrella gear that fits into the tail hub, or can you skip it if it doesn't go smoothly? I have 2 torque tube align Helis, and have never stripped an umbrella gear..
TRex 700DFC CC 120HV/VBar TRex 500 ESP/FBL CC Ice100, MiniVBar TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C |
12-17-2012, 10:36 AM | #87 (permalink) |
that is for the nitro boom it 10mm longer for the new DFC heli
12-17-2012, 11:05 AM | #88 (permalink) |
Dino, what about the axial play some of us are now seeing? Sorry, I didn't see your reply about send a email to Align on these issues.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550 Amain Hobbies Team Rep Last edited by rcflyerheli; 12-30-2012 at 07:55 PM.. |
12-17-2012, 11:54 AM | #90 (permalink) |
yes sent them a message about the in and out play on the tail shaft
12-17-2012, 01:06 PM | #91 (permalink) |
My black gear was also very large, I just stuck the new gear onto the end of a large driver in my drill, wrapped the outside with a bit of sandpaper, and worked it down to size in a few minutes. That part has gone fine, getting the tail slider moving freely through the entire range is still a work in progress, still a bit tight when all the way in close to the tail case. Otherwise the build is done and its been very easy and issue free.
12-17-2012, 01:25 PM | #93 (permalink) | |
12-18-2012, 06:57 AM | #94 (permalink) | |
I maidened mine today, and could swear she was humming at the higher head speed. lol.. the shafts just hit Malaysia today, so I ordered one straight up... |
12-18-2012, 07:13 AM | #95 (permalink) |
if you tighten the small bolt on the pitch fork to much the dog bones will drag some you have to play with that to make it just right.
12-18-2012, 09:56 AM | #96 (permalink) |
I measured my tail shaft axial end play with the new gears at 0.006 inch without shims or modifications. How does that compare to what others are seeing?
12-18-2012, 10:09 AM | #97 (permalink) |
Just got mine in, man it was tough, slight chamfer on the black gear shaft and put it in the freezer, then put the tail case bearings and all in the oven on low heat for a bit.
I inserted the old tail shaft into the top of the black gear and pushed it down on the tail case to get it started, once well into the top bearing I removed the shaft and pushed down on the gear with a block of wood padded with a towel folded over. Looks good so far, mesh is perfect, less axial play in the tail shaft and tail grips. I'll report back after next flight on Sunday.
12-20-2012, 03:10 PM | #98 (permalink) |
Actually ordered my new tail shaft kit today, they were in stock in the UK for about 2 hours...
Trex 450 Pro Trex 550E V2 3GX - CC Bec Pro Trex 700E DFC - AR7200BX, Gryphon GSR-7075 Spektrum DX8 - Phoenix Sim |
12-20-2012, 10:42 PM | #99 (permalink) |
Hi,
Another thing I've noticed, the fit of the black umbrella in the torque tube is not tight, has play. I make another test with another black umbrella and have the same play. But when I put the old white umbrella fits tight and don't have play. Can be a problem? Best Regards.
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo |
12-23-2012, 04:55 PM | #100 (permalink) |
Installing the upgraded gears in the bearing was a pain.
I came up with a little tool - I just cut an old 600 torque tube that I had and put it in the drill. Made it much easier to sand down the gears to the point where I could almost get them in there. Put them in the freezer for an hour and viola, in they went.
Trex 600EFLpro
Trex 600NSP DFC Trex 700E DFC Goblin 700 |
