Old 10-27-2011, 06:09 PM   #61 (permalink)
does anyone have any videos? i would like to see this thing in action and see everyones pictures!
Sponsored By:
MingDa Tech Helicopters, Astroid Designs
MKS Servos USA, Haiyin Lipos,
Scorpion Power packs USA
mattox is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 05:55 AM   #62 (permalink)
and has anyone tried diffrent canopies? i seen chp used a logo canopy but what size the 600 or 600se'? the stock canopy looks to big for this frame. any ideas?
Sponsored By:
Old 10-28-2011, 09:03 AM   #63 (permalink)
I took the canopy from my Furion 6 and test fitted it. It would fit perfectly with different mounting holes. It is a lower profile canopy so it doesn't sit below the skids like the stock 700e canopy does. If one were to order a custom F6 canopy from Fusuno with no holes and a Trex700 graphic I think it would look nice. Personally I thought it would look funny with the large canopy but when I saw of in person I found I really like it.
Mr Nice Guy is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 10:57 AM   #64 (permalink)
Dan told me that the Logo 600 canopy is a perfect fit.
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 12:59 PM   #65 (permalink)
can you show me a pic? i really wanna order a canopy that will fit well with it instead of hanging down at the bottom
Sponsored By:
Old 10-28-2011, 01:34 PM   #66 (permalink)
I will try and do a pic but it doesn't have the holes in the right place so it may not stay on by itself. I can also confirm that the logo 600 canopy goes right on.
Old 10-28-2011, 01:49 PM   #67 (permalink)
ok i can always get canopies that dont have holes. i just wanna see what it looks like, and see if i really wanna go that route. cause i do wanna get one orderedasap
Sponsored By:
Old 10-30-2011, 09:08 AM   #68 (permalink)
Default The HORNET!
Had a sorta compromised canopy that inspired this. My servos don't fit under the stock canopy either.
ID:	263601   Click image for larger version
AMA 373608
Old 10-30-2011, 01:34 PM   #69 (permalink)
That sux. I was just about to buy this kit but don't want to hack up my new canopy. You think he/they would have made some sort of standoff that would hold the canopy out......I suppose I'll send them another email.
Tom
litespeed is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 01:36 PM   #70 (permalink)
Oh, no the design is great. I used HV servos that are about 10-12mm taller than normal, so this is all my doing. I used a pair of stock tail rotor servo mounts to make rings that put the servos in the right position. The geometry change of the pushrods is negligible. I could have definiltely used the canopy in it's original form with a little tinkering, but this was calling me. I LOVE it! \
It's the HORNET, BABY!!
AMA 373608
Old 10-30-2011, 01:37 PM   #71 (permalink)
they did for the logo canopy. i ordered the kit with the stadoffs and i ordered a white logo 600 canopy
Sponsored By:
Old 10-30-2011, 02:33 PM   #72 (permalink)
Ah...thanks for pointing that out.
Tom
Old 10-30-2011, 02:45 PM   #73 (permalink)
The 600 3D and 600se canopies are the same size.
Blink 182 is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 09:15 PM   #74 (permalink)
Any thoughts on using this CHP DL frame with an 800 boom and blades? With the added tail weight. Would it be possible to use 6s 5000mah packs to balance it out?
Trex 700N, Trex 450PRO
"Why buy one when you can buy two for twice the price"
A.Delaney is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 09:33 PM   #75 (permalink)
Funny as I was just thinking the same thing. Imagine a 800mm bladed helicopter weighing in at around 10lbs.....can you say, "Power to weight?"
Tom
Old 10-30-2011, 11:36 PM   #76 (permalink)
that would be sick!!! ive also thought of doing a 50 sized machine with this frame. to 6s 3300s a 4035-560 and some 623mm blades!
Sponsored By:
Old 10-31-2011, 06:59 AM   #77 (permalink)
I was thinking the same about the 800 conversion. I bet it would work. I know a Guy who was flying his CHP frames with 5000s. It didn't balance but flew fine that way. I bet with the 800 boom you'd be just about right. One caveat though is you need to watch the physical size of the packs. His TP 5000s wouldn't fit under a Fusuno canopy but did fine under a logo 600 canopy. I believe the Fusuno has slightly less room in it than the stock but am not sure of that.
Old 10-31-2011, 10:15 AM   #78 (permalink)
That sounds like a real wild combo! I'm just worried how well the main gear will hold together once a bit of stick banging happens.. I thought 800 blades were pretty hard on main gears if you fly hard or with a powerful setup?
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote Quick reply to this message
Old 10-31-2011, 10:21 AM   #79 (permalink)
One thing to keep in mind is you'd have a very light 800 so much less stress on the gears than something like a Logo XXTREME. Not to say you wouldn't have problems but I believe you'd have a good chance of it holding together. Especially those new helical gears. They seem pretty rugged.
Old 10-31-2011, 11:16 AM   #80 (permalink)
TT
Hmmmm...I had thought about the 800 conversion just to be able to use heavier packs. I think 800 blades would make this machine too slow. Granted, the disc loading would be super-light but it would fly like a kite. I don't think it would penetrate very well and would lose momentum too quickly on certain maneuvers.
I wasn't impressed by the Logo XXtreme with 800mm blades at IRCHA and it's CLEARLY a much heavier machine. When I saw Kyle Dahl fly the XXtreme again at the SRC it was much better. I asked what they changed and Kyle's dad said they had started using 750mm blades, lightened it up a bit, and it really came to life. Just sayin'...
However, for AP use, the DL frame swinging 800s might be an excellent platform.
TT is offline        Reply With Quote Quick reply to this message
