Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-24-2012, 07:55 AM   #21 (permalink)
Nice flying man
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 02:06 AM   #22 (permalink)
Originally Posted by chrismechanic View Post
+1 there...great flying, groovy tunes...way to much fun Anko.
here in the uk we have rain...rain and more rain...
now when is the v4 coming ?
chris
No such thing as a V4, there is however a V3.1 comign with some minor tweaks to the bellcranks and added holes for cable ties and such also, new antirotation bracket, instead of he plastic thingy align has
After that, HEX800
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 03:25 AM   #23 (permalink)
After that, HEX800
i should have guessed HEX800....hmmmmm
chris
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote Quick reply to this message
Old 06-24-2012, 03:55 PM   #24 (permalink)
New frames!
V3.1, has changes at the battery mount, its 10mm longer now so, some added protection,
More holes for twraps,
more holes for frame braces(not needed, but always comes in handy
Went back to the old bellcrank design with 5x9x3 bearings instead of 3x8x3 ones. no more slop.
New antirotation bracket, wich uses the ''old'' plastic mounting holes. so you can choose wich one to use.. it looks better with the frame. and now i have 0!! plastic frame pieces on it.
The newer ARB, lighter, stronger does allow for a little frame flex but thats minimal if you ad a frame brace(holes for it are there).(here still mounted on a V3)
Also, when you buy a framekit, you can have one of those nice keyring thingys
If you are interested in one of these frame kits, PM me.
Old 07-22-2012, 05:04 PM   #25 (permalink)
Promotional video is up!
[ame]http://www.youtube.com/watch?v=SOWySmiyJfg[/ame]
Old 07-25-2012, 11:13 AM   #26 (permalink)
Hi, Sent you a PM for infos ....
How can I have a conversion kit ?
thx
Flydynamics is offline        Reply With Quote Quick reply to this message
Old 07-27-2012, 06:29 PM   #27 (permalink)
Default Yeahhh Baby!!
Last week I (finally due to my own fault..) got the full kit for the Hex50E
Got the motor (Turnigy SK3 560) Kontronik 80HV (later about that) another pair of GensAce 3700mah 60C and some small parts @3D masters so the build was ready to go!
Build went smooth enough, although there was no manual and it was my first time setting up a Vbar (thanks for the help Nko!)
The pics:
Already looking Sweet!
Powered by HK
Sunday morning the weather was great so got to the field early to do the final setup and even had to solder a charge cable @ the field
After all that of course Nko had to do the honors of giving it it's true maiden.....
It was all good, I almost had to "make" him put it down cause the pack was brand new and not charged yet
My first go at it and well....
This is one awesome machine!! Power ohne ende, quick and very precise.
@ roughly 2250rpm it is stellar!! Way too fast for what I can do with it (gonna need to get used to that cause it's addictive )
@ roughly 2000rpm it still is awesome!
What really blew me away was @ roughly 1500rpm! No wobles, shakes or weird tail actions. Thanks to bankswitching still that crisp fast and precise feel to it.
I got to do 4 packs with it...Nr 5 was over really quick
Plugged in the pack and as soon as the connectors touched, poof! The Jive just blew up
Fortunately no other damage and Kontronik service has always been perfect (hope to get it back next week).
Triplets!
Just finished putting a YGE 120HV with Gryphon Quasar bec on it. Gonna try the Vbar gov on it, if it works as good or better than the Kontronik it will stay on it.....
Tomorrow I'll do the setup and hopefully after dinner do some testing.
Iwan
IBremer is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 09:19 AM   #28 (permalink)
Question? I was wondering why you decided to use bell cranks? and how would you mount aileron and pitch servos if you wanted a straight shot to the swash? there doesn't appear to be enough space between the frame and the main shaft!
gr8fun is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 02:15 PM   #29 (permalink)
Looks like a mini 7Hv.
Almost make me want a T550.
My only worry would be replacement parts.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 05:32 PM   #30 (permalink)
hmmm........Nice frame...
Looks like it won't work for a 600 ESP though
AMA #976001
HELIS: TREX 500 (6s), Trex 600 ESP (12S) & Trex 550 (12S): ALL FBL
PLANKS: Hangar 9 Pulse 60, Alpha 40 & Great Planes Revolver
nieves50 is offline        Reply With Quote Quick reply to this message
Old 07-31-2012, 07:16 AM   #31 (permalink)
I went for Bellcranks, because it works and as you said, with the motor on top(best position) there is no room for direct to swash linkage. the ratio on the bellcrank/servo horn is 1:1 so its not noticable and the bellcrank system is made to be slop free using2 5x9x3 bearings per side.
What replacement parts? 550 parts are easy to come by, and 99% of the time, i have spare HEX parts laying around.
Yes, it does. just need to get the 550 bearingblocks, and mainshaft(standard 600 one will work but it will be taller), and the 550 bottom assembly(base plate, and 4 alloy pieces+rx tray), boom, head, swash, gears etc all will drop in from the 600.
Other upgrades will be shown in about a few weeks. im testing with a hybrid taildrive..(wich means belt+tt)
Old 07-31-2012, 08:35 AM   #32 (permalink)
Good to hear!! keeping this frame on top of my list to spruce up my old ESP!!!
Thanks!!
AMA #976001
Old 07-31-2012, 09:38 AM   #33 (permalink)
It's the spare Hex parts are in Netherlands and I am in Canada part.
Cool design though.
Old 08-17-2012, 04:18 PM   #34 (permalink)
So Anko,
Any news on the last tail drive system ?....
Seen the vids on **************.
Old 08-17-2012, 05:17 PM   #35 (permalink)
Still testing, my 2 teampilots updated their hexes as well. Will post more when i know how long things will last...
Old 08-18-2012, 03:31 AM   #36 (permalink)
Cool .. thx ;-)
Old 05-28-2014, 09:10 AM   #37 (permalink)
UP!
1500 flights have been reached on 1 of the systems
belt system failed after 300 flights, flanges on the ''bought than modified'' pulley kept coming lose...
But, i can now mill my own pulleys, wich have over 4000 flights on 4 different helicopters(with 3 different pilots, i own 2 of them)
I have to make some new pictures tho..
